TPE Nova 1 Class 802/2 Progress
I agree about Chat Moss, most of the way from Manchester to Newton-le-Willows is 75mph, with a 60 mph limit at the Glazebury level Crossing. The lack of line speed increases is probably due to the boggy nature of the Chat Moss route increasing the likelihood of subsidence, hence the use of Goalpost portals for the OHLE. In the height of austerity there likely wasn't enough funding to upgrade the line speed and signalling.
Its a shame as the line is as straight as the ECML north of York, so a 125 mph line speed limit could otherwise have been implemented which the 802s could take advantage of.
That's not quite right.
Before electrification the line speed on the Chat Moss route was 75mph throughout, except a tedious 2-mile section of 60mph from Astley eastwards to the M60 bridge.
90mph is now allowed west of Astley as far as Broad Green, and the 60mph at Astley has been reduced to a few hundred yards, so there is more 75mph running here.
Other problems are the junctions at Parkside and Earlestown, and catching up the various stoppers en route.
The 4-track Huyton-Roby section is very useful for overtaking at times, but it's a pity it was not extended further west (the M62 encroaches at Broad Green).
It is a little surprising that 100mph was not specified rather than 90mph, with all the trains now capable of that.
I get that some of the diagrams start at Doncaster Carr and Craigentinny but most of the diagrams start at Heaton or Edge Hill.
Who does the maintenance of these units at Edge Hill and Heaton? Is that Hitachi or is it contracted to some other business?
Alstom do the light maintenance of the 802s on behalf of Hitachi at Edge Hill.
When Avanti get some class 80x trains for the WCML they will also be maintained by Alstom at Wolverhampton, again for Hitachi.
Don't know about Heaton.
greyman42
14 Aug 2017
I saw a 802 heading north from York at 1430 on diesel. Was this a one off or was there a reason?
There are more power supply limitations for TPE on Sundays than weekdays, because LNER have extra trains on the Newcastle and Edinburgh route. So as explained in the track access application some TPE services are not able to use electric power between Dalton and Aycliffe neutral sections.
So you’d expect them to leave York on diesel as per earlier discussions as they won’t want to changeover when on the move.
8J
31 Aug 2009
Hitatchi actually have a number fitters who are based at Edge Hill and do some limited light maintenence. They aren't able to do much more as Alstom want a small fortune off them to use the shed at Edge Hill for under unit work in a pit.
3973EXL
2 Feb 2017
5Q90/X90 to Eastleigh running today.
Started Doncaster vice Heaton.
802218
Scotrail88
21 Jul 2014
With the reduced services on the ECML - are the limited services to Newcastle and Edinburgh now using electric power throughout?
surely sufficient availability during this time?
_toommm_
8 Jul 2017
One thing I’ve wondered recently:
The door release seems incredibly quick on these. Does the driver release the doos, a-la CrossCountry Voyagers?
PennineSuperb
8 Jun 2018
Yes, under normal working the Driver opens the train doors, and the Guard closes them, however unlike XC full door control is availabile to the Guard at all times and there is no '10 Bell Dispatch'
Photo of Guards Door Controls attached.
_toommm_
8 Jul 2017
Thanks for that. So the process is that the driver opens, guard steps out. Guard shutsall doors apart from local, shuts local then gives two on the bell?
Is that the same with the rest of the 80x family do you know?
TheAlbanach_
1 Jul 2017
Isn’t that a 395 panel? Or is the TPE 802s different from 801/800?
PennineSuperb
8 Jun 2018
Sorry, wrong thread! Thought this was the Mk5A thread.
But yes principle is the same on an 802, Driver Release, Conductor Close.
80X's have 3 set up modes,
DOO - Driver Open, Driver Close
DGO-D - Driver Open, Conductor Close
DGO-G - Conductor Open, Conductor Close
The Guard has to be 'given' door control via the Driver under DGO-G to ensure that the MSDO (Manual Selective Door Opening) is correct on the TMS (Train Management System.) Once they have checked the TMS shows the correct door pattern, they press a 'Train Door Control' button, which hands door control to the Guard.
Under DGO-D the Train Door Control is automatically given to the Guard once a door release is given.
Once the train doors and the local door has been closed by a Guard, they have no control over the doors and must ring the Driver to request door control.
sjm77
8 Jan 2020
Manchester
Is the remaining few hundred yards of 60mph at Astley simply because of the precarious nature of the level crossing with car drivers opening and closing the road* gates themselves?
*road might be a stretch, it is essentially a busy farm track!
61653 HTAFC
18 Dec 2012
Another planet...
Nope.
All TPE.
Shall post the times on here tomorrow.
Sorry, I meant are the tests taking place on behalf of Avanti- obviously the units are TPE because the Avanti ones don't exist yet.
If it's just being done for TPE, it will at least allow 802s to fill in for 397s, which will be handy if the power is off.
1 Feb 2019
From the beginning of the second line in your comment. Until the number 397 is right... :o
