driver9000
- Joined
- 13 Jan 2008
- Messages
- 4,243
Great to hear, are these into fault free running now then or just testing do we know?
I don't know what stage they're at but it was laden with weights.
A trip up the WCML yesterday found 397004 at Crewe with another set which did not appear to have any unit numbers and a further unit at Carlisle in the bay, presumably 003. There was also a 68 with a coach set in a loop near Lancaster. Any ideas on what the unit was or the 68 and the stock?
397003 was again out of the 3Q51/3Q52 testing circuit again
Transpennine Express 397003 by Mike McNiven, on Flickr
Is the coupling cover a replacement for the one that was damaged?
Does anyone know if there's any test runs planned for tomorrow?
If you can't see numbers on the outside, they must be on the inside!Is it just me that Find the numbers on these things? Saw 397003 at Leyland today only know it was that one because I asked on the forum...!
Where the hell are the numbers?! Even on photos I can't find them!
Also, note their vehicle numbers; 4710xx + 4720xx + 4730xx + 4740xx + 4750xx ('xx' being 01 to 12), which should help a bit further.If you can't see numbers on the outside, they must be on the inside!
The 5-digit series is basically full now, so, starting with the 387s, all new units have had 6-digit vehicle numbers; the CAF ones have also had a rudimentary EVN applied beneath the vehicle number (without things like spaces or a dash before the check digit).How come the six-digit carriage numbers? I thought individual carriages always had five-digit numbers - or am I behind the times?
That's because 397001 and 003 don't have set numbers applied yet although their nose end black panels differ so you can tell them apart from a distance. The black on the coupler cover on 001 is longer than on 003 (one end of 001 has no black on the coupler lid and obviously 003 has a grey nose at one end).
397004 does carry a set number just behind the cab door and as mentioned the last 2 digits of the vehicle number match the set number.
Indeed, the Voyager numbers are notoriously hard to spot.That makes sense then. Thought I was going blind or something. Getting 390/221 numbers has been hard enough, I thought these were even worse.
Lovely photos - the lighting is quite something. Thanks for posting!I finally got images of a Class 397 during a test run at Crewe yesterday
Photo taken through the front passenger door window of 0471003 at Carlisle 03/05/2019. None of the ballast weights seem to be secured in any coach and have now migrated from the seats to the aisle floor. It's to be hoped there's no accident! 397003 now has coach numbers applied.
I can't comment on that last but could it be that the ballast weights were too heavy for the seats to support so they were moved to the floor?I assume they didn't in fact fall on the floor, but were placed there to simulate a load of standees?
397001Hello is anyone privy to which 397 is currently sat opposite the main shed at Longsight please?
397001
