Eagle
Speaking of locomotives, 70 seems to have been used twice (although the first round of 70s were withdrawn before they could be numbered individually). The same goes for 43.
The only other possibility is that SWT were adament they never wanted their units to be numbered 3xx.
It could well be that at the time it was being decided there was no realistic likelihood of any SWT (ie SW division) services being combined with any AC routes.
Apart from Anglia's services from Basingstoke to the GEML (although these were run with Turbostars due to no dual-voltage stock being available).
EMUs couldn't get from South Acton to Brentford...
465 and 466- and even 455- were arguably the "correct" numbers according the Southern Region system. The Wessex units seem to have though gone through as a "70-s design"- I suppose the Mark 3 coach was- as otherwise 4x2 was correct (as they had some sort of buffet).
The southern region system only worked though where you had centralised procurement, ensuring that effectively only one design per purpose was ever built in each time frame.
Also, all TGV sets are given a unique number
consisting of 3 digits (325, 408, etc...). The TMST didn't fit that either as all sets are identified by a four digit number (3017, 3223, 3313, etc...).
themiller:1121330 said:If you look at the current European Handbook no 4, the Thalys PBKA, TGV POS And the TGV Reseau (TGV-R) all have 4 digit unit numbers! Also from personal observation.
I think that the '3' prefix on southern stock could be reexamined, things were easier to understand with letterd prefix such as BIL HAL SUB CIG VEP etc, all of these were both descriptive and easy to remember, new prefixes could be invented for each unit type could be invented by all of us on here that find 'dc land' interesting like me.
I think re - examing the '3' prefix would make things even more complicated than they all ready are at the moment. However, when you consider that the class 450's and 444's are actually dual voltage so could be used with a pantograph to get power from a OHLE then I do see the point you are making in this thread.
But the 377's are correctly numbered in my point of view, as they do travel on the west coast mainline ven if it is only as far as Milton Keynes. Plus the original London Midland 350's where going to be extra 450's for SWT I believe until things got changed.
From what I have heard the new thameslink stock will be in the 7xx series, anyone any the wiser.
Hasn't 700 been seen in writing somewhere? I wondered whether there was an intention for ATO stock to be classified in a separate sequence?
The only mention of 700 that I can find, is that FCC have 700 drivers that will need to be trained up on the new trains. An other links that I found that mention Class 700 are hearsay on other Railway Forums.
Rail vehicle group - Class identifier range
Diesel mechanical / hydraulic multiple unit sets - 100 199
Diesel electric multiple unit sets - 200 299
Diesel multiple unit sets - 600 699
d.c. electric multiple unit sets - 400 599
a.c. and a.c. / d.c. electric multiple unit sets - 300 399
a.c. and a.c. / d.c. electric multiple unit sets - 700 799
High speed multiple unit / fixed formation sets - 800 899
Infrastructure maintenance / non-passenger multiple unit / fixed formation sets 900 999
Since the order has not been finalised as yet, I don't believe any class number has been specified to the Siemens Desiro City trains that will be running Thameslink as yet. However, I suspect that it is going to be a 3xx number due to the fact of their dual voltage capability. I am suspecting that it is going to be Class 38x, possibly either 382 or 385.
Sorry, but it definitely isn't just 'hearsay on other forums'.
The changes to the relevant Railway Group Standard were made last year, and unit number ranges specifically can be found on page 18:
http://www.rgsonline.co.uk/Railway_...ck/Railway Group Standards/GMRT2453 Iss 2.pdf
Doesn't mean Thameslink will necessarily be Class 700 exactly, but there is no reason why they won't be numbered in the Class 7xx series.
Does this only apply to new stock or are we about to see a massive renumbering excercise?
... We haven't really run out of numbers have we?
Cl.70 got used twice, why shouldn't cl.103, 105, 110 etc?
The more recent numberings aren't especially messy if you break it down. (Well, the 4xx range is, but that's because it's still trying to conform to the Southern Railway's long-obsolete system of classification.)
*deep breath*
1xx series
- The original series of DMUs were numbered sequentially, getting as far as 131.
- The Pacers were introduced, with the prototype jumping forward to the next round number, 140, and the actual units being 141–144.
- The next family, Sprinters, jumped forward again to 150. 151 and 152 were planned but never built.
- The next generation of Sprinter was felt different enough to warrant a jump forward to 155. 156 followed, and 157 was planned (for Scotland). When much later some 155s were broken up, they were simply given an available number, 153.
- The Express Sprinter continued with 158. When some were sent to the south, they were renumbered as 159.
- The next family to be introduced, the Networkers, decided to jump again to 165 (which also allowed their electric versions to take the free numbers 365 and 465). 166 followed.
- The Clubman had a minor jump forward to 168, and its successor, the Turbostar, another minor jump to 170–172.
- The next type of DMU to appear was the Coradia, which went to 175. Its successor, the Adelante, jumped again to 180.
- The most recent new design of DMU was the Desiro Pennine, which took 185.
2xx series
- The original series of DEMUs was numbered sequentially, up to 210.
- The Voyager came much later and was unrelated, so it jumped forward to the 220–222 range.
3xx series
Admittedly a lot more complex than the diesel series. In order of introduction:
- The sequential-style numbering got as high as 325.
- Networkers took 365, to match the 165s.
- The first EMUs since privatisation were the HEx units, which for no reason I can discern were numbered 332. Their successors in the North were numbered 333.
- Electrostars, again for no obvious reason, took 357. Why their next generations jumped to the 375–379 range is equally obscure.
- The Junipers went for 334, breaking the rule that different series of trains shouldn't use adjacent numbers.
- Pendolinos, presumably because they are high-speed units, went for a high number: 390.
- The WCML Desiros went for 350, because they were originally meant to be 450s. Subsequent Desiros went to 360, skipped 370 (which was the APT) and went to 380. Pretty silly way of numbering them if you ask me; why not 350, 351 and 352, Thameslink stock being 353?
- The Javelins took 395, because they're higher speed than the 390s.
5xx series
Only ever used the sequential system which got up to 510 (the 510s ended up in the Southern Region however, and were relabelled as 455s).
