Trivia: Any completely self contained routes?
vidal
23 Feb 2017
Bolton
Are there any routes that although part of the National Rail Network are completely isolated? Isle of Wight would be a candidate, but are there any others? There have been temporary examples when routes have been severed and stock has been trapped.
James
Holyhead breakwater operated separately for a period
Think it was like that in 1980s but don’t know the dates
The narrow gauge Vale of Rheidal railway might have been separate (unless the tracks actually had a crossing of standard gauge) which was part of BR until end of 1980s
pdeaves
14 Sep 2014
Gateway to the South West
Depending on what exactly you count, branches like Sudbury may be candidates in normal service (the only track connection to the rest of the world being used to get a unit on and off the branch at each end of the day). There will be numerous other similar examples.
For 'no track connection at all', there will be very few. The Waterloo & City line was once in this category until passed to London Underground.
AMD
6 Dec 2017
Historically the Far North and Kyle lines were isolated when the Ness Viaduct got washed away on 7th Feb 1989, it wasn't until 14th May 1990 that the link was restored.
Cambus731
19 Jul 2013
The Stourbridge Town shuttle is pretty much self contained with its own dedicated rolling stock.
DB
Guest
18 Nov 2009
Still has a connection to the network though (which was used a few months ago for reballasting work - a 56 took the wagons up the branch. There are a number like this - Sudbury already mentioned. I think Looe is one as well? Apart from the IoW, I can't think of any which don't actually have a rail connection to the network though.
Peregrine 4903
18 Aug 2019
Grove Park to Bromley North is another one that runs as completely self contained during the day apart from ecs's in the morning/evening coming to/from Grove Park depot.
Also they are obviously not completely self contained but the merseyrail and the c2c networks are as close to self contained as you will get on the UK national rail network.
snowball
4 Mar 2013
Similarly the railway on Anglesey was isolated between 1970 and 1972 when the Britannia bridge was damaged by fire.
Ianno87
3 May 2015
I'm sure the St. Ives branch got severed a year or two ago due to track replacement at St. Erth; a pair of 150s were trapped shuttling between Lelant Saltings and St. Erth.
There have been light rail examples too:
-Track works in Croydon town Centre meaning East Croydon-New Addington/Beckenham Junction/Elmers End segregated from the rest of the system (trams kept at Elmers End each night)
-After the South Quay bombing in 1996 that severely damaged the station, a DLR unit was trapped at (old) Island Gardens for several weeks.
61653 HTAFC
18 Dec 2012
Another planet...
North of Barmouth Bridge has had similar temporary isolations, either for planned repairs to the wooden bridge; or when a particularly gluttonous species of woodworm were discovered chowing down on the bridge frame!
I suppose Stourbridge is pretty much functionally isolated, moreso than a “Sudbury”, because in normal circumstances the specialised stock also stays in situ.
SargeNpton
19 Nov 2018
Cardiff Bay shuttle.
During normal services yes. But during engineering works, some of the Valley Lines services run to/from Cardiff Bay instead of Cardiff Central.
I'd offer the Looe branch as I don't think that it has and scheduled passenger moves onto the main line. Possibly the Falmouth branch as well.
BayPaul
11 Jul 2019
The Falmouth branch runs along the mainline tracks for around 700m from Truro to the junction. Looe is self-contained, going as far as to have the platform at right angles to the main line platforms in Liskeard! (though obviously it does have a connection to allow stock to return to Laira.
Mcr Warrior
8 Jan 2009
Is the Manningtree - Harwich Town branch fairly self contained, last departure of the day is for Colchester, but that's about it.
BayPaul
11 Jul 2019
I don't know if it is currently operating, but isn't there usually a twice daily boat train from Liverpool Street to Harwich International to connect with the Hook Ferries?
waverley47
17 Apr 2015
It's important to differentiate between services that are self contained entirely, with no track connection to the main lines, and services which are run as self contained but share connections.
Everywhere on the network, barring certain unforseen circumstances, is connected to everywhere else. That is the virtue of a national network. Any unit could in theory be dragged everywhere else.
However, some services run as self contained shuttles. The Bromley North, Stourbridge Town, Looe and St Ives lines all run self contained during normal service, but share connection.
Other examples which theoretically could run without interference from the outside network are the Far North Line, by virtue of separate platforms at Inverness, and Merseyrail similarly with separate platforms at Ellesmere Port and Chester.
bassmike
23 Aug 2010
lenham kent
W&C still has no track connection.
DelW
15 Jan 2015
And again a bit further north a couple of years ago, when Pont Briwet (bridge) was rebuilt. However I don't think anything ran on the line north of the site, I think RRBs ran to Pwllheli from somewhere south of the works.
I believe the connecting line isn't passed for passenger use, so can only be used by ECS.
Kite159
27 Jan 2014
West of Andover
Although under the current timetable, there isn't any Cardiff Bay shuttles as the units work to Pontypridd or Caerphilly
GrimsbyPacer
13 Oct 2014
Grimsby
Would some of the permanent rail replacement bus routes, such as Wedgewood, technically count as isolated? Rail tickets can be used so it could be argued that some buses are part of the rail network.
Shimbleshanks
2 Jan 2012
Purley
Stretching a few points, but what about the Alderney Railway. Not exactly part of the UK, but it is standard gauge.
vic-rijrode
31 Aug 2016
The Bideford, Westward Ho! & Appledore Railway would have been a classic example of a standard gauge railway never joined to the national network gauge.
Mikey C
11 Feb 2013
The last time down there, I recall taking an early 150 from Plymouth to Liskeard which went around the loop to become the Looe shuttle for the day! I was half tempted to hide in the toilets so I could do that loop :E
Bristol
The OP asked for the national rail network:
I suspect this was never part of BR or the Big 4, which would presumably be the limit of the OP's definition.
Were any of these ever part of BR or the SR? Bideford may have been.
The Glasgow subway is self contained.
Hasn't this always been independent of the national rail network?
