Trivia: non stop services under an overall roof
Tomnot27
28 Feb 2017
Don't TPE services that bypass Darlington use the bypass lines outside the station
Same with York and VTEC flying Scotsman service
61653 HTAFC
18 Dec 2012
Huddersfield used to have (and may still have) a few regularly diverted South TPE services which would run through without calling. Those heading towards Manchester would definitely pass under the trainshed, those for Sheffield would most likely use P8 which isn't under the roof but could use P4 which is.
IanXC
Emeritus Moderator
18 Dec 2009
Nope.
At Darlington TPE run through the platforms non stop, and at York the Flying Scotsman runs through platform 3.
DarloRich
Fenny Stratford
This seems to be a fairly rare occurrence...
I suspect here are some pretty obscure ones, but how many examples can we come up with of a non stop service through a station with an overall roof?
TPE have a few which DISGRACEFULLY pass through Darlington platforms non stop.
Virgin Trains East Coast's Flying Scotsman does York non stop.
Thoughts on some more? I'm looking for long term booked route rather than as hoc diversions.
Fixed that for you! ;)
Wembley Central springs to mind.
Is that a station roof or a tunnel?
The Up Fast at Rugby is under the overall (island) station roof, and there are many non-stopping trains.
It's also possible on the Down Slow but unusual today.
Of course now that there are two outlying platforms outside the original canopy it rather complicates the situation.
There are several stations with extensive roofs which don't quite cover all platforms.
Rugby doesn't have an overall roof by any stretch of the imagination!
IanXC
Emeritus Moderator
18 Dec 2009
It's the extensions of the previous York terminating services. As I understand it there is insufficient time to call at Darlington due to another service behind them.
I'd be surprised if this is not eventually resolved when other work is done on the timetable.
My impression was that they don't have time to call as otherwise they don't meet the minimum turn around time at Newcastle?
Tomnot27
28 Feb 2017
The current 185's can only do 100mph while all other trains that use the line can go at 125mph meaning TPE services are caught up with most services wanting to stop at Darlington and Durham
Crossover
4 Jun 2009
Is there any reason why TPE don't use the through lines at Darlo?
0521 Crewe - Euston which only runs Tuesday, Wednesday and Thursday. It does miss out Milton Keynes though.
A couple of days this week it has been booked via Stafford
Darandio
24 Feb 2007
Nope.
Cannot be every single time though.
A few Saturdays ago, one preceded a railtour (was 47 vice a failed Steam loco) and passed on the down fast, the railtour followed 3-4 mins later on the same line.
Granted, that is the only time i've been there where one was booked to pass.
IanXC
Emeritus Moderator
18 Dec 2009
On that basis would you choose to call at Durham but not Darlington? My impression was it was because the XC ex Reading/Southampton was too close behind - and that it stopping at Darlington gives the TPE time to get far enough ahead to call at Durham.
Presumably they don't sign the route.
Darandio
24 Feb 2007
Until someone who knows TPE route cards comes along we're not going to know - that could have had a route conductor...
Well, that wasn't the service I saw, so that makes at least two. I find it unlikely that they don't sign the fasts, but we'll wait and see.
As those familiar with the area will know, a lot of northbound freight services use platform 4 to avoid conflict with services into platform 1, not because of signing issues. I'd wager this is the same reason.
Crossover
4 Jun 2009
D6975
26 Nov 2009
Bristol
On a down service it means crossing the up line twice. Simpler to stay to the left of it to avoid the possibility of conflicting moves.
Crossover
4 Jun 2009
I'll dig the track map out to see the full layout here to understand why this is the case
D6975
26 Nov 2009
Bristol
Relevent lines only shown.
Taking the northbound red route crosses the southbound (platform) route twice,
Mag_seven
1 Sep 2014
here to eternity
Err what is the point in having the down avoider then? There must be a time penalty associated with having to be routed through the station?
D6975
26 Nov 2009
Bristol
It still gets used, just not as frequently as it did.
It's sometimes used as a passing loop. I've seen freights held there for a few minutes on more than one occasion.
In days gone by there used be many more services that ran non stop through Darlington than nowadays and the mainlines were used much more.
DarloRich
Fenny Stratford
freight mainly although northbound services will often run through the station to avoid the double crossing issue referred to above. Southbound flyers are much more common
More students? Those for the University of Smogland can catch a direct TPE from the Boro.
Mag_seven
1 Sep 2014
here to eternity
Surprised Paisley Gilmour Street has not been mentioned - was admiring it's overall roof today whilst non stop services to/from Ayr passed through.
