TPE Class 397
Discussion in 'Traction & Rolling Stock' started by absolutelymilk, 4 Apr 2017.
  1. 158820
    158820 Member
    178
    1 Nov 2017
  2. driver9000
    driver9000 Established Member
    3,595
    13 Jan 2008
    Me too!
  3. 158820
    158820 Member
    178
    1 Nov 2017
  4. AndrewE
    AndrewE Established Member
    2,648
    9 Nov 2015
    Is that the locos for 2 trains and the barrier wagons for 3 then?
  5. 158820
    158820 Member
    178
    1 Nov 2017
    They should all of that lot for that 1 397 move, going off previous observations
  6. AndrewE
    2,648
    9 Nov 2015
    Thanks, I guess they must be running top-and-tailed with extra vehicles for brake force then. (Sorry, I just can't get used to the idea that a train of coaches for use here in the UK has to run as an unfitted/piped block of vehicles... Maybe this is another reason why I (and others) wonder whether we shall ever have a smart railway again!)
  7. SP Man
    SP Man Member
    113
    26 Aug 2018
    It's s strange one, running with 5 unbraked vehicles together is a funny one. Group standards wants a working distributor every 80m when hauled in freight train or if not in freight train only allowed 3 non brakes isolsted together. This means that this should have a portable distributor to split the 125+m between working distributors.
  8. Sleeperwaking
    Sleeperwaking Member
    43
    20 Oct 2018
    The 397s aren't approved for use in service yet and as EMUs they probably weren't designed to be fully pneumatically / electrically compatible with locomotives. It might just be easier to treat a newly formed unit off the boat as an unpiped block than go through all the required approvals / safety hoops for a one off set of delivery moves.
  9. JamesGar
    JamesGar Member
    411
    24 Oct 2015
    Moving 397010 I've been told
  10. sd0733
    sd0733 Established Member
    1,214
    7 Nov 2012
    It passed through Crewe earlier on, all centre cars are shrink wrapped. I wasn't that close but didn't notice a set number on it.
  11. driver9000
    3,595
    13 Jan 2008
    397001. The consist seems to have been inputted wrong but labels in the windows confirm it is UT1.
  12. driver9000
    3,595
    13 Jan 2008
    No set number applied yet.
  13. mikemcniven
    mikemcniven Member
    316
    13 Aug 2016
    Manchester
  14. Robert Mann
    Robert Mann Member
    27
    5 Nov 2018
    Llandudno
    561T 09:54 Holyhead Anglesey Aluminium - Manchester International Depot passing Llandudno Junction today
    LlandudnoJunctionRailStation2019.02.05-14.jpg LlandudnoJunctionRailStation2019.02.05-16.jpg
  15. SP Man
    SP Man Member
    113
    26 Aug 2018
    Can't believe it's still hot the rapping on again. Last time started to peel off and dangerously flap about, you can see on these photos that it's starting to peel in places again.
  16. mikemcniven
    mikemcniven Member
    316
    13 Aug 2016
    Manchester
    Gives a bad look for TPE and CAF for the units as they are delivered too
  17. JamesGar
    JamesGar Member
    411
    24 Oct 2015
    Why is it only on 3 carriages? And not the end cars?
  18. LittleAH
    LittleAH Member
    56
    24 Oct 2018
    Not really sure how it can be a bad look for TPE given that they've yet to accept the trains...
  19. mikemcniven
    mikemcniven Member
    316
    13 Aug 2016
    Manchester
    In the way that if it does come off and get stuck and someone see's then it's TPE's livery and Logo everywhere
  20. Jonny
    Jonny Established Member
    1,962
    10 Feb 2011
    Possibly because internal access was required to couple the barrier coaches...
  21. TBSchenker
    TBSchenker Member
    525
    15 Sep 2010
    Is the reason known why the 397 hasn't run out of Crewe this week yet?
  22. SP Man
    SP Man Member
    113
    26 Aug 2018
    Awaiting paperwork issues. Hopefully running Friday.
  23. Swanny200
    Swanny200 Member
    148
    18 Sep 2010
    What are the arlington marked carriages, I assume that they are old NSE stock, are they just barrier vehicles or are they still driveable in some way shape or form?
  24. 59CosG95
    59CosG95 Established Member
    3,308
    18 Aug 2013
    WIM/PBO
    They're barrier vehicles, converted (as you suspected) from old NSE stock (of Mk1 vintage). AIUI they are no longer driveable.
  25. Swanny200
    Swanny200 Member
    148
    18 Sep 2010
    Thank You, I did wonder. I know they are based at Eastleigh which made me wonder if they could still be driven on the 3rd rail. I know that they converted some of the old Connex 508's to barriers however they swapped the cabs around so they faced eachother and blanked them off, these ones still looked like the cab windows were present.
  26. Erniescooper
    Erniescooper Member
    370
    27 Mar 2010
    I think they are old de-icing units because when you look inside they still have the bulk containers for Kilfrost or whatever they use.
  27. 43096
    43096 Established Member
    4,413
    23 Nov 2015
    Are they not ex-InterCity Gatwick Express vehicles (and originally SR 2-HAP driving motors).
  28. Erniescooper
    Erniescooper Member
    370
    27 Mar 2010
    68501 and 68504 , both former Gatwick Express then De-icer and now translator vehicles
  29. driver9000
    3,595
    13 Jan 2008
    Is it running today?
Share This Page
