Trivia: Stations/Areas where the slow is FASTER than the fast lines?
30 Sep 2013
Weymouth
Of course there are many places now where they are the same speed such as Wandsworth Common, Battersea Park, Queenstown Road etc. But they are in london.
Luckily I surprisingly am adament I know an area of the southern network where I believe the Slow lines have a higher speed limit than the fast. That is: Earlswood. (99 percent sure that is correct but if i am wrong tell me please) earlswood is 90 on the slow and 80 on the fast, likely due to the sharper curve on the fast.
I am sure there are other places on the mainlines where the fast has a lower speed than the slow, but I guess there will only be a few.
DY444
16 Sep 2012
You're wrong about Earlswood. The 80mph limit on the fasts starts to the north of the station and the slow lines have a 75mph limit which starts to the south of the station.
317663
30 Sep 2013
Weymouth
Aw man, sorry :P I swear it Showed 90 on TS2016, but ometimes i suppose that can be wrong also. Apologies.
Ianno87
3 May 2015
Not quite the OPs original question, but there are instances where stopping trains used the Fast Lines and fast trains use the Slow Lines - Bromley South is one example, and Clapham Jn-Barnes (Down direction) spring to mind.
rower40
1 Jan 2008
Again, not quite the original question, but...
On those occasions when Paddington is shut, and trains terminate and reverse at Ealing Broadway, then the HSTs use the Relief lines, and the local services use the Main lines. Cue lots of switching from one line to another at the Southall crossovers.
This is because the Relief line platforms at Ealing Broadway are much better suited to handling an entire HST of passengers all trying to get to the Underground at once.
Trog
30 Oct 2009
In Retirement.
The Dn Northampton Fast through Northampton Castle Station is 20MPH, the Up and Dn Slow at the same place is 30MPH.
DY444
16 Sep 2012
That tells you all you need to know about the accuracy of many of the routes on TS2016, indeed the whole track layout at Earlswood is wrong as both sets of Fast/Slow crossovers are missing.
30907
Which happened because in 1959 someone decided that Boat Trains were faster than Kent Coast trains (they didn't stop at Bromley South!) - previously Up Boats had used the Up Local! Particularly odd at Swanley, but I guess it was an arbitrary decision - and until the Shortlands Diveunder was built half the stoppers used the Slows anyway.
317663
30 Sep 2013
Weymouth
I always get confused about the Clapham-barnes actually. I originally thought the middle platforms were slow, but I believe now it's
>fast>
>slow>
<fast<
<slow<
Am I correct?
Crossover
4 Jun 2009
I believe I have read on here before that this situation exists at Edge Hill, where the fasts have a lower limit than the slows
The Up Slow out of Lime St (Chat Moss line) is 40mph, while all the rest are 30mph.
It means a Pacer on the Slow can overtake a Pendolino on the Fast!
Maybe about to change (and be faster on all lines) with the upcoming remodelling through the area.
NR has recently eliminated the situation at Reading where the straight/original Reliefs (75mph) were faster than the curved/later Mains (50mph).
However there is a new anomaly on the WCML at Colwich where the Down Fast turns out into the Down Crewe at 65mph.
The adjacent Down Slow (was the original Down Fast until TV4) still runs directly into the Down Crewe at 90mph.
DY444
16 Sep 2012
The situation exists through Platforms 8 - 11 at Clapham Junction. UMF is 40, DMF is 50, UMS and DMS are both 60
>fast>
>slow>
<fast<
<slow<
Am I correct?
The Clapham Junction to Barnes section's operational usage is not the same as the line names.
The down pair is used the opposite way round to the line descriptions, the sectional appendix shows it in the conventional way with fasts in the middle DS, DF, UF, US.
Swapping round the services that use the down fast and down slow lines simply keeps slower trains via the loop out of the way of fast trains via Richmond. It isn't necessary to do this in the other direction.
DY444
16 Sep 2012
Although the limit on the mains at Reading was higher back in the day - can't remember exactly what now but 80 rings a bell on the up through possibly 75 on the DM. The 50mph limit appeared about 25 or so years ago.
driver_m
8 Nov 2011
Very short stretch at Edgeley on downs where fast is 40 but slow is 60. Primrose Hill tunnel nr Euston, 55 fast, 75 slow.
paul1609
28 Jan 2006
Wittersham Kent
When I used to commute (1986 to 90) to London the Up Slow at least was 90 until north of Earlswood station, there then followed a long period where the crossover from the fast lines had a 40 mph TSR. When the TSR was rectified the down slows through the station were reduced to 75!
16 Sep 2013
There is a good example between Horbury Junction and Wakefield Kirkgate. From Horbury, the Down Slow is 60 until just before Kirkgate (just after the line passes under the Doncaster Lines) into Wakefield Westgate, although there is a short section where the line speed is 40 (for no obvious reason). The Down Fast was until recently believed to be (by all TOCs) 60 from Horbury until just beyond the Doncaster Lines. However, it seems that Network Rail have become (re)aware that in fact the 60 line speed does not take effect until some considerable distance after Horbury Junction, and have (re)imposed the correct 20mph limit on this section of line (again this has no obvious reason to be so low - until earlier this year trains would accelerate as soon as they joined the Down Fast).
Ianno87
3 May 2015
Yes, it's so so that sropping trains towards Brentford/Hounslow can "turn right" at Barnes without needing to re-cross the path of faster services via Richmond.
samuelmorris
18 Jul 2013
Brentwood, Essex
Liverpool Street to Stratford - the slow services are timed for 7 mins, the fast 8-10. I think the speed limits are the same though.
Crossover
4 Jun 2009
I wouldn't take timings as the key to this - it is quite possible that the fast service has more recovery time in the schedule
Cherry_Picker
18 Apr 2011
Tangential but I believe the up Bicester is faster than the up main at Aynho Junction. Willing to stand corrected on that one.
adrock1976
10 Dec 2013
Something I have just thought of here.
With the unusual layout of the tracks of the Metropolitan Railway between Baker Street and Wembley Park, do the outer pair (fast lines) have a higher, lower, or the same linespeed as the centre pair (slow lines/Stanmore Branch)?
