But if it is starting why has there been no announcement that the work is going ahead?
Platform 7 at Huddersfield used to be very short, possibly used for light engine awaiting a service?
Was it always that short or was it truncated to allow (now disused?) Signal building to be built?
Could defunct signalling building be demolished and platform 7 be reinstated or would it still be too short (or awkward for pathing) for Sheffield service?
The plan posted a couple of pages back showed 5 & 6 removed/filled in, with 2 being the only existing bay to survive. A new north/east facing full-length bay provided (along with a 4th through platform) on the site of the current stabling sidings.I like your thinking but I would demolish it, then move the waiting room, toilets and cafe they're in order to lengthen platforms 5 & 6.
Although isn't the aim for four through platforms ?
Parts of the island platform are grade 2* listed, but I'm not sure if the listing includes the signal box structure.
It's certainly possible... whether it's required or viable is another matter. The listing of various different aspects of the station complex is quite complicated:Is there any scope to remove and rebuild the listed structures once all the platforms have been reconfigured?
Thanks for the update and correction.According to the listing for the station building, it, the island platform building and the overall roof is grade 1 listed! As for the signal box they're is no mention of it although it will still require listed building consent due to its location. The wooden island buildings are specifically refereed to although NOT much is said about them.
"Buffet and Waiting Room between platforms 4 and 8 is a separate match-boarded structure with panelled pilasters, each taking paired brackets and cornice."
https://historicengland.org.uk/listing/the-list/list-entry/1277385
Interestingly the fence between the public and staff car park is listed and has its own dedicated entry unlike the Water Tower, for which they're appears to be no mention of it being listed either in conjunction with the adjacent station nor on its own merit.
https://historicengland.org.uk/listing/the-list/list-entry/1232086
I took the opportunity to pass through Huddersfield on Saturday night. After having a look at the train shed, without demolishing it and building a brand new one, it would be possible of achieving four through roads by moving P4 outwards towards P1 in order to reconfigure access to the subway, then extend 5 & 6 all the way through.
Although that would require all the existing buildings from waiting room to former signal box to be demolished. Im not sure if its they're is much point getting rid of 5 & 6.
Platform 5 already takes a 2-car 150. It's a tight squeeze but I've seen one in there this year.I believe Platform 5 is getting extended to house a 150, rather than just a two car pacer or a 153.
It would seem mad to get rid of the bay platforms even with the development, especially if TPE continue with the splitting of the stopping services.
It’d be good if they could get on with doing something opposite Platform 8 as well, whether a new platform or a car park, or releasing the potential of the mill adjacent, that seems to have been on the agenda with no movement for years.
It would do if you could access the station from it.The mill (and car park) is owned by an investor who is keen to put it to good use. It is not as empty as it looks. There are onsite staff. It has been re-roofed and basic structural work done a few years ago. Just keeping it watertight an investment of over £1M. It is an amazing building to go for a walk around in.
A number of anchor tenants were interested.
They are very much in touch with network rail. I suspect, from what they told me about their plans, that no movement will happen until plans for the station are complete.
The current (rough surface) car park never fills up.
If we look to the post-upgrade situation (assuming the plan posted previously is enacted) there'll be the currently planned 6tph from Leeds to Manchester (including the 2 semi-fasts). Terminating from the north/east will be 1tph from Castleford, 1tph from Leeds via Bradford and hopefully an (at least) hourly EMU stopper from Leeds via Dewsbury. This latter could allow the 6th TPE to drop stops at lesser-used stations such as Ravensthorpe and Deighton.If you look at the proposed 4 tracking east of Huddersfield back at post #2048, you'll see that the new fast lines on the southern part of the alignment will use only 2 of the proposed 6 platforms at Huddersfield, so forgetting P2 as this faces west, there will still be two through & one long bay platform available for use by the stoppers & on a better alignment with the new slow lines. That should be more than adequate not only for current service patterns, but future & longer ones too.
The question then is whether there will be capacity to terminate 3 or 4 trains per hour from the East at HUD. The present timetable has 3, but can only accommodate the third by using P5 for the Castleford service. Whilst Northern will retain some units short enough to use P5, looking further into the future the 150s won't last forever and any replacement would be too long.
There is of course the possibility of using the new slow line platforms to turn units back (including any potential Manchester/Marsden to Huddersfield stopper), though this may impact any plan for a TPE fast to overtake a semi-fast at HUD.
The proposed LNER Huddersfield service is one per day so I'm sure it can be fitted in
Although will it always be just once a day, once established, wouldnt a future franchise want to increase it like they are doing with Bradford and Harrogate.The proposed LNER Huddersfield service is one per day so I'm sure it can be fitted in
Have you considered the impact of the proposed London trains?
Platform 5 at Huddersfield is 39m long. Although it is true 150s have previously used platform 5 they are currently not being used on services booked to use this platform (or should not be at any rate).
