TRIVIA: Direct Buses Faster Than Direct Trains
peterblue
25 Jun 2018
Lancashire
Sunday 15th May was (supposed!) to be the first day of DalesRail, between Blackpool and Carlisle via Clitheroe and Settle, once per week in each direction. Unfortunately, it was cancelled today on the first day.
But, upon reading the timetable, I noticed something unusual. On Sundays there is a direct train between Clitheroe and Preston (normally requiring a change at Blackburn) and also a direct bus to Preston, the 280 by Stagecoach. The train takes 50 minutes from Clitheroe-Preston, but the bus only takes 46.
Are there any other examples of this in the UK- where a direct bus is faster than a direct train between 2 points?
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
Although not a huge saving, the Stagecoach bus 65 between Guildford and Farnham can sometimes be a few minutes quicker than the relative South Western Railway service. The train takes around 23-25 minutes, whilst most journeys on the bus are also 23 minutes, but there are a handful which are slightly quicker (up to 20 minutes).
APT618S
7 Dec 2018
Kilmarnock Bus Station to Glasgow Bothwell St nr Glasgow Central is timed for 31min on Stagecoach's X76.
Typical trains take 35-40mins.
Due to the late morning Carlisle - Glasgow train having around 10mins waiting time at Kilmarnock, I have actually got off a train at Kilmarnock Station, walked down to the bus station and got the bus into Glasgow arriving before the train was due.
GusB
Buses & Coaches
Elginshire
Inverness to Wick: 4h15 is the quickest timing by train, while the bus is just under 3h.
Shimbleshanks
2 Jan 2012
Purley
Belfast to Londonderry is 2hr 02 minutes by train, 2hr 00 minutes by express bus, thought at least one bus journey is timed at 1hr 50 min.
Flange Squeal
17 Jul 2012
Richmond station to Kew Bridge station in south west London is typically 12 minutes by route 65 bus versus around half an hour by South Western Railway. BUT the trains run as part of a circular service, so while they do run direct without changes it might be a bit of a cheeky one.
InOban
12 Mar 2017
Fort William to Glasgow. Bus is about 3 hours, train nearly 40 minutes longer.
Inverness to Kyle , bus 2hr 8m. Train nearly 2 40.
Flying Snail
12 Dec 2006
Train is 2h12 and the rail station in Derry is far enough away from the city centre that a free shuttle bus is provided.
railwaytrack
7 Mar 2022
Pluckley
If you are travelling between Pevensey & Westham and Polegate or vice versa than it is much quicker to take the Stagecoach route 6 bus. The bus takes 12-14 minutes while the train takes 22-24 minutes. So the bus takes about half the time.
43055
8 Mar 2018
The Transpeak is timed at 12 mins between Matlock and Ambergate while the train takes 14 towards Derby. The other way the train takes 15 mins and the bus is 17 mins.
Mikw
20 Apr 2022
Leicester
I'd probably say Leicester to Birmingham.
National Express runs from just down the road, but only goes to Digbeth, but it's usually 45 minutes, and quite a bit cheaper
peterblue
25 Jun 2018
Lancashire
I see the fastest coaches taking 1h5m and the semifast train taking 48 minutes, unless I am missing something.z
Alex 2901
30 Dec 2015
Willenhall, West Midlands
Wolverhampton to Walsall.
By a very long margin:
Fastest trips on the 529 are given 28 minutes between Wolverhampton and Walsall. On average, it's given 37-38 minutes during the day.
For comparison, the daytime journey on the train is 62 minutes.
It was briefly even wider when the X529 ran - 28 minutes during the day.
Mcr Warrior
8 Jan 2009
I've used the coach regularly and it's usually only about 45 minutes.
Where were you travelling to and from exactly? Fastest Leicester City Centre -> Birmingham (Digbeth) bus/coach journeys (National Express service 150) seem to be late evening services and timetabled at 1 hours 5 minutes, as @peterblue has reported. Doubt you'd manage 45 minutes during the day, even in a taxi.
Mikw
20 Apr 2022
Leicester
Usually late morning, it's quite possible to do it in 45 minutes, the M69 and M6 are fairly quiet at that time of day
HullRailMan
8 Oct 2018
Very marginal but York to Driffield is 1hr 45min by direct train and 1hr 33min on the now once a day route 45 bus. The bus was even quicker on the now ended 45A bus and that route was also faster than the train York to Bridlington.
Mcr Warrior
8 Jan 2009
It's not uncommon for it to arrive at Digbeth well before the timetable says it should. Ok, so 45 mins is not that common, but 50 mins is quite regular.
Thanks for clarifying. So not actually timetabled as being quicker than the train, which does it in 48 mins, as advised by @peterblue .
plugwash
29 May 2015
Stockport to Manchester airport is 15-20 minuites on the 199 bus depending on the time of day.
Most of the direct trains have been withdrawn, but the one train a day that still runs takes 28 minuites.
GCRS
28 Nov 2016
I was going to suggest that the T19 bus from Llandudno - Blaenau Ffestinog would have been faster than the train, but it seems not. The train just beats the fastest bus.
61653 HTAFC
18 Dec 2012
Another planet...
Huddersfield to Bradford is often quicker on the X63 than the direct train, as it runs straight up the A644 for the most part. The train by comparison takes a rather circuitous route via Brighouse, Elland and Halifax.
DJames
22 Jan 2017
Tipton
If you can class it as a bus, the Megabus from Birmingham to Cambridge takes 2h 20min, whereas the direct train takes around 2h 45min. The coach would be a bit quicker too, if it didn't have to call at Coventry on the way.
