Travel the UK by Bus :)
Discussion in 'Quizzes & Games' started by sonic2009, 24 Oct 2011.
Thread Status:
  1. sonic2009
    sonic2009 Established Member
    4,148
    19 Jan 2010
    Moulton nr Winsford
    Now seeing as we have had the Thread about Hourly or More Services game.
    Let's create a bus one.
    Rules :
    Bus Routes in England,Wales,Scotland used must have a frequent service anything from every 2 mins to Hourly
    Direct Only, buses that change route numbers partway through the journey are allowed. as it's the same bus, just something to do with EU Regs.
    Example : x33 Abergavenny - Pontypool changes to X3 in Pontypool for Cardiff. Same Bus.
    Stagecoach X numbered allowed, Also GreenLine 757 etc allowed.
    MegaBus/Greyhound except the South Wales 100 Cardiff - Swansea, Reading - Heathrow are forbidden.
    National Express is allowed. And does not have to be HOURLY. with one rule person taking a go after NX is used cannot use NX on their turn :
    Example :
    444 NX Cheltenham - Worcester j.bloggs turn
    144 Worcester -.Birmingham First Midlands
    Now national express can be used :) comprende?
    It's going to be sketchy at first, but can update rules etc, as it goes along, if everyone feels it's getting confusing.
    I'm going to Start in Tewkesbury with Service 41 operated by Stagecoach West to Cheltenham Clarence Street.
    Rail Forums
  3. LexyBoy
    LexyBoy Established Member Fares Advisor
    4,461
    23 Jan 2009
    North of the rivers
    Got to be the 46 (Stagecoach West again) to Stroud then :)
  4. sonic2009
    4,148
    19 Jan 2010
    Moulton nr Winsford
    then the 93 stagecoach west again to Gloucester
  5. MK Tom
    MK Tom Established Member
    2,336
    31 Aug 2011
    Milton Keynes
    I don't have any idea where to go from Gloucester but I'd like to point out that the 99 from MK to Luton mentioned in the opening preamble is not a megabus or a rail link route now - Stagecoach now brand it as an interurban route rather like the X4 to Peterborough (which I assume this game would also allow?).
  6. Blindtraveler
    Blindtraveler Established Member
    7,702
    28 Feb 2011
    na same here. Kind of limmited! could we amend it so as NX can be used if all we'd do otherwise is dubble back on ourselves? Problem here is if we go somewhere new, we get problems with hourly services particularly after a certain time!
  7. MK Tom
    2,336
    31 Aug 2011
    Milton Keynes
    I think it'd work insofar as most major towns and cities have hourly+ bus routes linking them during weekday daytime... it's just a matter of what area you know. I know how to bus around from about Watford up to about Rugby, and from Swindon across to somewhere around Bury St. Edmunds. Outside of that diamond shaped area I have no idea!
  8. Ivo
    Ivo Established Member
    7,307
    8 Jan 2010
    Bath (or Southend)
    Sounds like a good idea! Thank you Sonic :)
    From Gloucester we'll take the Stagecoach West (in Gloucester obviously) number 12 to Dursley.
    I would have said the majestic 94 to Cheltenham, but er... we've been there already.
  9. dzug2
    dzug2 Member
    867
    5 Feb 2011
    I think you are stuck apart from the 210 to Cam and Dursley station which is almost hourly and when you get there you are stuck There's nothing frequent enough from Dursley southwards
    I'd have headed west from Gloucester to Ross on Wye on the 33 run by Stagecoach Wye and Dean though you pretty soon land up stuck that way as well
    To go back to the starting point you get much better opportunities starting off in a different direction. I'll suggest it once we are stuck......
  10. Ivo
    7,307
    8 Jan 2010
    Bath (or Southend)
    Last I knew Dursley had an hourly service to Bristol. But I haven't been able to keep up with some of the changes they've made.
  11. dzug2
    dzug2 Member
    867
    5 Feb 2011
    Every 2 hours and only to Thornbury now
    You'd be surprised in some areas as to the dearth of bus services - for example Gloucester/Bristol, Gloucester/Worcester, Gloucester/Newport all had reasonable services at one time. Now they are infrequent with changes en route
  12. Ivo
    7,307
    8 Jan 2010
    Bath (or Southend)
    My apologies to Sonic, seen as he's local (ish) to the area, but I might have to suggest a new starting point, and then probably in the south-east or M62 corridor. Gloucester really isn't an easy one, although it is possible (I think Stroud to Yate could have been used?).
  13. dzug2
    dzug2 Member
    867
    5 Feb 2011
    Another service that has bitten the dust I'm afraid. Now infrequent changing in Tetbury
    I'd suggest keeping Tewkesbury as a starting point and getting Aston's 540 to Evesham, whose frequency has recently been doubled to hourly as part of Worcestershire's bus cuts. (go figure....)
    I'm sure you can then get quite a way north without much further problem. (unless the aim is to get the next person stuck....) Probably to Northumberland
  14. MK Tom
    2,336
    31 Aug 2011
    Milton Keynes
    This seems to have died a death so shall we have another go starting at Watford??? Apologies if people can carry on from the previous line and don't want to do that. :)
  15. Ivo
    7,307
    8 Jan 2010
    Bath (or Southend)
    Certainly easier.
    From Watford let's take the much despi... I mean, loved 724 right through to its eastern terminus in my home county, Harlow.
  16. Xenophon PCDGS
    Xenophon PCDGS Veteran Member
    26,102
    17 Apr 2011
    The south-eastern part of the North West
    From Harlow, take the 505 service run by Arriva Shires and Essex to Chingford
  17. W-on-Sea
    W-on-Sea Established Member
    1,126
    18 Dec 2009
    And onto the TfL 179 to Ilford
  18. Xenophon PCDGS
    26,102
    17 Apr 2011
    From Ilford on the 123 service run by Arriva London to Wood Green
Thread Status:
Share This Page
