stephen owen
Travelling from Chester on a refurbished 175 to Llandudno i noted the new seats as being hard, i dont think this will be popular, especially on long journeys.
They're the same seats, they just haven't collapsed over 10+ years. I expect they will soften over time.
Nope, but it's the way of the world unfortunately. The subject of new and refurbished trains having much harder seats has been widely debated (actually - not much to debate, just about everyone agrees), but we are told it is all to do with reduced padding to be fireproof and thinner seats to maximise legroom.
The fireproof one appears to be a classic example of safety being taken to extreme measures (usually cost, but in this case comfort). The last train fire was 20 years ago next week, and was the result of a fuel tank rupturing following a direct impact, with a rapid inferno resulting. I'm not sure fireproof seats would have made much of a difference in that case. Before then, can anyone think of the previous fire in a train which entered the passenger area (excluding the Taunton sleeper train, where I agree standards need to be different)?
Just another example of where the railway gold-plates safety in a way that would not be tolerated in any other walk of life. As a great counter example in transport, look at the disquiet from the police and motoring organisations at the widespread creation of all lane running and removing hard shoulders from motorways. Sorry, slight digression!
I didn't think we changed the seat profile, just changed the foam and the seat cover. Welsh bums have got too used to seats that haven't seen any love for about fifteen years, they'll soften over time
But what no one asks is why do car seats get more and more comfortable but presumably still stay within fire regs ? (or are the seats in my Jag not compliant ?
The answer i suspect is that these are the seats you have to put up with as we (Dft or Train co`s) are not prepared to pay any more for better, more comfortable seats
I genuinely don't mind hard seats, as I've said before - I quite like ironing boards, even the original flat type on which I've done almost the whole run between East Croydon and MKC on a number of occasions, and that's nearly 2 hours. The specific problem with the offending "Azuma seat" (Fainsa Sophia) is that the base isn't thick enough and so you feel a supporting bar through it. The moquette cover is better than the flat cloth one at masking it but after about an hour you still feel it.
Back on topic, the seat used on 175/180 is quite reasonable and I don't think I'd be bothered about it being quite hard. Indeed it's quite a cleverly designed seat as it has the supporting structure in the middle (where your knees don't go) rather than at the sides (where your knees do go).
Quite - it’s more down to shape than squishiness, as it were... Those bouncy mk1 seats, whilst redolent of a golden era (or something) weren’t actually all that comfortable if we’re honest! (And the Citroen seats to which I referred were comfortable for about an hour until the lack of support began to make itself apparent!!!)
Where it falls down is things like contoured headrests (only any use if they're not supporting the back of your shoulders instead),
If you think his second paragraph isn’t the root of it, then you are hopelessly naïve.Because your car seats aren’t in a mass transit vehicle and are therefore subject to completely different regulations.
Your second paragraph is nonsense.
I'm not convinced the explanation around fire regulations stacks up. I've sat in seats in road coaches and aircraft that have considerably more padding than those in a lot of modern rolling stock, and they must be subject to fire regulations every bit as stringent.
I personally found first class on the ICE to be rather uncomfortable (1x on ICE-T, 1x on ICE-1). But then again I rarely travel in the UK so I wouldn't know if that's much worse.I would have thought the second para was spot on. They are not prepared to pay more and know full well that we do not really have a choice except sit for hours on end in traffic jams . Go the Germany and sit in an ICE train and feel the comfort of those seats which are still subject to EU fire regs.
So are you really saying that the seats in the 800`s are the best that can be bought for those trains and keep to fire regs ?
They cannot be so therefore they are what the dft is prepared to pay as I said above.
Ian Walmsley (who knows a bit or two about train procurement) is on record as saying it’s all down to cost. So I’m inclined to agree that the second paragraph is spot on, and definitely not nonsense.So are you really saying that the seats in the 800`s are the best that can be bought for those trains and keep to fire regs ?
And the point you miss is I have a choice, Go in my car in relative comfort or get excruciating back and bum pain on an 800. Car seats get better, train seats get worse. Regulations is a cope out.
Some of the Northern trains I have recently travelled on seem to have been filled which such mediaPeople nowadays are soft. In the old days everyone in Wales would sit on sacks of coal or slate and not complain
I don't normally travel by coach but I find seats on GoAhead and Arriva buses more comfortable than most train seats. With the so called "ironing board" seats it isn't so much the lack of padding but that they feel very narrow.I'm not convinced the explanation around fire regulations stacks up. I've sat in seats in road coaches and aircraft that have considerably more padding than those in a lot of modern rolling stock, and they must be subject to fire regulations every bit as stringent.
I personally really don't mind hard seats, I find them fine
