I'm travelling from London to Shrewsbury & back next weekend but see the Chiltern line is closed and passengers are being advised to use other routes / operators.
I would normally buy a ticket via High Wycombe but this route is not possible (other than by replacement bus). Can I buy this ticket but use it on Virgin or Cross Country services to Euston or Paddington, or do I have to buy the more expensive 'all routes' ticket because the Chiltern Line is closed?
Chiltern's Website - 'Due to Network Rail engineering works in the Haddenham & Thame Parkway area, together with HS2 preparation works at West Ruislip, the line between Marylebone and Bicester is closed at multiple locations. A heavily-amended timetable will operate on all Chiltern Railways routes, and most journeys will be affected. Passengers may need to travel via alternative routes, on other operator's services, London Underground services and/or rail replacement bus services. Journey times will be considerably longer than usual.'
