Trivia: Shortest freight journey?
Discussion in 'UK Railway Discussion' started by jonty14, 11 Aug 2015.
Thread Status:
  1. jonty14
    jonty14 Member
    199
    3 Aug 2009
    Rottweil Germany
    Just out of interest what is the shortest journey for a freight train in the UK?
    One I can think of myself is the Sellafield to Drigg low level waste train. Any shorter journeys?
    Regards
    Jon
    Rail Forums
  3. Darandio
    Darandio Established Member
    7,654
    24 Feb 2007
    I'd imagine there are plenty tbh. A couple from here, not sure on mileages..
    Tees Yard - Middlesbrough Goods
    Tees Dock - Tees Yard
  4. BRblue
    BRblue Member
    237
    13 May 2015
    Sunny Sussex...
    After a few minutes searching I came up with these two...
    487T 0822 Southampton Up Yard (Fl) to Southampton M.C.T. and
    671I 0525 Swindon Loco Yard to Swindon Cocklebury
    and I would think there are many more similar movements.
  5. dk1
    dk1 Established Member
    8,033
    2 Oct 2009
    East Anglia
    They are strange headcodes.
  6. The Planner
    The Planner Established Member
    9,607
    RTT masks freight headcodes unless you were being facetious.
  7. eastwestdivide
    eastwestdivide Established Member
    1,826
    17 Aug 2009
    For another where the journey is definitely to deliver freight, and not just shuffling wagons around, the Aldwarke-Stocksbridge Works steel trains don't travel very far, just between two Tata steel plants.
    About 13 miles as the crow flies, probably nearer 20 by train.
  8. Pacerpilot
    Pacerpilot Member
    332
    7 Jun 2010
    When we Used to work coal trains between Newport docks and Fifoots PS, the distance between them was around half a mile as the crow flies, across the river Usk. By rail the journey was around 9 miles and took nearly two hours.
    The 4mph limit from the coal pad back to AD Jn didn't help things!
  9. dk1
    8,033
    2 Oct 2009
    East Anglia
    Not trying to be anything. Just never seen other than number-letter-number-number.
  10. Oxfordblues
    Oxfordblues Member
    272
    22 Dec 2013
    Briggs Sdgs-Tunstead in the Peak District must be one of the shortest flows.
  11. yorkie
    yorkie Forum Staff Staff Member Administrator
    45,848
    '487T' and '671I' are meaningless numbers; the real headcodes for freight are not available in the open data used by sites such as Open Train Times, Raildar etc.
  12. deltic
    deltic Established Member
    2,037
    8 Feb 2010
    How long is the route from Boulby Mine to South Bank Tees Dock - its only about 45min freight haul
  13. Pacerpilot
    Pacerpilot Member
    332
    7 Jun 2010
    Stoke Gifford - Avonmouth BBHT comes in at 7 miles.
  14. tsr
    tsr Established Member
    7,375
    15 Nov 2011
    Between the parallel lines
    IIRC GBRf headcodes do show correctly (and some 3xxx maintenance/weedkiller/adhesion trains certainly do too).
  15. DarloRich
    DarloRich Veteran Member
    23,342
    Work - Fenny Stratford(MK) Home - Darlington
    miles too many for the purpose of this discussion - the line is very twisty between Boulby and Saltburn
    Are these not light engine movements?
  16. greatkingrat
    greatkingrat Established Member
    2,170
    20 Jan 2011
    No, the first number of the RTT headcode is accurate so these are class 4 and class 6 trains respectively. A light engine would show as something like 012A.
  17. eastwestdivide
    1,826
    17 Aug 2009
    I'd be interested in narrowing all this down to trains which actually move "stuff" from place to place, i.e. they are loaded at one end and unloaded at the other.
    The OPs Drigg/Sellafield obviously counts, as does the Aldwarke/Stocksbridge, and presumably the Boulby potash is unloaded at Tees Dock. Others? Is Briggs Sdgs/Tunstead just repositioning wagons?
    Going way back, I have a photo from the 1980s of a 12T van labelled along the lines of "To work between Crewe Station and Crewe Stationery Stores only". Not an internal user, but a proper traffic number too.
  18. lewisf
    lewisf Member
    324
    21 Feb 2009
    Kingston/Surbiton
    And yet I thought the Acton to Tolworth stone trains was a short run but several on here already beat that.
  19. 221129
    221129 Established Member
    4,520
    21 Mar 2011
    Sunny Scotland
    Not sure if it still happens but Exeter Riverside - Exeter Alphington Road was a short run.
  20. Mag_seven
    Mag_seven Established Member
    5,695
    1 Sep 2014
    here to eternity
    HOPS train movement?
  21. theageofthetra
    theageofthetra Established Member
    3,134
    27 May 2012
    Is there one which goes from Angerstein Wharf with a load of sand to another part of London?
  22. Boothby97
    Boothby97 Established Member
    1,695
    24 Apr 2011
  23. ChiefPlanner
    ChiefPlanner Established Member
    5,671
    6 Sep 2011
    Herts
    2 I can think of ..
    Aggregate - Chichester - Lavant (now defunct) , and steel exports Llanwern to Newport Docks via East Usk Yard.
    Both "long shunts" - but quite good earners .....
  24. class 9
    class 9 Member
    478
    18 Nov 2010
    Kellingley colliery to Drax power station, only about 20 minutes.
  25. 33056
    33056 Established Member
    2,352
    12 Nov 2007
    On a train somewhere in Europe
    Wembley Yard to Willesden Euroterminal or vice-versa is a relatively frequent one, there is one leaving shortly (real headcode is 6T47).
  26. furnessvale
    furnessvale Established Member
    3,584
    14 Jul 2015
    No. Following the closure of quarrying activity at the Dowlow end, stone is moved by rail from Tunstead so it can be processed in the still active plant.
    The flow even received a section 8 grant for the purchase of new wagons.
Thread Status:
Share This Page
