Trivia: Instances where a local service has been bustituted to make way for diverted fast trains
Discussion in 'UK Railway Discussion' started by PTR 444, 1 Feb 2020.
  1. PTR 444
    PTR 444 Member
    276
    22 Aug 2019
    Wimborne, Dorset
    As we’ve heard on the Eastleigh derailment thread, routine engineering work on the Romsey - Salisbury line has been cancelled to make way for XC and freight trains diverted by the blockage. You’d think that in this instance, SWR and GWR would reinstate their services along the line, but nope, that hasn’t happened. We are now left with the bizarre situation of a line having its local stations bustituted because fast trains are being diverted that way, even though there are plenty of paths available along the line.
    I’m sure there are other examples of local rail bustitution (where the line is open but no trains are stopping at stations) around the country for more legitimate reasons though. I seem to recall Melksham having a replacement bus service for the day due to a planned closure of the Berks and Hants Line diverting all fast trains through that station (and taking up available paths).
    Rail Forums
  3. Kite159
    Kite159 Veteran Member
    14,024
    27 Jan 2014
    West of Andover
    One which pops to mind which has happened in the past is buses between weybridge & virginia water serving Chertsey & Addlestone on Saturdays when the mainline has been closed.
    Another example which pops to my head is between Aylesbury & Princes Risborough, the local service for Little Kimble & Monks Risborough is bused whenever the mainline is closed and Birmingham trains are diverted via Aylesbury
  4. The Planner
    The Planner Established Member
    9,683
    There will be countless occasions, every weekend.
  5. bramling
    bramling Established Member
    7,506
    The Hertford loop in the aftermath of both the Hatfield and Potters Bar accidents. The entire local service was withdrawn in order allow the outer suburban and long distance services exclusive use of the loop.
  6. Mag_seven
    Mag_seven Established Member Associate Staff General Discussion
    5,969
    1 Sep 2014
    here to eternity
    A couple of weeks ago there was no GWR stopping service on the Greenford branch in order to make way for diverted Chiltern services which were running to/from West Ealing (the diverted services did not make stops intermediately in lieu)
  7. swt_passenger
    swt_passenger Veteran Member
    22,119
    I thought it was explained in the Eastleigh thread that leaving the buses in place wasn’t directly because of the diversions, but more likely because it was too late to bring additional staff in?
    (Please see pompeyfan’s post #241 in that thread.)The diversions had run with the normal Salisbury to Southampton timetable in place all week.
    But as others have said the general point about using local buses to make room for other long distance trains isn’t at all unusual.
  8. gingerheid
    gingerheid Member
    1,000
    2 Apr 2006
    Happens on the Hertford Loop?
  9. tbtc
    tbtc Veteran Member
    15,911
    16 Dec 2008
    Yorkshire, Yorkshire, Yorkshire
    Isn't this the plan on some of the crayonista suggestions on the forum? That a route be built for local trains but with the capacity to abandon such services so the line could accommodate long distance diversions when required? I thought that was therefore seen as A Good Thing?
    I suppose one "long term" example in recent times has been the EMT/EMR peak time service from Bedford to Wellingborough (?), so that trains could run non stop (since Thameslink services strangled paths available to East Midlands services) - I say "long term" to mean that it wasn't just a temporary thing for a few weeks due to engineering works or disruption.
    A parallel thread might be "Instances Where A Local Station Has Seen An Improved Service Due TO Disruption/ Diversions" (e.g. places temporarily gaining a better class of stock serving it or a faster service to the nearest big city or additional departures)
  10. tsr
    tsr Established Member
    7,394
    15 Nov 2011
    Between the parallel lines
    One line of route where this happens is Dorking-Horsham. If trains between London and Gatwick are diverted via Horsham as part of a planned weekend closure, buses or taxis will generally replace trains calling at Holmwood, Ockley and Warnham. The off-peak traffic to these stations is so scarce that even one taxi can be overkill, and in fact would probably be more useful to any passengers who do turn up... except when you get a completely random group of hikers and you suddenly need 3 buses. Oh, the joys of Things Which Are Not Quite As Good As Trains.
    This only applies during weekend blocks which include the Saturday, as there is no Sunday service on this line. You can therefore get the occasional Sunday service (as tomorrow) running non-stop through these stations when the line would usually be completely shut.
    Not quite "countless". It's a reasonably well-worn tactic, but there aren't that many places each weekend where there are both diverted trains and significant impact if services stopped at all stations.
    Happens in shorter-term disruption as well. On Monday, for example, the signalling issues at Knebworth meant that there was a plan to run all express trains via the Hertford Loop and cancel the stoppers. Fortunately, just as buses arrived, the plan was cancelled.
    The same can potentially happen if there is any other major blockage (loss of signalling, fatality etc.) on the ECML between Alexandra Palace and Stevenage.
    Likewise, if there is congestion caused by an incident and the Welwyn area gets congested, some trains won't stop at Welwyn North or (in a few cases) Knebworth.
  11. 185143
    185143 Established Member
    3,118
    3 Mar 2013
    IIRC during the Lamington Viaduct diverts, ScotRail cancelled 1tph between Glasgow and Kilmarnock to facilitate VTWC diverts, with Kilmarnock gaining a roughly hourly non stop 221 to both Carlisle and Glasgow?
  12. AlbertBeale
    AlbertBeale Member
    676
    16 Jun 2019
    Are there often closures on the Chiltern line that affect the stretch from Pr Risborough to Neasden, but not the part northwards to Brum and not the part from Neasden to M'bone? So trains have to reverse twice to get to and from M'bone? Wouldn't it be possible to get some of those passengers from Brum to London more efficiently via Oxford and the Paddington line?
  13. JonathanH
    JonathanH Established Member
    4,030
    The days when there were paths for Paddington to Oxford and Banbury for Chiltern line trains are long gone so it is through diversion via Aylesbury or DIY diversion on GWR / XC services. Chiltern need to maintain their own links to Princes Risborough, Haddenham and Bicester in any case.
  14. Nicholas Lewis
    Nicholas Lewis Member
    240
    9 Aug 2019
    When Fast Lines are closed Stoats Nest Jcn to Gatwick Airport and traffic via Slows Earlswood and Salfords are bustituted
  15. thenorthern
    thenorthern Established Member
    3,583
    27 May 2013
    Norton Bridge, Stone, Barlaston and Wedgwood, it's been the case in some sort of way since 2004.
  16. Parallel
    Parallel Established Member
    2,723
    9 Dec 2013
    TransWilts services via Melksham.
  17. Samuel88
    Samuel88 On Moderation
    385
    20 Jan 2017
    I really think especially in these cases, that rail companies should be laying on replacement buses free of charge, and you shouldn't be required to have a rail ticket before boarding!
  18. ANDREW_D_WEBB
    ANDREW_D_WEBB Member
    238
    21 Aug 2013
    Technically this is an example of a service being suspended without any replacement as no buses were provided, passengers being directed to regular TfL buses. It did mean that West Ruislip to West Ealing had a half hourly service both days instead of the usual weekday Parliamentary service.
    In the same area, Hanwell, West Ealing and Acton Main Line all get no replacement buses when the slow lines are closed on the GWML (these stations have no fast line platforms
  19. mr williams
    mr williams Member
    132
    19 Sep 2010
    About 15 years ago engineering work on the Filton Bank meant that long distance trains to the north between Bristol Temple Meads and Parkway were rerouted through Avonmouth for a couple of weeks and all Severn Beach line local services were cancelled and bustituted. Whilst unpopular with the regulars it was popular with the railfan fraternity as they could travel around the Henbury Loop for the first time in decades.
    I also remember that one day trains were bustituted because either the Queen and/or Phil were visiting Avonmouth by Royal Train so the trains were taken off as a security measure!
  20. MCSHF007
    MCSHF007 Member
    258
    7 Dec 2015
    I doubt whether those with advance tickets/longer term season tickets would be happy with this barmpot suggestion.
  21. ANDREW_D_WEBB
    238
    21 Aug 2013
    Last weekend the Piccadilly Line was closed west of Hammersmith with Heathrow served by coaches. As there was no Oyster / Contactless reader on the coaches the service was in practice free for those wanting to use Oyster / Contactless as a payment method
  22. JonathanH
    4,030
    The idea is that you touch in at the station before you board the bus. It amazes me that after 17 years TfL is still prepared not to seek this revenue when rail replacement is in place particularly given its budget issues.
Share This Page
