D1009
Thanks, saves me having to get my track diagrams out!Yes, the overlaps foul each other, the reduced overlap route for arriving can only be used for four cars max else you foul the station throat.
OK thanks. That may explain why platform 3 is so little used. Is there a solution?Yes, the overlaps foul each other, the reduced overlap route for arriving can only be used for four cars max else you foul the station throat.
A despatcher cannot give the right of way to a train at Oxford Road's platform 4 under a single yellow; it has to be double yellow. This will, I assume, be part of the same signalling issue. Of course this line was never built to handle this volume of trains originating from as far away as Glasgow, Newcastle and Norwich.The Piccadilly P15/16 and Oxford Road platform project would have had to sort this out, as having trains alternating between the two platforms is pretty much unworkable otherwise.
Looks like a train proceeding on single yellow and stopped at the next signal could still be occupying the overlaps of the platform starters and thus forcing any train into either platform to use a warner route with a shorter overlap. Although I can't help thinking keeping the train in the platform in this situation would be worse.A despatcher cannot give the right of way to a train at Oxford Road's platform 4 under a single yellow; it has to be double yellow. This will, I assume, be part of the same signalling issue. Of course this line was never built to handle this volume of trains originating from as far away as Glasgow, Newcastle and Norwich.
What are you trying to solve? A lightly used platform can be a godsend in times of disruption, particularly one that can be used for turnbacks.OK thanks. That may explain why platform 3 is so little used. Is there a solution?
Pl. 3 is used for turnbacks, through freights and, as far as I can tell, just one regular through passenger working. Being able to use 3 and 4 at the same time, with trains proceeding to Piccadilly, would reduce the number of trains queuing back to Deansgate, but I guess they would then hit another bottleneck at Piccadilly, unless 13 and 14 took two trains at the same time, which the signalling appears to allow.What are you trying to solve? A lightly used platform can be a godsend in times of disruption, particularly one that can be used for turnbacks.
This is an area ive been working within during my current work within network rail.
Know as Docking, large stations have a booked platform docker. Where allocated platforms, splits or units, on top stabling etc are put into an expanded timetable document. This is currently handled by Central train planning at Milton Keynes.
My current work has been to make the midweek Edinburgh Waverley docking plan rotational to leave half the station clear of trains overnight (North Monday/Wednesday, South Tuesday/Thursday) effectively doubling the number of dockers for the station with one working MWO and the other TThO. This document is currently at Milton Keynes for verification before coming in as part of the December timetable change. The net result being a net increase from 100 minutes max possible in a small area block to a total 1/2 station block of 240 minutes each night Monday to Thursday delivering a 16 hour increase on current booked access levels (5 hours Saturday night only with trains stabled in possession)
Adhoc changes often apply at medium sized stations. An example I'm working with on the increased access and through diagramming front is perth where unit positions depend on the arrival order and scotrail control allocations for the following morning. The long term plan is to through diagram perth with clear platform options for maintenance overnight.
Glasgow Central and Inverness are the next places to follow the Waverley model with different splitting with Glasgow Central going to a 3/4 block rotation and Inverness awaiting confirmation of track modification projects.
The key aim is to allow the aligning of blockage access to the working timetable allowing a modal shift from red zone working and 'turn up and ask' blockages to a national access timetable removing the overly complex track access systems currently in use with overall benefits of productivity increase, better defect cover and reductions in backlog, aimed towards TPM style maintenance and inspection.
Hope that elaborates on platform allocations and how tweaking them can help with unseen things.
