[Trivia] Nearest unstaffed station to London Charing Cross
Discussion in 'Infrastructure & Stations' started by Gathursty, 24 Jan 2020.
  1. Gathursty
    Gathursty Established Member
    1,860
    31 May 2011
    Wigan
    What's the nearest completely unstaffed (all day, every day) station to London Charing Cross (what I take as the centre of London) as the crow flies?
    Rail Forums
  3. Mag_seven
    Mag_seven Established Member Associate Staff General Discussion
    5,933
    1 Sep 2014
    here to eternity
    Drayton Green? (or perhaps a station on the DLR if it counts?) Wembley Stadium might be another contender.
    EDIT: OP has confirmed DLR does not apply.
  4. yorksrob
    yorksrob Veteran Member
    22,212
    Beltring ? Either that or somewhere on the North Kent line.
    Or Leigh, going the other way from Tonbridge.
  5. ValleyLines142
    ValleyLines142 Established Member
    5,847
    25 Jul 2011
    Cardiff/Bristol
    St Johns?
  6. Hophead
    Hophead Member
    928
    5 Apr 2013
    South Bermondsey?
  7. FelixtheCat
    FelixtheCat Established Member
    3,418
    23 Jul 2015
    Edinburgh, London, or somewhere else
    That's staffed on weekday mornings.
  8. sharpley
    sharpley Member
    157
    18 Aug 2018
    Lea Bridge?
  9. telstarbox
    telstarbox Established Member
    4,623
    23 Jul 2010
    Wennington Crossovers
    I'm assuming you exclude occasional cleaners and so on. Westferry DLR if that counts?
  10. adrock1976
    adrock1976 Established Member
    2,790
    10 Dec 2013
    An obvious pair would be both the Sudbury (Middlesex) stations along the Chiltern line (the ex Great Central/Great Western section via High Wycombe) due to the very limited number of trains that call there.
    Maybe Northolt Park too?
  11. transmanche
    transmanche Established Member
    6,008
    27 Feb 2011
    It appears there are 27 National Rail stations in Greater London categorised as Category F (Small Unstaffed). But I don't think this list is accurate as some stations listed as category F (such as Canonbury or Clapham High Street) are staffed full-time.
    I think the closest category F station would be Queenstown Road (Battersea), which is less than 2.5 miles from Charing Cross, as the crow flies. But I believe this is a staffed station.
    Other than that, it has to be @sharpley's suggestion of Lea Bridge, at about 5.5 miles.
  12. ValleyLines142
    5,847
    25 Jul 2011
    Cardiff/Bristol
    Thanks for confirming, have only been there in the afternoons.
  13. tsr
    tsr Established Member
    7,401
    15 Nov 2011
    Between the parallel lines
    That's staffed. Although hours seem to vary a bit at the moment.
  14. SlimJim1694
    SlimJim1694 Member
    181
    8 Jan 2020
    Medway
    Birkbeck is most definitely unstaffed
  15. Ian Hardy
    Ian Hardy Member
    42
    18 Nov 2009
    Barnes Bridge - 6 miles from Charing Cross
  16. RDWRER
    RDWRER Member
    30
    4 Apr 2018
    Barnes Bridge or Kew Bridge at a guess
  17. Gathursty
    1,860
    31 May 2011
    Wigan
    I'll exclude cleaners etc... I'll also discount the Tube and DLR. I'm just on about NR stations. These may have interchanges but most of them will be staffed apart from ones like Birkbeck.
Share This Page
