Tinnitus
danbarnstall
1 Apr 2014
I have minor tinnitus, is this an issue with TOCs?.
I have seen a specialist who advised my hearing capacity is still 95%, so only very very minor hearing loss. At most 10db but closer to 5.
Thanks in advance
Lrd
26 Jul 2010
You shouldn't have any issues. I also have minor tinnitus and was able to pass a hearing test for my current role (driver) with no struggles.
Lrd
26 Jul 2010
Is the hearing test passable if you had a hearing aid in one ear? :|
Couldn't possibly say. You would have to talk to a potential employer and see what they say.
It also depends on what role you want to do.
whoosh
3 Sep 2008
From here,
A.1.40
"Hearing and speaking requirements (3) Sufficient hearing confirmed by an audiogram, i.e.—
– hearing good enough to hold a phone conversation and to be able to hear warning sounds and radio messages.
The following values should be taken as guidelines—
(a) the hearing deficiency must not be higher than 40 dB at 500 and 1000 Hz, (b) the hearing deficiency must not be higher than 45 dB at 2000 Hz for the ear with the worst air conduction of sound, (c) no anomaly of the vestibular system, (d) no chronic speech disorder (given the necessity to exchange messages loudly and clearly),
(e) the use of hearing aids is allowed in special cases.
Infrastructure managers and railway undertakings should consider whether some occupations, even those where mandatory hearing standards currently exist, require additional or more stringent hearing standards in order to control other identified risks. This might be, for example, a train driver working on or near the line. It should be noted that the widely adopted hearing standard for persons who are required to maintain their own safety when working on or near the line is that hearing loss should not exceed 30 dB averaged over frequencies 0.5, 1.0 and 2.0 kHz in either ear."
I did used to work with a Driver with a hearing aid at my previous company.
Llanigraham
23 Mar 2013
Powys
From the Signalling Grades, you cannot get a PTS Card if you wear a hearing aid, so certain jobs are out.
20 Jan 2016
I have hearing loss in both ears, around 40% but probably more
And you're employed by a major TOC? What role are you in? Did you have the impairment before you got the job or has it got worse in recent years?
Sorry for all the questions, I have a lot of research still to do but am determined to get to the bottom of this.......
