LOL The Irony
The toilet.What is that 'extension' on the gangway end of the furthest two seats?
Perching point, much like the ones in 378s, for example:What is that 'extension' on the gangway end of the furthest two seats?
Virgin Standard Class Seats:
(not my image)
Found in: 220, 221 & 390's
Pros: Not half bad, okay padding & aren't as bad as they look.
Cons: Not as comfortable over long distances (God help anyone on Euston - Glasgow), legroom is a little tight, too narrow & bad footroom.
MY RATING: 5/10
5/10 seems a bit generous. I’ve used pendolinos a couple of times from MKC to Euston (35mins) and both times I’ve been so glad to get off you have NO IDEA. I think that the Pendo seats look better than they actually are, not had any problems with legroom though, it’s in the sweet spot for me where it’s cosy but not chlostrophobic (but I’m like 5’4”). Both times I’ve used 390s I’ve used a GA Mk3 set straight afterwards, oh IC70s are simply heavenly, shame they’re only used on 2hr journeys max. Class 390 seats are, and I will say this with confidence, many leagues below the compins in 375s, and I’m including the later ones with less padding, which I get all the time for the hour journey into London way to often. There’s just something about the 390 seats, I think I’ve pinned it down, but I’m not sure, and it’s that the contouring on the lower back is way too extreme and bites in to the most sensitive part of my (already hypersensitive) back, and no other seat does that.
These are the original seats so are probably a BR design. Don't know the name though.Evening all,
Right I'm trying to work out what the seating that is fitted to some Northern 158s (including the 158/9s) and the GWR 158s (maybe also the SWR ones). Its the high back seating (original maybe). In a couple of places I've found it referred to as Richmond seating but I'm more familiar with Richmond being more rounded/thinner (but I realise that seating types can vary). It's this seating https://www.flickr.com/photos/sboot...iW-HoNo9B-VEEr2Y-VkcZAm-VkcZ8h-T21gBy-LQRwhi/
If anyone could please identify which seating this, it would be much appreciated
Many thanks,
Sam.
Those seats are being used on the Northen Class 158, 195 and 331.View attachment 51482 Does anyone know which type of seats are used in the GA refurbished 321s, I haven’t seen them anywhere else.
No it is not, it is the Compin ones that look like the 377 seats.Class 333 is Fainsa.
Nope.No it is not, it is the Compin ones that look like the 377 seats.
I'm not sure what the name for them is but they're only used on Networkers, Turbos and 323s, which would suggest that it is a British Rail design of some sort, probably a follow on to the Ashbourne design.
They are quantum seats. They are also used on Northern's refurbished 158 and the new 195 trains rolling out to the network.View attachment 51482 Does anyone know which type of seats are used in the GA refurbished 321s, I haven’t seen them anywhere else.
Northern is using Fainsa. So far, the only other use of the (superior) Quantum seat will be on Vivarail 230s.They are quantum seats. They are also used on Northern's refurbished 158 and the new 195 trains rolling out to the network.
No, Northern are using Fainsa.No Northern are really using them cause they are wider and they have more padding
Quantum is no wider than Fainsa. Fainsa seats can be made with deeper, contoured cushions and armrests, but it's still the same seat.No Northern are really using them cause they are wider and they have more padding
A little off-topic, but were Compins seats also in Wessex Trains Class 158s?
Yes, at least one unit received such an interior.A little off-topic, but were Compins seats also in Wessex Trains Class 158s?
Did anyone ever get a picture of them?
I must agree.Seemingly so https://www.flickr.com/photos/rpmarks/8508850134. A big shame this was taken out in favour of Richmond seats and more recently the original 158-type seats.
Probably the biggest downgrade in train refurbishment history if you ask me!I recently did the Carlisle to Leeds on a refurbished 158 with the new seats. They are terrible considering the duration of the journey. The old seats were considerably comfier.
I recently tried them and while admittedly they are a bit firm, they're actually not as bad as many people say they are but that's probably cos I haven't been on it for long enough (Newport to Cardiff Central is pretty short) - at least the legroom is generous!The Azuma seats are very hard
