Track query
devon_metro
11 Oct 2005
I noticed that the sleepers in this picture look different as they are metal. Is this a new type of sleeper with different clips that connect the rail to it?
4 Nov 2005
Parkstone
they use track like that on the freight only line from bicester to calvert
Bill EWS
10 Feb 2006
Didcot
Hi,
Metal sleepers were around in B.R. days but were not not liked and were used very sparingly and not usually replaced with the same. The privatised railway has taken them on in a big way, no doubt because they are cheaper and they can cover larger areas of relayed railway a lot quicker. But whether they are more economical than the standard concrete sleepers, in the long run, is a debatable issue that only time will tell. You probably travel over many miles of them these days, not only on freight lines but once the ballast is layed you don't always realise you are running over these type of sleeper unless you really look for them.
Perhaps a more modern design and metal mix may improve them compared to previous makes but that would only be a guess.
Regards.
Bill EWS.
Aureol
29 Sep 2005
With a spanner in hand in D212's engine room
The Settle & Carlisle line has steel sleepers laid on a very vast majority of the route and is going to be closed for a lot of this year due to track bed renewal, as the ballast is the wrong stuff!:lol:
If anyone's planning on traveling over the S&C this year, I would advise them to check the possession dates in advance to avoid disappointment.
Nick W
5 Nov 2005
Cambridge
Is there any side effects of using metal sleepers such as less smooth journeys, more vibration and problems with expansion?
66526
9 Nov 2005
There are metal sleepers on the freight connection onto Joan croft jctn coming from S****horpe! Regarding Nick... Bugger! :(
Nick W
5 Nov 2005
Cambridge
As noticed by Yorkie, the East Suffolk line has concrete wood and steel.
David
9 Jul 2005
Scunthorpe
uktrain225 said:
steel sleeper is rarely to bee seen!
You can see steel sleepers. Just look out for the rust coloured ones when you are next on a train. Also, you can't miss the loud noise they make when you're passing over them....
By the way, welcome to the forum.
