Transfer of TPE 350/4s to West Midlands Trains (LNR)
samuelmorris
18 Jul 2013
Brentwood, Essex
The contract incentivises a very low failure rate hence that is what is delivered.
When maintenance is done in house by TOCs (much more common for Bombardier) the TOC can chose what is the most economically sensible optimisation of maintenance. Southern have much greater freedom over unit mileage than SWT/SWR due to the nature of the contracts.
The manufacturer maintenance contracts also have lower unit utilisation levels to allow more time for maintenance so you end up needing slightly more units than the in-house approach.
Manufacturer maintenance contract margins are very much in operators crosshairs across Europe at the moment as that is the most obvious "fat" that can easily be trimmed to lean the overall system costs.
But presumably if it leads to lower fleet reliability then it has a negative effect on the service ultimately delivered?
hwl
5 Feb 2012
Yep but there is a cost optimisation.
The way failure metrics are calculated on a distance/ time between failures mean that above a certain level (say MTIN of 50,000) there is very little gain in actual reliability in practice given the occurrence of other delay reasons and money can be better spent elsewhere.
Coupling issues e.g. joining and splitting in service are a major source of "delay" incidents so reducing joining/splitting on route or having large allowances for it to happen in termini can also effect failure rates.
samuelmorris
18 Jul 2013
Brentwood, Essex
Presumably though that's all part of MTIN as if a unit failed to couple with another that would create a TIN, therefore reducing the number of times units couple would be another means of increasing the MTIN without adjusting maintenance schedules.
hwl
5 Feb 2012
Precisely hence the SWT practice of all day unit coupling where possible.
Allowing lots of time in termini for joining allow for several attempts if needed without causing a delay.
Basically the stats can be managed to certain extent to comparison should be done with care, it is the detail that matters in practice.
If most of the issues can be resolved in the 3-6 minute time scale the impact may not be that large in practice (e.g. lots of 700 and 345 issues fall into this bracket) as the shape of the delay curve matters.
worth having a look at this thread for some MTIN background:
https://www.railforums.co.uk/threads/how-is-mtin-calculated.87260/
F Great Eastern
2 Apr 2009
East Anglia
The Siemens maintenance contracts are very expensive and you end up paying for a level of maintenance that may not be worth it.
Well the fact that Siemens units are constantly winning Golden Spanners left right and centre for the last decade and often taking up the top few positions all to themselves suggest that such contracts work.
Skimping on maintenance doesn't work out in the long run, go see any units that have had maintenance expenses cut back or have come off maintenance contracts and see their reliability fall in some cases quite dramatically and lots of short forms, which I'm sure people in this thread have experienced.
The difference between Bombardier's approach and Siemen's approach is reflected in the respective fleets that were born around the same time and their respective reliability figures. I understand that there are terms to these contracts, but they offer railways protection to ensure a certain availability of units or get compensation, the fact these were not around really when Alstom sold a load of questionable reliability stock is a real shame.
If we are really going to go down the road of keeping trains reliable is expensive so lets just not be bothered that much about it then there are seriously troubled times ahead for the railway, as the railwaymen a decade ago would never allow such things as these contracts were in part born out in the UK of the desire for operators to avoid issues experienced with various Alstom Fleets. The problem is the bid managers and theory knowners without any operational experience don't care.
You will find the bid managers and those who know the price and theory of everything and the practice of nothing have them in their crosshairs. The Railway engineers and the operations people who come from that background and know the reality and practice have a rather different opinion.
Generally the only time people claim figures are massages is when there side is losing, when their side is winning then suddenly the figures they cast doubt on the accuracy of suddenly become reliable.
Their was an intention to though it was only after given to tpe that it was changed to /4s
They were never ‘given’ to TPE. It was a case of piggy backing onto an existing LM contract which was already underway, but they were always ordered for TPE.
Likewise, they were never actually ‘sub-leased from LM’ despite it being regularly described that way in various forums...
RealTrains07
28 Feb 2019
Yes i know iam trying to say once the units were finished for tpe that it was changed to /4
anamyd
17 Aug 2018
I remember reading one of London Midland's own press releases not long ago saying that the order for the new 350s included units for First TransPennine Express!
That’s right. I think there was also a time that Southern were directed by DFT to add units that would go straight to another TOC. Basically acting as a bulk-buy agent...
Silverlinky
3 Feb 2012
350/2's to the MML for the new "local" service Corby-St Pancras.
Would be a great fit to go with the Drivers they will get from LNW, already signing the traction. (the recent recruitment drive for Kettering/Corby has attracted a fair amount of interest from Drivers at LNW who live over that way and are based at Northampton/Bletchley)
You mean there’s an advantage to be had at the recruitment stage if you can bring your own rolling stock? :)
samuelmorris
18 Jul 2013
Brentwood, Essex
That's my thread ;)
But thanks for the reminder, I had forgotten all about posting this...
Silverlinky
3 Feb 2012
Lol.....yeah why not!! They are after "about 40 drivers" and there are 37 units! One of two would have to go without their own personal mark 2 but i'm sure EMT could let that slide and not hold it against those unfortunate enough to miss out! :D:D:D:D
Bikeman78
26 Apr 2018
Is there any point replacing 318s dating from 1986 with 321s dating from 1990?
I wouldn't have thought so. The 318s and 320s work in multi and cross cover the diagrams. They all had a lot of money spent on them.
RealTrains07
28 Feb 2019
as have all units including the 350/2s it’s unfortunate that toc cant sell their own units since they dont get money back for investing in their trains
Wivenswold
24 Jul 2012
Essex
There's a strong rumour floating around that Corby will get the ex-GA 360s. If so, they're due a refurb and repaint anyway so there won't be too much training for LNW trains. They'll have a much better view too.
MatthewRead
21 Nov 2014
West london
360's are meant to be taking over those services.
Silverlinky
3 Feb 2012
350/2's will remain at LNW for longer than originally envisaged due to the delay in the 730 program.
12 month lease extension arrangement has been rumoured
Class 170101
1 Mar 2014
Nope, I was thinking of the 321/4s (ex WCML/ECML) that haven't yet been sent to Kilmarnock for conversion into Class 320/4s. The Renatus 321s have plenty life left in them yet, and I have an inkling they won't be bound for ScotRail after GA...
I think its been said elsewhere on this board that Class 321s were going to be used as a test bed for Hydro Flex?
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Yes and no; Eversholt/Alstom plan to use them for a "321 Breeze" project to power them with hydrogen fuel cells, however Porterbrook & the University of Birmingham beat them to it with the HydroFLEX 319 (now with the Class number 799).
bussnapperwm
18 May 2014
Would it be viable to convert the /2s to DC so they could then work with 444/450 stock in SWRland? Number them 451s?
59CosG95
18 Aug 2013
I've asked the question before, and the answer is no. They could be converted to DC, it's true, but where would you store 37 4-car units that are surplus to requirements? The biggest problem for me is the power supply down on the Wessex route, which is pretty much at bursting point...again.
