Three Bridges to Woking and return, stopping on way at Twickenham or Hounslow
James Wake
30 Aug 2013
Good morning all
I’ve got a possible journey to make on Sunday which is essential work related.
I will need to travel from Three Bridges to Hounslow or Twickenham for an outward journey.
Then travel home from Woking to Three Bridges probably via Guildford and Reigate.
Would a 26-30 railcard discounted Three Bridges to Woking off peak day return not via London be valid to do this, and to stop short at Hounslow or Twickenham?
Many thanks in advance
Nunners
19 Oct 2018
It's valid if the ticket is valid via Hounslow or Twickenham. The route from Woking back to Three Bridges is the shortest journey and so automatically valid.
In the routeing guide, Three Bridges to Woking has LONDON as a code, so as WV+WX is a route from London to Woking, to Twickenham would be a valid route on an Any Permitted ticket.
I THINK you are still allowed to use those maps on a not via London ticket (as long as you don't go into London - changing at Clapham Junction would be best). You might want to check with someone else.
It is a reasonable route IMO, so I wouldn't expect any trouble from going that way.
As always, if you can get a journey planner to give you that journey, it's valid.
James Wake
30 Aug 2013
Turns out now I’ll be breaking at Clapham Junction then resuming from Woking in the evening as planned. So I’ll use a Not Via London ticket and not go into London Terminals
JB_B
27 Dec 2013
.. I THINK you are still allowed to use those maps on a not via London ticket (as long as you don't go into London - changing at Clapham Junction would be best). You might want to check with someone else. ..
Yes, that's the tricky question : "can you use a route:Not London ticket to trace a route (avoiding London Group itself, of course) on a combination of the to-LONDON and from-LONDON maps ?"
It's been discussed before - I think most recently here:-
https://www.railforums.co.uk/threads/trainsplit-v2.149312/post-3114406
I get the impression that the consensus answer (amongst people wiser than me) was either -
"No."; or
"No, except where there only yellow pages entry is LONDON"
I'm still not completely sure that's correct - certainly that interpretation rules out some perfectly reasonable routes - including the one that the OP wanted here.
