TRIVIA: Heritage railways that run trains on NR lines
AY1975
14 Dec 2016
I would guess that the NYMR's Whitby services are one of only very few examples of a heritage railway running trains on Network Rail metals - regularly between Grosmont and Whitby, and occasionally as far as Battersby during certain special events.
Can anyone think of any other examples of existing or proposed services run by heritage railways (or by other operators using heritage railways) onto NR lines? I suppose the Dartmoor Railway runs almost entirely on NR metals, and the proposed Swanage-Wareham service (now delayed until at least 2019) is another example as is the often mooted (but so far never realised) Rawtenstall-Manchester commuter service if it runs via Castleton. Plus the WSR's long-held ambition to run through to Taunton.
See also the thread on the Wareham-Swanage service at www.railforums.co.uk/threads/swanage-wareham-diesel-service-delayed-until-sept-2018.159857/ and the one on heritage railways running community rail services at www.railforums.co.uk/threads/trivia-community-rail-services-on-heritage-railways.172078/
matt
30 Jun 2005
Rugby
North Norfolk runs dining trains to Cromer.
steamybrian
26 Nov 2010
Kent
Spa Valley Railway runs on NR metals between Birchden Jn and Eridge. I will state that it is a separate parallel line with line used by "Southern " services.
Chinnor and Princes Risborough railway runs into its separate Princes Risborough station over NR metals which (I believe )are still used for engineers trains. I open for correction on this.
pdeaves
14 Sep 2014
Gateway to the South West
Paignton & Dartmouth used to run on BR track to south of Goodrington. Now, having bought that formation, it uses one end of a Network Rail-owned crossover.
The Dart Valley Railway operated over BR tracks into Totnes station from 5 April 1985 to 2 September 1987.
IanH440
11 Oct 2017
Oakhampton is owned by the Quarry, Welsh Highland 60cm run over Cambrian (NR)
duffield
31 Jul 2013
East Midlands
The WHR (Welsh Highland Railway) at Porthmadog runs 'over' NR metals in the sense that it has a flat crossing with them. :E
InterCity:125
15 Jul 2018
Bristol
The chosley and Wallingford railway uses the national rail chosley station but I’m not sure whether they’re NR metals.
168lover
2 Aug 2013
Chiltern Mailine Land
The siding that Chinnor operate is used by 2 trains a day to turn back in once they terminate in Princes Risborough. These trains can be found here:http://www.realtimetrains.co.uk/train/C72328/2018/10/18/advanced and http://www.realtimetrains.co.uk/train/C72107/2018/10/18/advanced. The siding is also used by the occasional tamper who have rights to stable on our site at Princes Risborough and also by the very occasional special or loco move to Chinnor for events we put on.
Mag_seven
1 Sep 2014
here to eternity
The Scottish Railway Preservation Society (SRPS) has its own set of coaches (based on its preserved line in Bo'ness) which is used on tours on the NR network.
matt
30 Jun 2005
Rugby
So it's the other way around then - GBRf (assuming they're still the current operator) services running along part of the private line? Are there other examples of that on the network?
The tanks from Preston Docks run on the Ribble Railway for the first part of their journey although I believe they use their own traction before swapping to Colas at the exchange sidings.
bnm
12 Oct 2009
The WSR and its landlord, Somerset County Council, no longer have active plans or ambitions to run into Taunton. It hasn't really had any such ambition since the 1970s plans for commuter services between Minehead and Taunton were kyboshed by British Rail and the NUR.
Talk of such, 'plans' comes from individuals or groups not affiliated with the WSR. Such plans that do exist are for national rail services to run to Bishops Lydeard. NR running over WSR metals rather than vice versa.
pdeaves
14 Sep 2014
There were revenue stone trains to Minehead and Fitzgerald Lighting ran a revenue freight for a while from the Bodmin & Wenford Railway to 'somewhere' on the main line network.
xotGD
4 Feb 2017
Coal trains operated from a loading point at Wolsingham on the Weardale Railway for a couple of years. Not any more, however.
steevp
25 Jul 2012
No - it is completely separate (they use opposite sides of the same platform with a short run round loop on the C&W side) - there isn't even a access point, any visiting locos are delivered by road to Wallingford.
InterCity:125
15 Jul 2018
Bristol
I know this thread is about tracks, but don’t they use the same station facilities?
vlad
13 May 2018
IIRC the Network Rail boundary is a bit to the north of Matlock station, so Peak rail trains technically run onto NR lines at the southern end of their journey.
STEVIEBOY1
31 Jul 2010
Not forgetting some charter trains which run through from NR to private railways from time to time, eg the Summer services from Bristol to Kingswear and services on to the WSR, SVR, MHR, Weardale and Wensleydale etc.
alexl92
12 Oct 2014
The MOD run trains along the Wensleydale branch to deliver equipment to Catterick Garrison - in fact it was they who were responsible for keeping the line from being closed by BR in the first place.
MarkyT
20 May 2012
Torbay
Dartmouth Steam Railway, as it is known now, fully owns their station yard at Paignton, and the land you describe at Goodrington, but in addition to the crossover described, their dedicated single track for a short distance extending over Sands Lane (Paignton South) level crossing is also still owned by Network Rail. NR take no part in authorising normal movements over this section however, with the two railways having their own independent signalling. The level crossing installation is entirely a NR asset but is operated locally for each train by crew from the DSR or a mainline train company as appropriate. Barriers rise automatically once a train has cleared the crossing. The crossover points connecting DSR to NR are NR owned but only properly interlocked with the DSR signalling via a ground frame release. Movements between the two railways still have to be verbally authorised as the corresponding interlocking in the NR signalbox has never been installed. At the NR end, the switches are secured by clip and padlock, with a special key held in the signalbox.
Skutter
15 Mar 2015
Does that still happen? The only links I can find online are from years ago, but it would surely be a good source of revenue if true.
alexl92
12 Oct 2014
I thought it did, from time to time, but I can’t be 100% sure. But as the line is leased from NR I imagine it’s NR who keep the revenue?
