Trivia — Shortest Routes Between Stations of the Same Name (For Example: Catford to Catford Bridge)
snowball
4 Mar 2013
I think I can better that : Falkirk High - Croy - Bishopbriggs - Springburn - Cumbernauld- Greenhill Lower Jn - Camelon - Falkirk Grahamston.
You don't have to go into England - see above.
Or Falkirk High - Waverley - South Sub - Falkirk Grahamston? There seem to be junctions facing the right way.
(I'm ignoring the existence of passenger services, just looking at the tracks.)
southern442
20 May 2013
There are no services which connect Bishopbriggs to Ashfield.
There are also no services which connect Bishopbriggs to Springburn.
I didn't think direct services were needed, just that the connection exists and is useable?
Assuming it isn't, then a quick glance suggests you'd need to travel to Edinburgh, down to York, Leeds, Manchester, Preston, Lancaster, Leeds then back up. This would also make Upper Tyndrum to Tyndrum lower possible.
I would hypothesize that *every* connection is possible in some form, but the real question is where the most optimal routes are.
24 Sep 2017
St Budeaux Victoria Road to St Budeaux Ferry Road:
Ferry Road > Plymouth > Exeter > Taunton > Bristol > Bath > Salisbury > Romsey > Loop back to Romsey via Southampton and Chandlers Ford > Salisbury > Bath > Bristol > Taunton > Exeter > Plymouth > Victoria Road
After Bath you could go Westbury > Castle Cary > Taunton etc rather than going to Salisbury and Southampton
flitwickbeds
19 Apr 2017
I interpreted it as that it must be possible to actually do on a train. If we're just looking at infrastructure and nothing else, can we include freight/depot loops with appropriate junctions?
If we're doing it with existing passenger services only, I think it would have to be Falkirk High > Edinburgh > Newcastle > Carlisle > Motherwell > Cumbernauld via Coatbridge Central > Falkirk Grahamston. I think that works?
Of course!
Here are a few more I thought of overnight which vary the rules a bit!
Harlington (Beds) to Hayes and Harlington
Harlington Beds > Farringdon > Wimbledon > Reading > Basingstoke > Southampton > Salisbury > Westbury > Pewsey > Reading > Hayes and Harlington
London Waterloo to Waterloo Merseyside
London Waterloo > Clapham Junction > Sutton > Wimbledon > Clapham Junction > Milton Keynes via Shepherds Bush > Crewe > Liverpool South Parkway > Waterloo Merseyside
TheDavibob
10 Oct 2016
Birmingham New Street to Birmingham Moor Street: WCML south to Willesden - Acton Canal Wharf Jn - Acton Wells Jn - Acton West Jn - Reading - Oxford - Banbury - Leamington - Birmingham Moor Street
I guess willesden - acton canal wharf junction - acton wells jn - acton west junction - west ealing - greenford south junction - greenford west junction - high wycombe - banbury - leamington - moor street is slightly fewer miles! (but still a long trip)
I haven't run the numbers, but potentially a 'shorter' route via (nearly) Newport:
New Street -> Bromsgrove -> Gloucester -> Hereford loop? (Newport) -> Abergavenny -> Hereford -> Worcester FS -> Kidderminster -> Moor Street
It's decidedly less straight than the WCML so might not be shorter.
30907
New Street -> Bromsgrove -> Gloucester -> Maindee Curve (Newport) -> Abergavenny -> Hereford -> Worcester FS -> Kidderminster -> Moor Street
Another option for this is via Stonehouse, Swindon and Didcot West Curve.
Historically it would be much shorter - Droitwich, Honeybourne, Stratford.
Ash to Ash Vale I can only seem to manage via Guildford, Redhill, East Croydon, Clapham Junction, Peckham Rye, East London Line, North London Line, Willesden Jn, Richmond, Virginia Water, Chertsey and Woking (but you have to use the lesser-used curve between Chertsey and Byfleet)
You can shorten that by going ....East Croydon, Tulse Hill, Herne Hill, Brixton, Longhedge Jn, Clapham Junction - Richmond....
And you can use the Byfleet west curve, but you don’t have to. You could go Virginia Water - Ascot - Bagshot - Ash Vale.
Or you could go Ash - Reading - Oxford - Bicester - Neasden - Acton Canal Wharf - Acton Wells - Kew East - Hounslow - Staines and thence as above.
fairysdad
27 Dec 2010
London, Surrey... bit of a blur round here...
Ewell East to Ewell West: Ewell East > Sutton > Mitcham Jct > Streatham > Herne Hill > Brixton > Wandsworth Road > Clapham Jct > Barnes > Southfields > Wimbledon > Motspur Park > Ewell West
With no connection between Southern and SWR at Clapham Junction, you'd need to go via Balham and the northern half of the Thameslink Loop to Wimbledon and join SWR's metals there.
Dr_Paul
3 Sep 2013
Yes! The criterion that I set was that one can take any uninterrupted route. It doesn't matter if there has never actually been a service that has taken the route in part or in whole. Going along a freight line is fine; going through a yard or depot is fine as well, so long as one does not have to reverse. Looking at industrial faculties on 25" maps, it seems that some of them were served by branches of different railway companies, thus raising the intriguing idea that a through route might have been possible through one or another mine or factory yard. This, of course, would be restricted to historical route possibilities.
[London Trains' previous post: 'Ewell East to Ewell West: Ewell East > Sutton > Mitcham Jct > Streatham > Herne Hill > Brixton > Wandsworth Road > Clapham Jct > Barnes > Southfields > Wimbledon > Motspur Park > Ewell West.'] With no connection between Southern and SWR at Clapham Junction, you'd need to go via Balham and the northern half of the Thameslink Loop to Wimbledon and join SWR's metals there.
If we substitute Wandsworth Town for Barnes, then that's fine, as it means (as I imagine London Trains intended) going through East Putney. There is the proviso that one needs to get from the joint LT/SW down line across to the down Sutton line at Wimbledon, which, according to this map is possible.
Here are a few more I thought of overnight which vary the rules a bit! Harlington (Beds) to Hayes and Harlington [etc, etc].
This variation will add to the fun.
[Selhurst] you can only travel via the depot as ecs [empty coaching stock] as they removed the passenger loop from the running line about 40 years ago ??
If it's possible to go through from Selhurst to Upper Norwood (or vice versa) via the Selhurst yard without reversing, then that's within the thread's main criterion.
JKF
29 May 2019
Historic one:
Bath Green Park - Mangotsfield - Staple Hill - Clifton Down - Avonmouth - Henbury - Filton - Lawrence Hill - Keynsham - Bath Spa
30907
You only need to get to the Down SW for Ewell West, going to Sutton will have you going round in circles :)
Dr_Paul
3 Sep 2013
Of course! I'm getting things well confused. No problem about getting from the District/SW joint across to the down slow SW line.
Sultan1056
27 May 2017
Cumbria
What about Newark Northgate to Newark Castle?
via York > Edinburgh > Midcalder > Carlisle > Crewe > Birmingham New St > Leicester > Nottingham.
pis there a shorter route?.
JohnRegular
12 Dec 2016
Might be missing something but I think you could go North Gate - Gainsborough Lea Rd - Worksop - Mansfield - Nottingham - Castle? Requires using the curve avoiding Lincoln which doesn't see regular passenger services (I think).
TheDavibob
10 Oct 2016
I think the curve at Retford allows direct access from the ECML towards Worksop too, cutting out Lincoln/Gainsborough.
DelW
15 Jan 2015
Here's an amazing one for stations which are so close together (the closest two stations on the network??). Normally a simple reversal at Plymouth.
(Although whether or not you consider the two stations to be on a different line is debatable - you certainly can't travel directly between the two on one train!)
Since the OP allows freight lines, there's surely no need to go beyond Bristol? Go round in a loop via Filton West, Avonmouth and Clifton and head back south.
flitwickbeds
19 Apr 2017
There is one direct train in each direction between the two stations on weekdays and Saturdays
And 3 in one direction and 2 in the other on Sundays
roversfan2001
19 Feb 2016
Lancashire
They all reverse at least once so don't meet the criteria set for the thread.
4COR
30 Jan 2019
A historical one: Warlingham (now Whyteleafe South) to Upper Warlingham.
I think a route historically could have been:
Warlingham -> Purley -> Norwood J -> Crystal Palace (via Bromley Up Junct) -> Tulse Hill -> Peckham Rye -> New Cross Gate (via the lost chord from Old Kent Rd Junct to New Cross Gate - this looks like it might be a through line from the Railway Clearing House diagram dated 1908?) -> S Croydon via BML -> Upper Warlingham
Certainly prior to 1983 (and Warlingham was renamed well before this!), I suppose you could have done the following down the Woodside and S Croydon Railway to prevent going over any line twice (at E Croydon - but probably not as short as going via Herne Hill and back through Crystal Palace):
Warlingham -> Purley -> Clapham J -> Pouparts/Longhedge -> Denmark Hill -> Lewisham -> Elmers End -> Selsdon -> Upper Warlingham
Ianno87
3 May 2015
Hayes to Hayes & Harlington:
Hayes-Lewisham-Denmark Hill-Factory Jn-Longhedge Jn-West London Line-South West Sidings-Acton Bank-Ealing Broadway-Hayes.
Bigman
24 Feb 2011
A historical one this...Bradford Exchange - Laisterdyke - Idle - Thackley - Shipley - Bradford Forster Square.
adrock1976
10 Dec 2013
A historical one I have thought of:
Sheffield Midland> Pontefract Baghill> Milford Jct> Hambleton Jct> Doncaster> Retford> Worksop> Darnall> Sheffield Victoria.
Also, a couple of present day ones are Glasgow Central High Level> Polmadie> Rutherglen> Langloan Jct> Gartcosh> Springburn> Cowlairs South Jct> Glasgow Queen Street High Level.
Glasgow Central Low Level - Queen Street Low Level via Dalmarnock> Rutherglen> Langloan Jct> Sunnyside Jct> Shettleston> Bellgrove> Queen Street Low Level.
jfisher21
21 Mar 2011
Would Warlingham -> Purley -> Clapham J -> Pouparts/Longhedge - Brixton - Herne Hill - Tulse Hill - Crystal Palace - Norwood Junction - East Croydon - Purley - Upper Warlingham be possible?
Or the alternative is a trip through London Bridge, Thameslink tunnel, Cricklewood, South Acton, Kew Bridge, Barnes, Clapham J -> Pouparts/Longhedge - Brixton - Herne Hill - Tulse Hill - Crystal Palace - Norwood Junction - East Croydon - Purley - Upper Warlingham
Glenn1969
22 Jan 2019
Halifax, Yorks
What's the quickest route ?
Bramley (Yorks) to Bramley (Hants)
Bradford to Bradford on Avon
Kingston upon Hull to Kingston upon Thames
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
Could do Portsmouth Harbour to Portsmouth Arms. ;)
I expect the quickest route would be something like: Portsmouth Harbour > Southampton > Salisbury > Westbury > Taunton > Exeter > Portsmouth Arms
Edit: Forgot the reversing rule!!! Reworking...
Portsmouth Harbour > Southampton > Salisbury > Yeovil > Exeter > Portsmouth Arms - this appears to work.
Ianno87
3 May 2015
Portsmouth Harbour - Fareham - Botley- Eastleigh - Chandlers Ford - Romsey - Salisbury - Axminster - Exeter - Portsmouth Arms
30907
Do you mean quickest timetabled, or quickest theoretically possible in on the OP's terms (ie without reversal?). If the latter, then:
probably Whitehall Curve or Hambleton Junctions, Saltley, Tyseley, Reading West Curve
probably Whitehall Curve or Hambleton Junctions, Saltley, Bristol East Curve.
North London Incline, Willesden Jn HL, Clapham Jn, East Putney or Richmond.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Unfortunately Hambleton Junction (opened 1983 with the Selby diversion) didn't exist when Sheffield Victoria closed (1970), so you would have had to take the very slightly longer route via Selby West and Canal Junctions!
