Ticket machines used by bus companies.
83G/84D
28 Oct 2011
Cornwall
What types are used by bus companies and are the same ones used across the groups such as First Go Ahead,Stagecoach etc?
pompeyfan
24 Jan 2012
From observation and experience, First split their ticket machines into operating areas.
First south west and Wales (including hampshire) use a machine manufactured by Almex.
First eastern counties, such as Essex, use the same machine that My local Go-Ahead and Stagecoach operators use.
There's also a cheaper one called ticketer which is used by smaller independent companies.
trentside
Fares Advisor
14 Aug 2010
Messroom
Ticketer is aparently very diverse and can handle all sorts
Having been given a demonstration of things it can do by a driver, it seems a very versatile and easy to use system. Also capable of doing things like two way messaging, defect reports etc.
skyhigh
14 Sep 2014
Uno bus in Hertforshire uses a ticket machine used by INIT - nasty things, controlled by a touchscreen that appears to spontaneously go out of calibration with no way for the driver to re-calibrate it.
First in West Yorkshire also uses Almex machines.
Rich McLean
6 Feb 2012
Wayfarer in use on NXWM, with the old style ticket printers behind the drivers cab
GaryMcEwan
20 Aug 2013
Bridgeton, Glasgow
McGills currently use Ticketer on it's 23 and also on the ClydeFlyer routes and on all the other routes they use Almex. They were trialling ERG on the 23 but went for Ticketer instead.
I believe First Glasgow is either in discussions or almost ready to get rid of the Almex machines and replace them with ERG.
Stan Drews
5 Jun 2013
Transdev Blazefield use Parkeon Wayfarer, with the new Wayfarer 6 going into use soon in Lancashire.
90019
29 May 2008
Featherstone, West Yorkshire
Lothian currently uses the Parkeon Wayfarer 200, but I believe they're being replaced next year.
Whatever new machines they go for can't come soon enough*, because the 200s are mostly worn out and generally just a bit crap.
*Unless they're worse.
ag51ruk
29 Oct 2014
Trent Barton use INIT machines as well, although I haven't noticed drivers having any issues using them
Bungle965
Buses & Coaches
2 Jul 2014
Blackley and Broughton/ Walsall South
First Manchester also use Almex Optima BLs.
Sam
