Trackside cabinet question
sutty
15 Feb 2011
Hi,
Every time I pass through Smethwick Galton Bridge (Lower Level) I often wonder something, but I'm too slow on the uptake to get my camera out. There are a number of cabinets with what looks like a speaker or horn on top of them.
Why would a cabinet need a horn? I've never heard them sounding when I've gone past on a train with an open window.
Thanks,
A nosy commuter.
Railsigns
15 Feb 2010
It was a system that the signalman operated to alert the signalling technicians that their presence was required, should they be out and about on the trackside. I've heard it called the "cuckoo".
civ-eng-jim
16 Jul 2011
Derby
Or it could be a Train Operated Warning System (TOWS) which is linked to the signalling system and, when switched on, alerts track workers to an approaching train.
Trog
30 Oct 2009
In Retirement.
If it is a big trumpet shaped speaker it will be a cuckoo, there used to be three different notes played depending on which of the three engineering departments the signalman wanted to speak to.
carriageline
11 Jan 2012
We have one on a LOC behind a box I sign, always wondered what it was for! Although, surely that's a strange place to put one?
Sent from my iPhone using Tapatalk
sutty
15 Feb 2011
Brilliant. Thanks for the video, emblematic and everybody else for your replies!
Is it just that there's no financial need to remove it where I've seen it, or is it still in use? Now I've watched that video the sound is very familiar. Maybe something as a child I thought was a level crossing sound.
MarkyT
20 May 2012
Torbay
I doubt it's still in regular use with modern communication methods available, although radio coverage in the station and tunnels might be patchy so it just might have been retained operational as a backup perhaps? If out of use the external fittings would probably not be removed unless they were causing other problems. If removed from cabinet mountings the sounders might leave behind holes that would need to be plugged for instance. Circuit fuses may be removed, and wiring disconnected further at various points, but is often not stripped out entirely from old trunking where pulling it out might cause damage to other circuits. Any unterminated wire ends left loose in wire runs should be properly insulated with crimped end caps.
sutty
15 Feb 2011
That makes a lot of sense. Lots of details I hadn't thought of.
