You see the high intensity headlight well before the yellow end, so no.
Not this old chestnut. :roll:
Summer heat haze, off the perfect straight, red zone working.
I'll have the yellow ends thanks.
Just don't cross a railway track.
Now please leave the enthusiast wibble talk behind and listen to those who work in the industry at a senior operational level who know about such things. :roll:
Oooooh! Get you!
Out on track much? :roll:
Every day that I work actually.
When the 185s were being put into the new livery, the plan was for the yellow ends to be REMOVED. This was shelved as the RSSB paperwork was not done in time before the order for vinyls was placed, hence the front ends remain yellow, same for the class 350 fleet.
I spent 9 years on the track, during that time the standards regarding headlights changed several times. By the time I was finishing the latest 66s were being delivered and the lights were super bright, visible well before yellow front ends.
The older stock, the yellow still warns before the headlights do.
But all this arguing about lights v yellow is quite petty.
With either, as long as you're in a position of safety 10 seconds before the train arrives what's the problem?
Don't know why I have to keep posting this.....
The NEW TPE fleets - ALL OF THEM - will NOT have yellow ends, including the locomotives.
Such is the way these days that with the headlights, the high intensity negates the yellow ends. Even the marker lights are bright. When the 185s were being put into the new livery, the plan was for the yellow ends to be REMOVED. This was shelved as the RSSB paperwork was not done in time before the order for vinyls was placed, hence the front ends remain yellow, same for the class 350 fleet.
On a dull day from a far distance you DO see the very bright lights of a 185 for example before you see the yellow end.
Attached picture is the TPE class 68 loco livery.
Having said earlier, heat haze, and not being on the straight, there's situational awareness.
In a time where safety standards are tightened, it goes against everything that's been delivered for on track safety, just so the designers don't have to paint the front end yellow. Removing it is petty, not complaining about it.
Like most countries, France doesn't have yellow front ends. Are we all dead ? No...
If the last line of defence between being dead or alive is down to an individual noticing yellow fronts or lights then something has gone tragically wrong.
Network Rail Scotland have banned unassisted red zone working. Basically, you can not work as an IWA in Scotland without some form of protection.
The new kit lookouts have now where they can be positioned out of sight of the work group and give a warning via radio means they don't have to rely on yellow fronts or lights. Just when they see a train coming.
And as ever, lineside environments continue to be part of the risk assessment for the Safe System of Work. If due to heat haze the required sighting distance of oncoming trains can not be met satisfactorily, then the work is suspended or move up the hierarchy of Green zone working.
When I was first trackside I enjoyed the freedom of just nipping on to the track to do a job, relying solely on looking up every 5 seconds. During my time Health and safety (rightly) kicked in. Then paperwork dictated when and how I went trackside.
headlight standards are improving to increase visibility, but safe systems of work standards are tightening to avoid working 'red zone' without lookouts.
Silliest question i may ask but how many 68's are expected into tpe livery?
Are there plans to use these on the Glasgow Central TPE services in place of the current multiple units?
Those services are going over to the 397s IIRC.
I've no idea how the 397s are going to actually pan out, other than the few artist impressions that exist. Although they don't necessarily replicate the actual final designs by CAF (Crossrail's a fine example of this), they do look a bit commuterish given they are serving Intercity routes to Edinburgh and Glasgow.
I may be wrong, of course.
It's an interesting point you've made, because I've seen at least three different artist impressions of the new CAF stock for Northern, in each one the front end design has changed. Personally, I'm not going to cast too much of an opinion until we see a photograph of the real thing, which won't be all that long now.
If you think we'll be seeing a photograph of the 397s anytime soon, knowing CAF, I wouldn't get your hopes up.
