Traveling during the olympics
musicking1306
10 Jun 2012
Bristol
I have to travel between Paddington and Liverpool st/ Stratford on a Friday evening and return Sunday afternoon. Has anybody got any tips to travel through the area. E.g. Lines, times or different routes.
rail-britain
12 Aug 2007
I have to travel Euston to Stratford on a Friday evening
I plan to walk to St Pancras, and then take the Javelin to Stratford
I would suggest you travel Paddington to St Pancras, and then take the Javelin
What is the date?
If it is towards the end of the Olympics watch the performance of the some of the services over the preceeding weekends to see what they are like
rail-britain
12 Aug 2007
I travel between the two most weekends
Apologies, I read that you were looking to travel to/from the Olympics, but are actually looking for an alternative
I would suggest you look at the Olympics schedule, I would expect the second half to be busier as people attend the Athletics events
There will be a queuing system in effect for passengers between St Pancras and Stratford, with Games Travelcards, so you will probably want to avoid this
Therefore it might be more appropriate to travel (LU) Paddington to Notting Hill Gate, the via Liverpool Street to Stratford
SS4
30 Jan 2011
Either walk to Lancaster Gate and get the central line direct via Liverpool Street or you can get the H&C to Mile End where there is a cross platform interchange with the central line.
Probably easier using LUL than NR from St Pancakes
musicking1306
10 Jun 2012
Bristol
Ok thanks very much that sounds much more of an easier route than circle to Liverpool st from Paddington.
