The tilt on the Shanghai Maglev which runs from Pudong Airport is something different to experience. With a top speed of 430kmh (approx 270mph) the journey doesn't take long enough to feel sick.
That's superelevation, not tilt.
That's a relief, now I know we were merely superelevating round bends I feel much better.
From personal experience, it wasn't just tanked up journalists who felt sick on the APT.
APT attempted to compensate fully for lateral acceleration, so passengers would feel as if they were on straight track but looking out of the window would show they were on a curve. The resulting sense of disorientation was thought to be one reason for feeling sick. The way round this was to modify the systems to compensate only partly, so passengers still felt some pull to the side on a curve. This seems to have solved the sickness problem and also has the benefit that less tilt is needed so the train can have a larger cross-section and feel less cramped.
Tilt is where the train itself moves.
Cant is where the track is tilted (like at Rugby where the track is canted AND the train tilts)
I wouldn't have called Shanghai maglev as "tilting" either though, the train stays where it is on the track, it's the track that "tilts".
Although a quick look at dictionary.com may help
I'm not sure what Shanghai Maglev you were riding but on all the times I've ridden it (20+) it's always been smooth and even at max speed (431km/h) the cant of the track is not noticeable.
You can't feel it even if you ride in the cab (Even though you can see the track cant).
A quick look at dictionary.com did help, it confirmed I don't understand the point you're trying to make . To my simple mind if the train doesn't tilt (or lean if you prefer) with the track (or magnetic field) it shoots off at a tangent with unfortunate consequences. I suspect we may be playing a game of semantics.
Tilting is only about passenger comfort, it's never about derailment safety.
Cant, a.k.a. Superelevation, is about both but can be hard to balance when trains of different speeds use the same curve (freight, intercity, stopper etc).
Tilt will increase the comfortable speed but not the maximum safe speed
It will increase the maximum safe speed by moving the centre of gravity of the train towards the inside curve although the effect is small. Where you can see the effect more prominently is with motorcyclists.
Very little. Basically they just need to reinstate the balises after sleepers are replaced.How much maintenance does the TASS system require?
How much maintenance does the TASS system require? After HS2, would it be worth the effort to keep the system running for the intercity trains that remain? (as there will be fewer and they will have more stops so less 125mph running)
(The economic case for HS2 shows around 6 or 7 intercity trains out of Euston per hour post HS2)
How is tilt failure handled? (Assuming that the train isn't in its vertical position, that isthen I presume they just continue with it isolated at normal line speed?)
Was on a train where this happened and it was quite severe. We were in a corner and tilted normally one moment and the next the train had levelled itself out and the emergency brake was on. The act of being levelled out so quickly was a bit rough and the 390's ability to drop the anchor is quite impressive! There was certainly plenty of leaning around like a bad sci-fi show
After 10 minutes of standing still we were back underway, though with tilt disabled and speed reduced as a result.
