Trainee Train Driver Waterloo (012551)
Discussion in 'Railway Jobs & Careers' started by snakeydave24, 14 Feb 2020.
  1. snakeydave24
    snakeydave24 Member
    8
    25 Apr 2019
    So, did anyone manage to apply for this in time? came up and disappeared very quickly, and even more annoyingly I didn't receive a job alert email for it even though I am set up too :(
    Rail Forums
  3. venom ivv
    venom ivv Member
    7
    22 Nov 2019
    acton
    When did it get posted ?
  4. DunfordBridge
    DunfordBridge Member
    440
    13 Apr 2013
    Scarborough
  5. snakeydave24
    snakeydave24 Member
    8
    25 Apr 2019
    Already got a no today, quickest one so far :rolleyes:
  6. DA1
    DA1 Member
    87
    22 May 2017
    Kent
    Did you manage to apply for it in the end then? Was the no after you completed the online test?
  7. Stigy
    Stigy Established Member
    3,262
    6 Nov 2009
    As far as I was aware there’s only a national standard on the coordination test?
  8. DunfordBridge
    440
    13 Apr 2013
    Scarborough
    I thought that too until last week and it probably is the case with the majority of operators with Transpennine being one of the few exceptions, but who knows.
    How many trains do you know that are controlled by joysticks? Most of the levers in the cab tend to be notched in any case.
  9. Stigy
    3,262
    6 Nov 2009
    True, but it’s about coordination, so I guess it’s irrelevant how trains are actually controlled. You have to be able to potentially reset/press etc any or all safety devices at once. Plus some trains have a lever/handle for the brake, and one for the throttle, so you need to demonstrate you’re not massively limited in terms of simultaneous movements of both hands.
    It does seem a silly test to have enhanced standards for, as you generally either have the coordination or you don’t.
    Edit: Are you saying it was Transpeninne you took the assessments with before? As SWR almost certainly only use standard passes.
  10. DunfordBridge
    440
    13 Apr 2013
    Scarborough
    That is where I preferred the old DTG test with the coloured circles and tones where you had to press buttons and pedals. Strictly speaking, if you make a brake movement first, the DVD will not sound and need to be cancelled with the DSD. Think I would try to plan my driving so the brake was applied before I crossed the AWS magnet.
    With regard to the enhanced joystick test, I can only imagine that it is a way to keep the numbers manageable, in terms of applicants.
  11. Stigy
    3,262
    6 Nov 2009
    Without wanting to go too far off topic; It’s often not necessary to brake before an AWS magnet depending on the section/circumstances etc. And with the best will in the world, sometimes the DVD sounds before the driver has made any brake/throttle movement in the last 60 seconds or so :E
    I have only done the coordination test on the newer style with the joysticks, and found it’s not about keeping within the lines specifically, but rather have quickly/accurately you get ‘back on track’ when you do stray. It’s deliberately not a great set up as it’s unnatural for one joystick only to move back and fourth and the other left and right. No matter how much Forza you play (or Train Simulator depending on your outlook on life :lol:).
  12. DunfordBridge
    440
    13 Apr 2013
    Scarborough
    I know the DVD sounds pretty often between Scarborough and York where the limit is 70 for miles on end. Do not even know what Forza is, something to do with music maybe?
  13. TBDDesiro
    TBDDesiro Member
    31
    14 Jul 2019
    Applied, did assessment and said I’ve been successful, still waiting for any further news.
  14. DA1
    DA1 Member
    87
    22 May 2017
    Kent
    Applied the other day and been offered an interview for this week.
  15. MDCW
    MDCW Member
    63
    19 Nov 2017
    You must be on your 2nd attempt then. What do you have left to do? Just MMI & DMI?
  16. DA1
    DA1 Member
    87
    22 May 2017
    Kent
    Nope, this is the first time I’ve applied for SWR and I’ve already passed the assessments with another TOC so I’m assuming this is a DMI.
  17. MDCW
    MDCW Member
    63
    19 Nov 2017
    Guess it is is you have passed MMI Good luck!
  18. TBDDesiro
    TBDDesiro Member
    31
    14 Jul 2019
    good luck!
  19. DA1
    DA1 Member
    87
    22 May 2017
    Kent
    Thank you both!
  20. TBDDesiro
    TBDDesiro Member
    31
    14 Jul 2019
    Got an invite to Assessments, is the MMI and/or DMI on the same day?
  21. Twotwo
    Twotwo Member
    345
    10 Aug 2018
    What did the email invite state?
  22. TBDDesiro
    TBDDesiro Member
    31
    14 Jul 2019
    It didn’t state anything about Interviews so I’m assuming not but it did state the following assessments:
    TRP, Group Bourdon, TEA-Occ, WAFV, ATAVT, WCT, 2Hand, Colour Vision.
Share This Page
