Southern Dvr
- Joined
- 13 Oct 2010
- Messages
- 876
Because Christmas 2020 is a long time to wait and that’s the sort of speed RAIB work at!
Do you not get a printout of lates when you book on? They don't go on our notice case as such, just the printouts, (and presumably tablets for a lot of other TOC's and FOC's) We had some ESRs at Euston without daleks and warning boards in the past (due to being near the old rathole at Camden just outside) but even then we had it on the lates notices just to warn us so we weren't ringing up Wembley Mainline to say the boards were missing .
Nothing, nil, zero. The only area on all of swr metal where we get advanced written or electronic screen notice (1screen in signing on area) is for esr between Waterloo and Clapham jnc as temporary aws magnets aren't laid there probably because of so many signals and some being quite close. All boards are laid out however.
As others have said , if it is esr being imposed burning laid out yet, then stopped and cautioned.
We use to have all esr in written form in late notice case but most depots now don't have a 24/7 presence to post them in good time, so they were done away with a number of years ago.
Tsrs obviously posted in won
The RAIB have now issued an Urgent Safety Advice bulletin about this issue...
https://www.gov.uk/government/publi...ign=govuk-notifications&utm_content=immediate
It'll be interesting to see what action is taken following the Urgent Safety Advice. Either we will get stopped and cautioned for every TSR, in which case the timetable is now meaningless. Or, being optimistic will GSM-R be used to send nice berth triggered messages warning about ESRs?
RAIB said:Marker boards and associated automatic warning system (AWS) magnets were in place to provide warning of the emergency speed restriction and denote where the restriction commenced and terminated. However, the driver of the train had not received any notification of the existence of the emergency speed restriction prior to the journey.
RAIB said:The RAIB’s preliminary examination found that the requirement to issue information about ESRs to drivers was removed from the railway rule book in 2008.
and
are very worrying statements! The Swiss Cheese model mentioned above is starting to line up.............
https://www.gov.uk/government/publi...ver-awareness-of-emergency-speed-restrictions
PS - how is a driver expected to find this information? I guess the late notice case is a thing of the past ( perhaps no clerk to "run" it these days) but are you given some kind of Ipad with a pdf notice?
Print offs of late notices, like what we get at VT everytime we book on. (Or via tablets); I honestly thought everyone received late notices
and
We still have physical Late notice cases kept up-to-date date by some guards and drivers who are appointed leading crew, but they don't have fixed presence. We do have an electronic notice case to supplement this. However esr haven't been posted in either for years WAT-CLJ.
Print offs of late notices, like what we get at VT everytime we book on. (Or via tablets); I honestly thought everyone received late notices .And they're not as numerous as you think. Ours tend to be one or two A4 sheets with esr's and maybe a bit of info eg. about broken TASS balises, temp closed platforms to us, and at this time of year, untreated RHTT sites)
So how do you know the information shown in the case is up to date? If no one tells you how do you find out about an ESR? Sorry for asking but this seems like a really big gap.
I think I've explained upthread already. Essentially (like the lner incident ) won't know until we get the first warning magnet when driving. The main thing the LNC gets used for is advise of power reduction and if that is newly introduced then we'll get some sort of live or recorded advice from The appropriate signaller.
cheers - I assume the magnet is positioned in such a way that you are given adequate time to bring the speed down to a suitable level before the ESR? Personally I think you should be given more notice and the older system seems a sensible and easy way of doing that
As the others have said since you asked, yes it should be sufficient time. NR have guidelines/formula for setting out ESRs based on the line speed and restriction speed and the braking capability of the all the train types that are route cleared for the line.cheers - I assume the magnet is positioned in such a way that you are given adequate time to bring the speed down to a suitable level before the ESR? Personally I think you should be given more notice and the older system seems a sensible and easy way of doing that
A train driver who sped through a 20mph (32km/h) zone at 121mph (194km/h) was distracted as he grasped for medication for an illness.
The driver missed two speed restriction warning signs, according to the Rail Accident Investigation Branch (RAIB).
An emergency limit was set at Sandy South Junction, Bedfordshire, after a crack was found on a set of points the day before the journey, on October 19.
When he finally noticed, it was too late to reduce his speed completely.
The RAIB also said a failure by London and North Eastern Railway (LNER) to notify drivers of emergency restrictions prior to their journey was a contributing factor.
Always a risk
The driver told investigators he began to feel worse as the train got closer to Sandy and he did not notice the first warning sign.
He then misunderstood a second warning and thought it did not apply to his train.
The RAIB warned that although there was no accident on this occasion, there was always a risk when trains do not comply with speed restrictions.
No-one was injured as a result of the speeding and the LNER service from Aberdeen made it to London King's Cross safely.
The report stated it was also possible the driver missed the first warning sign because of issues with its visibility.
LNER now warns all its drivers of any speed restrictions on their routes following recommendations by the RAIB.
85 The requirement to provide drivers with details of emergency speed restrictions before the beginning of their journey was removed from the rule book without adequate consideration of the risk associated with this change, and this has led to inconsistency between train operating companies in the information they provide to drivers.
86 In March 2007, a freight operator challenged the requirement in the rule book (see paragraph 47) to issue notices to drivers regarding emergency speed restrictions, stating that the practice was costing it around £60,000 each year, and that the lineside warning equipment was sufficient to notify drivers of the restrictions and to give them time to bring the train down to the required speed.
Summary of conclusions
Summary of conclusions Immediate cause
95 The driver did not reduce the train’s speed to 20 mph (32 km/h) in response to the emergency speed restriction (paragraph 49).
Causal factors
96 The causal factors were:
a. The driver was distracted due to both a medical condition and searching for paracetamol in his bag, so was not paying full attention to the line (paragraphs 53 and 63, Recommendations 4 and 5).
b. The driver did not respond to the ESI board, and then mis-interpreted the warning board (paragraph 64, Recommendation 3).
c. LNER did not provide drivers with notification of any emergency speed restrictions prior to them starting their journeys, following a change to the rule book in June 2008 (paragraph 78, Recommendations 1 and 2, Actions already taken, paragraph 99). Underlying factor
97 The underlying factor was:
a. The requirement to provide drivers with details of emergency speed restrictions before the beginning of a journey was removed from the rule book without adequate consideration of the risk associated with this change, and this led to inconsistency between operating companies in the information they provide to drivers (paragraph 85, Recommendations 1, 2 and 5).
The full summary of conclusions:
I'm not adriver so won't comment on the distracted driver theme. But the TOC having not told the driver of a 105 mph speed reduction - choosing not to at that - is deeply concerning.
That is true.What difference does it make if it's 105MPH or 10MPH difference? The ESR warnings are put at a distance that the driver can slow to the correct speed in time safely. The driver missed these warnings through being distracted, which should not ordinarily have happened.
The driver having so much to do, ordinarily, and yes -the driver did miss the warning.What difference does it make if it's 105MPH or 10MPH difference? The ESR warnings are put at a distance that the driver can slow to the correct speed in time safely. The driver missed these warnings through being distracted, which should not ordinarily have happened.
Yes - what 30907 said!That is true.
But distractions will happen and a belt-and-braces approach makes sense.
