I think the question was possibly also about the wider ‘tube’ network, outside the tunnels, where LU still tend to use their typical higher level brackets. I think they also have many areas with a continuous air supply with pipes carried on the same support system. I suppose it’s likely they continued what started underground for standardisation, but it’s also possible some of their formations are a lot narrower.All cables associated with tube lines obviously have to be carried within the tunnel. These include signalling, communication and power supply - both traction and lighting etc. By putting them at the side of the tunnel they are easily available for installation and maintenance/replacement.
On surface lines, because the cables are at ground level, they are not so obvious to passengers, unlike the old telegraph posts and wires once familiar alongside railway lines.
used to be pneumatic. dont know if they have gone electric. How many lines have them still? must be redundant with ATO. Vic line never had themDo the trainstops need air pressure?
True, but I suspect the cost of deliberately changing over to Fibre Optics and lighter cables would far outweigh any savings; best wait until a cable has to be replaced? And with all the supports there and available I don't suppose they need to look at alternatives.How much cabling is needed nowadays. A fibre optic can carry tons of data so can connect up most kit. OK point machines use a lot of juice, but LED signalling must use very little. so any power cables could be smaller
I would have thought cable theft of valuable copper would drive replacementTrue, but I suspect the cost of deliberately changing over to Fibre Optics and lighter cables would far outweigh any savings; best wait until a cable has to be replaced? And with all the supports there and available I don't suppose they need to look at alternatives.
I am aware of theft of copper cables from surface lines, but haven't heard anything about thefts from tube tunnels! But on rereading the OP's original post were they talking about tunnels or open-air sections?I would have thought cable theft of valuable copper would drive replacement
BR used to be covered in heavy cables hanging on metal brackets on short concrete posts. Can't say I have noticed any recently, it seems to have all gone with modernisation.Alongside tube tracks there are many cables in racks, usually neat but also ugly. You don’t see this in BR tracks. Do tube trains need more cabling or is it just hidden?
On Tube lines the only place available for cables and other services is on hangers about half way up the side of the bore, I suspect this is also true of the sub-surface lines where the chess is used for drainage. LU also route cross track cables on bridges rather than under track crossings. Why use cable hangers rather than cable troughs, I have no idea of the history but it probably goes back to Victorian times.This then leaves signalling and communications cables - again it’s simply LU practice to route them above ground. Maybe LU is less vulnerable to vandalism with their lines generally always having being well fenced?
Compressed air on LU is used by the signalling systems for several purposes. Until the early 1990’s most if not all points were air operated (I once found the original 1912 drawings at Westinghouse, the design has not changed much). The mechanism is placed between the rails, i.e. in the 4 foot, the only option in Tube tunnels. They are also much faster to operated, about 1 second vs. 4 seconds for an electrical machine. Even here LU are moving away from air operation, the Westinghouse Surelock machine being low profile and mounted in the 4 foot, they can be stripped down in situ and rebuilt in 10 minutes.Yes I meant the outside the tunnels sections. These racks are several feet high and always well populated with many cables. What was the compressed air for?
