Train driver Assesment
Discussion in 'Railway Jobs & Careers' started by WishIHadAName, 13 Feb 2018.
  1. WishIHadAName
    WishIHadAName Member
    17
    8 Jul 2015
    I heard from someone that the rules hace changed for the tests regarding the three strikes on the tests. He recons that when you first fail it you have to wait 6 month and then you can fail again and retake after a year as many times as you like? Is this a new rule or have they got it wrong?
  2. baz962
    baz962 Member
    885
    8 Jun 2017
    Unless very new it is wrong, i did them last june/july , it was six month wait if failed, only two strikes too.
  3. Rachael92
    Rachael92 Member
    12
    13 Feb 2018
    I recently had my assessment day a few weeks ago. Was informed on the day that if you fail you have to wait 6 months to reapply and that you only get 2 strikes.
  4. London 10101
    London 10101 Member
    36
    16 Jan 2018
    6 months to reapply for the same toc
    2 failures and your out
  5. baz962
    baz962 Member
    885
    8 Jun 2017
    If its psychometrics, six months for any toc.
  6. Mainline88
    Mainline88 Member
    14
    14 Feb 2018
    I only know it as two strikes and out. Must be a very new rule if not.
    Really if people have to keep doing the tests over and over to get a pass, the job may not be for them. There are a lot of rules and different traction out there to learn. Failing repeat tests will raise competency issues.
    The practice material is more then adequate to understand.
    Just don’t let nerves get the better of you on the day.
    Best of luck
  7. Sera
    Sera New Member
    2
    28 Nov 2017
    It should have been clear but still confuses me..
    I recently failed just on the last test for Arriva, called VSE. Since this is only an extra test for Arriva and Crossrail, do i have to wait 6 months for any other TOC application? Just wondering as if it was another TOC i would have been succesful and would have gone to the interview. Failing only to the specific arriva test and passing all the other tests should it make me waiting 6 months for any TOC?
    My other question is, is the two strikes and out only for the tests or it applies to the interview as well?
    Thanks! ;)
  8. baz962
    baz962 Member
    885
    8 Jun 2017
    The vse, will only count against any that use it. Its not part of the psychometrics , so you have full lives. If you fail it again then thats it for any tocs that require it. The mmi interview is two strikes, the dmi is not, although many people think if you fail a dmi with one company twice, they probably will not give you a third, but you can go elsewhere. That is just heresay , so could be wrong.
  9. Sera
    Sera New Member
    2
    28 Nov 2017
    Now is everything clear! Thanks for your very helpful response ;)
  10. London 10101
    London 10101 Member
    36
    16 Jan 2018
    Mt
    mtr told me in 2015 that 6 months for the same toc
  11. Mainline88
    Mainline88 Member
    14
    14 Feb 2018
    Deleted
  12. baz962
    baz962 Member
    885
    8 Jun 2017
    If you fail any part of the psychometrics its six months any toc, the opc tell you and almost all toc application forms state if you have failed any part of the train driver assessment within six months, you are unable to apply.
  13. theking
    theking Member
    203
    30 Sep 2011
    If you fail an element of the core train driver psychometric process.
    You CANNOT take any element of the psychometric assessment process again within 6 months.
    Even if you apply for every toc in the country.
    Even if you manage to get to the assessment centre when you answer YES to the question.
    Have you taken any part in the train driver assessment process within the last 6 months?
    And they search your name you will be asked to leave.
    Different tests e.g. DFFT or VSE have different rules as they're toc specific.
  14. Matt711
    Matt711 Member
    180
    22 Oct 2017
    If you passed to national, but failed to enhanced, OPC said you can apply to TOCS that only require national standard straight away, however if you want to go to a TOC that requires Enhanced, then the 6 months apply......
  15. Mainline88
    Mainline88 Member
    14
    14 Feb 2018
    Just for clarification,
    Is it still the case that each days assessment must be a pass for all tests?
    Failing one results in the entire day to be redone. Unless of course you pass all to a national standard, you can then retake the particular test of which an enhanced score is needed for the relevant TOC?
Share This Page
