Train/Tractor accident near Knaresborough, North Yorks
Discussion in 'UK Railway Discussion' started by David Dunning, 14 May 2015.
Thread Status:
  1. David Dunning
    David Dunning Member
    182
    27 Oct 2009
    York
    Train and Tractor collision at Flaxby near Knaresborough this evening.
    More details here http://www.minsterfm.com/news/local/1614637/updated-train-and-tractor-collision-near-knaresborough/
    Rail Forums
  3. Adam0984
    Adam0984 Member
    523
    18 Feb 2014
  4. rebmcr
    rebmcr Established Member
    2,541
    15 Nov 2011
    That 150 seems to have fared exceptionally well, compared to the heavy machinery it demolished!
  5. crispy1978
    crispy1978 Established Member
    1,037
    4 Feb 2013
    Scarborough
    The pictures look horrendous.
    Very lucky there hasn't been a serious injury or fatality - the tractor is an absolute mess.
    150225 is the train involved.
  6. 455driver
    455driver On Moderation
    11,332
    10 May 2010
    both big bits of the tractor look fine, they are just not attached to each other!
    I wonder how this occurred?
    Actually I have got a pretty good idea! :roll:
  7. SamS
    SamS Member
    66
    25 Oct 2013
    York
  8. tsr
    tsr Established Member
    6,900
    15 Nov 2011
    Ballast
  9. class 9
    class 9 Member
    279
    18 Nov 2010
    Alas, farm crossings do have telephones and some have the miniature red/green warning lights, but the railway has a constant battle to make the users of these crossings use them correctly(and therefore safely).
  10. SamS
    SamS Member
    66
    25 Oct 2013
    York
    The only lights I can see are in the distance, which I assumed was the train.
  11. Bantamzen
    Bantamzen Established Member
    2,042
    4 Dec 2013
    Baildon, West Yorkshire
    If you look to the right of the picture, over the front of the trailer you can just make out a set of lights which appear to be at red.
  12. edwin_m
    edwin_m Veteran Member
    13,222
    As usual, a number of causes are possible and we will see the report in due course.
    Glad nobody was seriously injured, and I hope the unit is quickly repairable. Despite the arrival of 319s Northern is still short of DMUs.
  13. sbt
    sbt Member
    262
    12 Oct 2011
    There are also other reasons that accidents happen at these crossings. Some of them are down to 'the railway', some down to a combination of fault and some down to 'happenstance'.
    Its rare for a RAIB report into incidents at User Worked Crossings not to have at least a 'Learning Point' for NR, even in cases where misuse was the major factor. Sometimes those recommendations or learning points relate to the conduct of that 'constant battle'. In other cases the RAIB has commented on the tendency to automatically assign blame to the crossing user and therefore take no action on issues that are down to 'the railway'.
    Indeed. Looking at the photos and having read every report the RAIB has ever put out I'm pretty sure about some key features of the accident. I will wait for the RAIB report before commenting further however.
  14. lincolnshire
    lincolnshire Member
    745
    12 Jun 2011
    Oakwood farm Level crossing used to be Miniature Red And Green warning light crossing with phone line direct to local signal Box, might have changed as been a good while since I last went passed as see we now have p.v panels there now.
    Years ago if you passed both on train and road the gates was often left open if you looked across as gates open away from railway.
    Just have to see what has happened when the inquiry is over .
  15. sbt
    sbt Member
    262
    12 Oct 2011
    Ok, straightaway I break my own intention.
    New photos show miniature lights at this crossing clearly.
    Google Earth photo, just a 'point in time' and possibly from 'years ago' appears to show gates open and no vehicle around, which backs up your statement about your experience of the usual state of the gates.
    <thinks> Side looking cameras on the NMT to record state of UWC gates and trigger action to encourage compliance if required? Similar checking if an aerial survey is done (are they done?) </ thinks>
  16. darloscott
    darloscott Member
    254
    12 Dec 2013
    Stockton
    There was a double 150 set outside Neville Hill this morning, presumably these two involved in this incident
  17. g8bvl
    g8bvl New Member
    2
    4 Apr 2015
    Should this happen to be an occupational crossing the farmer petitioned to have electric gates installed to negate leaving their vehicle, I trust they will be delt with proportionately, mindblowing disregard for public safety
  18. Anvil1984
    Anvil1984 Established Member
    1,140
    28 Aug 2010
    Was it Oakwood Farm? When I was at York you were cautioned regularly at that crossing as the owner of the adjacent land refused to close gate
  19. snowball
    snowball Established Member
    4,598
    4 Mar 2013
Thread Status:
Share This Page
