Trivia: most circuitous route between 2 stations on same line
PTR 444
22 Aug 2019
Wimborne
The OP stated "2 stations on the same line" (my emboldening).
I don't think Exmouth to Starcross, or Weston to Cardiff, or most other estuaries, really meet that criterion.
Both these pairs are served by the same service though.
DelW
15 Jan 2015
OK, but if you use that criterion, then Penzance and Aberdeen (or, for more trains per day, say Pwllheli and Bham International) are "on the same line".
Of course it's up to the OP how he wants to define it, and from post 29 I think he agrees with you not me :oops:
vlad
13 May 2018
I thought from the thread title that it'd be something like Crewe to London via Stoke, Birmingham and Northampton, as opposed to the direct route via Lichfield.
Esker-pades
23 Jul 2015
Beds, Bucks, or somewhere else
then Vauxhall to Queenstown Road (Battersea) <D :p
If you're talking about the Hounslow Loop, they stop at Queenstown Road 1 stop after Vauxhall. Thus, the 2nd time doesn't count.
If you're talking about the Kingston Loop services, they start on the SWML. Queenstown Road isn't on the SWML (it's on the Windsor Line). So, that doesn't count either.
DynamicSpirit
12 Apr 2012
SE London
I don't somehow think Penzance to Aberdeen will give a very impressive value for the ratio (miles by rail)/(miles as the crow flies) though. :) (Although maybe you could slightly improve the numbers for that one if you allow the crow to tunnel underground in pursuit of a direct line).
If I've understood this thread correctly, 'same line' simply means, not changing trains. On that basis, Vauxhall to Queenstown Road via Kingston is quite a clever answer!
AlbertBeale
16 Jun 2019
Although you can get a direct train from Coryton to Radyr, you can't get a direct train between those Enfield stations
Ah - sorry. From a quick glance at a map, I'd assumed Coryton and Radyr, being on separate branches, had no through connection...
randyrippley
21 Feb 2016
I don't know if it still does, but for years the last Lancaster-Barrow train ran via Morecambe, from which it ran direct to Carnforth via the Hest Bank curve. If you used a boat, Morecambe-Barrow is around four miles, by rail its a lot further - I'd guess at 40?.........though road would be even more
NorthOxonian
Buses & Coaches
5 Jul 2018
Oxford/Newcastle
If we're counting light rail - then this might be the winner indeed. 1km as the crow flies, 29km by rail (38km if you don't change at Monument!)
Manors/Central to Jesmond/St James would be high figures too, though that's a more tenuous example (since for those pairs changing at Monument reduces the distance massively)
gingertom
19 Jun 2017
Kilsyth
Pollokshields east to/from Pollokshields west are only a couple of hundred metres apart but you need to go nearly the full length of the Cathcart circle to get from one t'other. Or go in and back out of Glasgow Central.
USBT
5 Nov 2017
Was thinking Blackfriars to Farringdon via the Circle line - it's almost exactly 1km as the crow flies, no idea how far via the Circle Line (longer via S Ken obviously, but you can't do that without changing these days at Edgware Rd).
EDIT: 5.47km via Aldgate
Ladbroke Grove to Notting Hill Gate are 1 mile apart by road (walking) but about 13.5 miles on the Circle line without changing.
HullRailMan
8 Oct 2018
Driffield to York.
30 miles to drive.
Direct train via Hull and Selby around 72 miles!
It’s even quicker to do this journey by bus than train.
There will be similar variances for Bridlington and Beverley as the more direct rail routes no longer exist.
RLBH
17 May 2018
46 chains shortest possible route by rail, with reversals. 4 miles 56 chains by an actual service train. The train from Pollockshields West to Central actually passes by Pollockshields East on a line with no platforms, and joins the line at a junction just past the station.
DynamicSpirit
12 Apr 2012
SE London
Gravesend to Ebbsfleet on the roundabout Javelin via Ramsgate + Ashford?
2.5 mile walk while the train does 130-odd miles
That's an impressive one! I wonder if an Ebbsfleet to Gravesend ticket would be valid on that long route - since it's obviously absurd to do it that way, but on the other hand it is a direct train.
NorthOxonian
Buses & Coaches
5 Jul 2018
Oxford/Newcastle
I certainly wouldn't try to break my journey on that ticket!
adrock1976
10 Dec 2013
London Underground
Hammersmith and stations to Paddington (Bishops Bridge Road) inclusive - Bayswater.
The Circle Line calls at Edgware Road after Paddington, then continues via Baker Street, Kings Cross, Liverpool Street, Tower Hill, Victoria, and High Street Kensington.
By the time you have gone the long way round the loop on a direct train, it is quicker to either walk from Paddington or change to a via High Street Kensington Circle or Wimbledon District.
Also Paddington Bishops Bridge Road to Paddington Praed Street on the Circle. Again, it is simpler and quicker to exit the Bishops Bridge Road platforms and walk through the mainline station to Praed Street.
National Rail
Cumbernauld - Dalmuir.
These trains run via Motherwell, Blantyre, Bridgeton, Glasgow Central Low Level, Patrick, and Yoker, with a mileage of 34.75 miles and a journey time of 90 minutes. By road via the M80 and A814, the distance is 22 miles with a journey time of 35-50 minutes.
HowardGWR
30 Jan 2013
They most certainly are - and have direct services between them. The trains do not have to reverse either.
ijmad
7 Jan 2016
London Underground
Mill Hill East & Edgware are about 2.5 miles away from each other as the crow flies.
There are many trains per day that leave from one, go down via Charing Cross to Kennington, do the loop and then head back up and to the other.
That's around about a 28 mile trip!
Mikey C
11 Feb 2013
As an example of a "regular journey" Cookham to Marlow is probably twice as long as the direct crow flies route, due to having to go in and out of Bourne End
