Travelcard v contactless less in London
LeylandLen
28 Oct 2013
Leyland Lancs
I am an occasional visitor to London with Virgin (off peak fares)from Preston , Lancs ,and I hold a senior railcard. I usually purchase an off peak zones 1-6 day travelcard capped for me at £7.80 . I have started using my contactless bank card when I estimate my journeys will be less than £7.80 in total. Am I right to assume that should my single off peak journeys within Z1-6 come to more than £7.80 ,then that is all I pay per day ? I have registered my bankcard with the tfl online page so they know I am a senior railcard holder!
gray1404
3 Mar 2014
Merseyside
You would be better getting an Oyster card and getting your railcard entitlement loaded on to it. This will be cheaper then using contactless.
DaveB10780
10 Sep 2015
Definitely an Oyster card with your railcard will be cheapest for you since cannot link contactless to a railcard. I think the current price is £8.00 for a Travelcard with a railcard. If you use contactless the standard off peak caps will apply depending on the zones used between £6.50-£12.80. However if you use Oyster it will be between £4.30 and £7.80.
MarlowDonkey
4 Apr 2013
Not quite the same problem, but with a Senior Railcard loaded to Oyster, should I buy a <local station> Travelcard? Or should I just get the London terminals ticket and use Oyster? Whether I'm travelling in the evening peak in Zone 1 seems to matter, as the price is higher with Oyster, but not with the Travelcard.
MikeWh
15 Jun 2010
Crayford
It depends what <local station> is.
