Trivia: shortest path to reverse a train from a terminus platform
Bristol
Brighton? Out towards Hove, reverse towards Preston Park, back into Brighton?
shortest route for Brighton Looks to be up and down the Brighton Main Line via the loop of Brixton, Stewarts Lane, and Tulse Hill.
If wanting to avoid such a long length of the same route being done twice, it'd be out via Hove, Eastleigh, Wimbledon then the connection to Tooting before following the same loop as before and down from Croydon again. However if you wanted to end up back in exactly the same platform it'd need to be no more than a 4-car from the buffers end of platform 3
dgl
5 Oct 2014
I was thinking about Weymouth and trying to think of where it could do a loop without reversing as I think most turn around options that are the closest would need the train to reverse to get on another line to come back.
pokemonsuper9
20 Dec 2022
Greater Manchester
Would you have to go via Reading and Guildford?
61653 HTAFC
18 Dec 2012
Not at the Rochdale side (although I think there is by Newton Heath depot).
And even if you could use the tram line you then have to go via Huddersfield or Darwen to get back to the platform.
Thanks. Thinking about it, I don't think use of Metrolink would help anyway. So far as I can tell there's no way to "loop" using the two routes across Manchester city centre or anywhere else on the network.
I was hoping to find a clever way of utilising the rule about using other systems... We don't really do loops on our trams though, apart from Blackpool which doesn't have a connection to the wider network. Think there may still be a disused connection at Fleetwood but if my memory serves it required a shunt to access anyway.
Not a booked service, but surely Leeds to Wakefield Westgate, down the line to Kirkgate and then back to Leeds via Woodlesford. There's a few platforms from Leeds you could do that with too.
I suggested that (in the opposite direction, mind) at the top of the previous page.
I selected P13 as a gift to the signallers as it's probably the least awkward to path a train in/out from/to both routes. Your direction works better on that front due to left-hand running putting us on the inner arc of the loop... which as an added bonus probably shortens the journey by a few yards!
pokemonsuper9
20 Dec 2022
Greater Manchester
If there was a connection at the Rochdale side as well Manchester Victoria and Oxford Road would have much shorter loops.
RobertsN
6 Jun 2020
Somewhere over the rainbow
DanNCL
17 Jul 2017
County Durham
Are there any connections remaining between Network Rail and the Metrolink Oldham Loop line? As such a move is permitted by the OP that could make things interesting, though I haven't tried to map anything out in my head.
This got me thinking about the wider Metrolink network. There are three connections off the network, at Newton Heath, Altrincham and Bury. The latter can be taken out of the equation as that only leads to Rawtenstall, which leaves the connections at Newton Heath and Altrincham. Both require long routes although I think Altrincham is slightly better. From Altrincham you’d go to Chester, then onto the Wirral line and around the loop in Liverpool before going back the way you came.
There’s no means of turning round on Metrolink infrastructure without a reversal which means anywhere without a clear run to the two connections (Altrincham, East Didsbury, Airport, Trafford Centre, MediaCityUK and Eccles) are all impossible.
plugwash
29 May 2015
mmm.
The "oldham loop" enters rochdale from the north, but since it was converted to metrolink, it's connection to the mainline in rochdale was severed.
Metrolink has a connection to the ELR in bury, but a reversal on the ELR is then needed to get out onto the mainline.
61653 HTAFC
18 Dec 2012
Thought about Bradford Interchange as a possible short-ish example, but as (I think, correct me if I'm wrong) there's no access onto the Whitehall curve from the (modern) Calder Valley line- so coming from Bramley you'd have to head through Leeds to York, then round the Harrogate loop to then use the Whitehall curve to Woodlesford. Then via Wakefield Kirkgate, Mirfield, Brighouse, and Halifax to get "home".
pokemonsuper9
20 Dec 2022
Greater Manchester
Based on what I can see on OpenRailwayMap you can go from Bramley to Woodlesford (Traksy also agrees), so it's just Bradford Int - Bramley - Woodlesford - Wakefield - Brighouse - Halifax - Bradford.
Bristol
Good point - brain fade! OK, Westbury - Swindon - Reading West - Basingstoke.
If allowing the same route but different tracks, you can do Weymouth by Westbury-Dr Days Jn- Avonmouth-Filton Abbey Wood-Dr Days- Westbury
Bob55G
18 Jun 2021
West Yorkshire
I think that there is direct access from the Calder Valley line to the Whitehall curve. I travel into Leeds from Guiseley, then to Huddersfield on a regular basis, and I'm sure that there is a connecting route. Just checked opentraintimes maps and Google maps and it certainly appears to be the case. Saves you the trip via York !
norbitonflyer
24 Mar 2020
SW London
Croydon does. So Elmers end - Croydon - Elmers End works (there are longer possibilities
Think Kingston Loop would be fine, as while ordinary passenger trains will never go from the same platforms, I believe there are the crossovers to allow them to go from say Waterloo 19 - Wimbledon - Kingston - Richmond - Waterloo 19
Certainly you can, and I have, taken a train from the Windsor side which went via Wimbledon. Most common is when a train from Shepperton has been diverted inbound via Richmond, but is going back via Wimbledon. But a Loop train could do it too.
In my case it crossed from the Down Windsor to the Down Slow using the crossovers near Queenstown Road, but there are other crossing ponts that can be used - the signallers choose whicehever is the least worst option as it affects both fast lines and the up slow.
Dr Hoo
10 Nov 2015
Hope Valley
The winner, surely
Sorry, no. Meridian Water to Stratford by either side of the 'teardrop' is over 5 miles, so a total of materially over 10 miles. The Cathcart Circle from Glasgow Central is shorter in distance and time and available in either direction on a daily basis.
Dash it!
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
I believe that Ilkley’s shortest route is to go via Shipley, Lancaster, Preston, Blackburn, Wakefield Kirkgate and the Whitehall curve to get back onto the Wharfedale line, some 180 miles. Quite a way considering how the interworking around the Shipley triangle means that the units that serve Ilkley change which way they are many times per day.
D365
29 Jun 2012
Huntingdon P1 (south facing bay) is what I am currently musing.
Flying Claret
14 Aug 2014
Blackpool (N&S)-Preston- Burnley-Rochdale-Man Vic-Bolton-Preston Blackpool.
Morecambe, Carnforth, Hellifield, Blackburn, preston lancaster.
pokemonsuper9
20 Dec 2022
Greater Manchester
The Manchester bound platform I think the shortest route would have to go via Eccles, Warrington and Northwich.
I think it would actually be quicker (same applies to Manchester Piccadilly, Victoria, and maybe Stalybridge and Bolton too) to go via Buxton (either arriving/leaving via the Northern or Freight line.
For Stockport, via Denton and Ordsall Chord should work.
Julia
19 Jun 2011
Huntingdon - Harringay Park Jn - Gospel Oak - Richmond - Kingston - New Malden - Clapham Junction - Kensington Olympia - Gospel Oak - Harringay Park Jn - Huntingdon?
Nearly... but the only way back in to Huntingdon P1 without reversal is wrong-line working from St Neots, is that allowed?
Magdalia
1 Jan 2022
The Fens
Is Huntingdon platform 1 still usable?
This can't be done in this direction without a double reversal over the Harringay flyover.
Going through the Thameslink core and round the Sutton loop is the obvious solution, but I think this is a shorter route:
Thameslink core-Loughborough Jn-Factory Jn-Olympia-Kensal Green Jn-Willesden Jn-Gospel Oak-Harringay Park Jn
That's a good point! I think it has never been possible to arrive in Huntingdon platform 1 in passenger service, only by reversing in off the up slow line.
The same discussion could have applied to the old Peterborough platform 1, which was available for arrivals and departures, but when that was open, the Canal Tunnel wasn't.
Hornsey do have a route through the core for turning trains, which they have used for turning class 387s. I can't remember exactly what it is.
Haywain
3 Feb 2013
Isn't a double reversal required at Buxton to access the Peak Forest line?
