Oscar46016
Is there any reason gaps were left when TOPs came into being - ie whatever happened to Class 36's ( did they even exist ) and I guess there must be others 49 51 etc?
Thanks - but it doesn't answer the question
Hymecks were class 35 tractors 37s - why weren't tractors Class 36?
And why weren't Hymecks 34s?
When they got to type 4s no gaps were left
That’s no different from many EMUs (eg large parts of classes 375 and 377) that have no pantograph so are DC only, yet are numbered as AC units.Because they are 'multi-modal' and so have to fit in the range 750-799. The list on wikipedia is not very helpful - the correct version is on page 33 of this standard (table 7). The real 'oddity' in the sense you ask about (primarily diesel but registered as a bi-mode) would be the welsh 769s, which have had their pantographs removed and are incapable of operating from electrified infrastructure!
It is foolish to look for logic in TOPS numbers when none exists (at least anymore)...
When TOPs classes were allocated in the 1960s no account was taken of carriage numbers, resulting in overlaps with dmu vehicles in the 50xxx and 55xxx series (and later the 56xxx and 59xxx series) as well as numerous hauled stock types and a handful of emu cars, until a mass renumbering of coaching stock in the mid 1980s.Gaps were left for future builds and to avoid clashing with multiple unit vehicles and coaching stock.
One can hazard a guess at what was intended to fill the gaps.
18, 19 There were two different engines and two different transmissions types used in the class 17 "Claytons". Such differences led to three classes of "Peak" (Classes 44-46), and it is possible that the original intention had been to distinguish the Clayton variants in the same way.
32, 34 Possibly again the three subclasses of Class 33 were at one time intended to take separate class numbers.
36. The power rating of the LMS "Twins" would fit them in here. Both still existed in 1967, although they had been withdrawn from service in 1963 and 1966 respectively.
38, 39. Not sure about this one - were there variants of the 37s that early?
49, 51, 54. There were a number of engine/transmission variants of the Brush Type 4 - possibly as many as seven. (Class 48 was used for the examples with V-form engines). Classes 50 and 53 may also have been intended for class 47 variants, as those classes did not exist in the mid-60s.
72. The original six class 73s differ in several respects from the rest. Could class 72 have been originally intended for them?
I can imagine that once the classes had been provisionally allocated, someone decided to amalgamate some of them, but closing the gaps would have led to possible confusion.
So HS2 trains will be under the 8XX prefix. On the other hand, they made the 73's an anomaly just so the 70's weren't an anomaly.
Information I have (can't comment on veracity) suggests that LMS 10000/1 were allocated class 34, also the narrow body 33/2 was allocated 34 at some stage.32, 34 Possibly again the three subclasses of Class 33 were at one time intended to take separate class numbers.
The same info says this is correct.72. The original six class 73s differ in several respects from the rest. Could class 72 have been originally intended for them?
Since 73s are (now) unique, there being no other dc-only electric locos, they will be anomalous however you classify them. The only other dc electrodiesels were the 74s. The only other dc-capable electric loco class currently in use are the 92s. The only other electrodiesels are the 88s.
And since many 73s work in Scotland, hundreds of miles from any dc juice rails (except the Glasgow Subway, which is barred from use by 73s for many reasons, not least the 4 foot gauge) - and have had their shoegear removed, I believe - they are to all intents and purposes Type 3 diesels. Indeed, with a power output of 1500hp (Cummins engines) or 1600hp (MTU) they would fit in neatly at vacant classes 32 and 34 respectively!
As far as I'm aware the GBRf ones can still work off third-rail
Apparently so, although the actual shoes have been removed from the ones working in Scotland to avoid clearance problems. A possible reason they did not get a new classification, despite the extensive rebuild (at least as significant as class 21 to 29, 30 to 31, 47 to 57, or class 56 to 69) was because they would then count as new locos and different emission standards would have had to apply.
I'm pretty sure the Scottish ones have no shoes, to avoid them getting bashed off by high ballast shoulders (which were put like that when there was no need to think about Southern third rail stock running there!).I thought they still had shoes but the 750V capability was isolated as in flick a few switches or plug something back in and that would suffice.
The 73s were originally classified JBs by the Southern Region, for what it's worth.
Class 53 was the Falcon prototype
Class 21 has also been used twice.Indeed, but that loco was not taken into BR stock (or given a BR number) until 1970. As it had the same engines as the Westerns (class 52), the next highest number was the obvious choice.
Classes 41, 43 and 70 have all been used twice.
Back in the day when all this was being proposed, there were 1600 & 2000 bhp versions of Class 31, and, possibly, some potential distinction between the original Merrilees engined versions and those re-engined with EE engines - ultimately all of them. It is possible that these would have accounted for some of the gaps in class numbers.
