"Timed for 224mph"
tsr
15 Nov 2011
Between the parallel lines
As many of you are well aware, what a train is listed on RTT "timed for", the stock used and the maximum speed attained are all different things. But the following VSTP schedule for 2A04 0102 Ldn Victoria-Brighton caught my eye on Realtime Trains tonight: http://www.realtimetrains.co.uk/train/W88640/2015/08/09/advanced
As you can see, it is timed for the absurd figure of 224mph. Has anyone seen higher, and does anyone know if this is the theoretical maximum able to be entered into the various systems or not? It is pretty blatantly an error but seems like a more interesting one.
(The reason for the VSTP schedule is that there is an additional possession between Redhill and Stoats Nest Jn tonight.)
Tommy1581
2 Feb 2015
Ashganistan (or Ashington)
Once had a Pacer timed for 168mph max.
PHILIPE
14 Nov 2011
Caerphilly
There already a couple of Posts on the on the Forum reporting VSTP HSTs timed as 280mph
SpacePhoenix
18 Mar 2014
Would HS1 even have a maximum line speed limit approaching that - I thought that for HS1 that max line speed was 300kph
61653 HTAFC
18 Dec 2012
Another planet...
There's the jokey Christmas schedules (North Pole depot to North Pole depot via anywhere and everywhere) that tend to have crazy timings...
Tom
19 Jan 2008
35,000ft
It isn't a fault in TRUST directly nor is it a fault in RTT.
The schedules are seeing accurate speeds in TRUST, and they're coming through inaccurately on my end. So...
Freightmaster
7 Jul 2009
...there's a kink in the space/time continuum in the Milton Keynes area? :)
MARK
Philip C
21 Feb 2013
MARK
Does that mean that there is some hope of the whole MK area falling out of existence, the green fields reappearing and us all agreeing that it was just a bad dream?
MCR247
7 Nov 2008
It could do, maybe some Wimbledon MK Dons fans are behind it <D
greatkingrat
20 Jan 2011
Looks like there is a multiple of 2.24 floating around
224 mph = 100 mph
168 mph = 75 mph
280 mph = 125 mph
JamesRowden
31 Aug 2011
Ilfracombe
224 mph = 100 mph
168 mph = 75 mph
280 mph = 125 mph
I think that it must be a confusion between miles per hour and meters per second since a meter per second is equal to 2.2369 miles per hour.
Someone might have meant to insert 100mph but inserted 100mps instead and the system subsequently calculated that as 224mph.
2.24cm in an inch if memory serves correctly... mectrification by stealth? :D
It is 2.54cm to an inch.
Deepgreen
12 Jun 2013
Betchworth, Surrey
Still arrived late though!
