Through and bay platforms
Discussion in 'Infrastructure & Stations' started by PMN1, 4 May 2019.
  1. mcmad
    mcmad Member
    526
    11 Mar 2015
    Was the original intention not to run the borders as an extension of
    originally the Bathgates (until A2B) and then Fife but the likelyhood of spreading disrutption in Fife onto the single line (and the south end bay platforms) largely put paid to that.
  2. railjock
    railjock Member
    305
    30 Jun 2012
    That’s how the original Crossrail service to Newcraighall ran but this was changed to minimise delays.
  3. mr_jrt
    mr_jrt Member
    881
    30 May 2011
    I'd argue the bay platforms at Edgware LUL would be more useful had the conversion to through platforms been completed :)
  4. edwin_m
    edwin_m Veteran Member
    14,837
    Only if the development it was intended to serve hadn't been cancelled by introduction of the Green Belt.
  5. noddingdonkey
    noddingdonkey Member
    451
    2 Nov 2012
    Huddersfield has the opposite problem with its bidirectional through platform 4 being used as a pair of bays for most of the day.
  6. 61653 HTAFC
    61653 HTAFC Established Member
    9,774
    18 Dec 2012
    Another planet...
    That (at least in part) comes down to one of the two East facing bays (5) being very short. At the last May timetable change, that short bay saw very little use as the Wakefield service became diagrammed as a 3-car 144 meaning it had to use 4a or 6. The Leeds via Bradford has a long (>30min) turnaround at Huddersfield and blocks one of those.
    When the Leeds to Manchester Piccadilly stopper was split, the Manchester half uses 4b and the Leeds half uses whichever of 4a or 6 isn't occupied by the Bradford service. This in turn meant the Wakefield could only use P5, so can only use a 2-car Pacer, a 153, or a 150 as that's all that'll fit.
  7. Glenn1969
    Glenn1969 Member
    457
    22 Jan 2019
    Platform 5 at Huddersfield is far too short. I did wonder if it could be extended under the Transpennine Route Upgrade?
  8. 61653 HTAFC
    9,774
    18 Dec 2012
    Another planet...
    The medium-term plan should render it obsolete, as only 2 services per hour will terminate at Huddersfield from the East.
  9. PHILIPE
    PHILIPE Established Member
    9,900
    14 Nov 2011
    Caerphilly
    Similarly Kirkby
  10. camflyer
    camflyer Member
    208
    13 Feb 2018
    The 4 bay platforms at Cambridge rather limits capacity at the station.
  11. edwin_m
    14,837
    But it was much worse until a few years ago.
  12. xotGD
    xotGD Established Member
    1,805
    4 Feb 2017
    Newcastle Central lost 6 bay platforms and gained 2 through platforms. Changing requirements and reduced conflicts.
  13. camflyer
    camflyer Member
    208
    13 Feb 2018
  14. Deepgreen
    Deepgreen Established Member
    4,142
    12 Jun 2013
    Betchworth, Surrey
    Redhill! The recent project to provide the additional (through) platform 0 resulted in platform 1 becoming a south-facing bay, when it should have remained a through platform. The cost of re-signalling to permit this has resulted in a sub-optimal layout.
  15. mr_jrt
    mr_jrt Member
    881
    30 May 2011
    Well, you could argue that even making it as far as Brockley Hill for a P&R would have been very worthwhile - it would have relieved the road pressures around Edgware station massively, and rather handily, would have got the line safely out through the built-up area should things ever change, policy-wise. It would also have probably saved the line between Edgware and Mill Hill East, which would be very useful.
  16. MML
    MML Member
    294
    25 Oct 2015
    Totally ridiculous layout.
    GWR Reading service blocks through platform 0.
    Platform 1 now a bay for the Tonbridge shuttle where the 3 car unit sits at the end of the platform without platform canopy.
    All the northbound services funnelled into platform 2 while southbound services queued waiting to use platform 3.
    Hours spent sat outside Redhill each month.
  17. PeterC
    PeterC Established Member
    1,838
    29 Sep 2014
    With hindsight Chalfont and Latimer which would now allow an S8 to operate as a shuttle if necessary or to be held in a platform clear of the branch. Sadly not worth retrofitting. (Would have also allowed freights and locals to be looped when the GCR shared the line)
  18. Y Ddraig Coch
    Y Ddraig Coch Member
    540
    1 Nov 2013
    Chester - 5 bays but only 3 through platforms so they have had to split them all into a & B to make it work.
    Often lots of hanging around at lights outside the station at both ends waiting for a platform.
  19. Aictos
    Aictos On Moderation
    7,928
    28 Apr 2009
    How about Sheffield?
    Link Platform 2C with Platforms 4A/4B and renumber to Platforms 5A/5B.
    Extend Platforms 3A/3B to be a though platform and renumber to Platforms 4A/4B
    Ideally though the whole station would be remodelled with the following changes:
    Platform 1A/1B to stay as it is
    Though Line to be served by a new platform numbered as Platform 2A/2B
    Platforms 2A/2B become 3A/3B
    Platforms 3A/3B become a though platform and numbered as 4A/4B
    Platform 2C joins with Platforms 4A/4B and renumber to Platforms 5A/5B
    Platforms 5A/5B become a though platform and numbered as 6A/6B
    Platforms 6A/6B become a though platform and numbered as 7A/7B with the shunt signal removed and replaced with a full aspect signal
    Platform 7 to stay as it is and renumbered to Platform 8
    Platforms 8A/8B become 9A/9B
    That should provide enough capacity for the next 30 odd years!
  20. iphone76
    iphone76 Member
    532
    6 Nov 2010
    South Essex
    Wickford bays - Platforms 1 and 4. Would mean the new trains could fit in the station.
  21. PHILIPE
    9,900
    14 Nov 2011
    Caerphilly
    And one of the bays (alongside platform 1) is not for passenger use.
  22. 30907
    30907 Established Member
    6,415
    1. The additional platform adjacent to the through road would be very narrow (why only one, BTW) and difficult to provide access to (though it has been done at Gravesend).
    2. Sheffield has 5 through platforms for 4 through trains per hour (edit: each way!) plus the two terminating Londons. Does it need more through platforms?
  23. johnnychips
    johnnychips Established Member
    1,839
    19 Nov 2011
    Doncaster
    I agree it’s impractical and unnecessary, but it is eight through trains an hour. Have you forgotten to double it for the trains in the opposite direction?
  24. jopsuk
    jopsuk Veteran Member
    11,908
    13 May 2008
    Network Rail have published somewhat speculative plans for adding a second island, that would ideally happen in concert with an eastside entrance. It's going to become a more acute issue, as double-unit West Anglia services when the fleet is replaced won't fit in 2&3. With the current future timetable proposals/stock changes, all that will be able to use 2/3 will be the slow Thameslink (class 700/0) and any Liverpool Street services formed of a single 720/5. Currently the 1Hxx services to Liverpool Street use the bay, but I'd have though there would be a desire to have longer trains on the fast services, as the 2Hxx (which start at Cambridge North) will probably mainly be single units due to calling at shorter platforms.
    And if/when the airport services become merged with the norwich services, that's even more use of throughs, less of the bays.
  25. thenorthern
    thenorthern Established Member
    3,361
    27 May 2013
    Manchester Piccadilly I would think is the main one as since the Windsor Link Platforms 13 and 14 are being used by much more services than they are designed to do so.
  26. Taunton
    Taunton Established Member
    3,627
    1 Aug 2013
    I lived in Edinburgh for several years in the 1970s and never once saw the mid-platform crossovers used. Don't know if they are now. Apart from the handful of through Aberdeen-London services everything else terminated, but main line services all seemed to use just the two main platforms, generally stopping at the midpoint fouling the crossovers anyway. There were always too many east end bays and not enough west end ones.
    A station which could use at least some through platforms is Inverness, all bays, pointing two different directions and linked by a through avoiding line. Some trains have always been run past the station on the avoiding line and then backed into the opposite side of the station, Limerick Junction style, for a range of reasons - transfer of passengers/mail, next working, enabling the loco to be easily released, etc.
  27. Scotrail84
    Scotrail84 Established Member
    2,014
    5 Jul 2010
    It has 9. Platforms 1 and 2, 7, 8, 9, 10, 11, 19 and 20 are all through roads.
  28. Steamysandy
    Steamysandy Member
    192
    29 Jan 2018
    Longniddry
    I used Edinburgh Waverley on a five days a week basis for the best part of 30 years and saw the mid platform crossovers used regularly such as trains via Carstairs leaving old platform 10 crossing to pass whatever was in Platform11 or North Berwick services coming into Platform 1. from Haymarket bypassing old platform 19 to give 2regularly seen examples
  29. TheGrew
    TheGrew Member
    243
    31 Jul 2012
    Nobody seems to have said Manchester Victoria which in my experience can get rather congested during rush hour. Though the solution to that might well be extra bays on the western side of the station.
  30. 30907
    6,415
    Knew there was something wrong :)
Share This Page
