Trivia: Stations With A Small Number Of Terminating Services (But *Not* Zero)
Discussion in 'Allocations, Diagrams & Timetables' started by tbtc, 14 Jul 2019.
  1. FelixtheCat
    FelixtheCat Established Member
    2,829
    23 Jul 2015
    Edinburgh, London, or somewhere else
    Yep. 08:15 from Glasgow Central, arrives at 09:00. Returns at 09:07.
  2. Iskra
    Iskra Established Member
    2,463
    11 Jun 2014
    Chapeltown, Sheffield
    Goole- most services pass through, but it has a handful of Leeds terminators
  3. Iskra
    2,463
    11 Jun 2014
    Wakefield Kirkgate has one only at the end of the day from Huddersfield, all others continue through to Castleford now and all other services run through.
  4. John C
    John C Member
    111
    3 Dec 2011
    Carstairs has a small number of ScotRail service which start/terminate to/from Garscadden and Anderston.
  5. vlad
    vlad Member
    369
    13 May 2018
    Macclesfield has a couple of Northern stoppers to/from Manchester terminate in platform 3 each day - all the rest continue on to Stoke.
  6. John C
    John C Member
    111
    3 Dec 2011
    Beverley is also one which has a couple of Northern service starting/terminating in the AM and the late evening, remaining services run through to Bridlington and Scarborough. Also some Hull Trains from London Kings Cross start/terminate here.
  7. FelixtheCat
    2,829
    23 Jul 2015
    Garscadden has a few which then return to Yoker depot.
  8. t_star2001uk
    t_star2001uk Member
    633
    23 Aug 2011
    Bicester North has 3 terminators in the Monday to Friday timetable...
  9. 221129
    221129 Established Member
    4,119
    21 Mar 2011
    Sunny Scotland
    St James Park has 2 services a day that terminate.
  10. 700007
    700007 Established Member
    1,058
    6 May 2017
    Near a bunch of sheds that aren't 66s.
    Broadstairs has a few services terminate during the High Peak from St Pancras and Victoria (?)
    Harwich International has a small, irregular offering of 'boat trains' from London and Ipswich terminating.
  11. hexagon789
    hexagon789 Established Member
    6,282
    2 Sep 2016
    Cheers, I wonder why they don't extend it to the Harbour.
  12. gazthomas
    gazthomas Established Member
    2,717
    5 Jun 2011
    St. Albans
    Avoids cluttering up Guildford
  13. thenorthern
    thenorthern Established Member
    3,465
    27 May 2013
    Sellafield has a single train per day that terminates there on weekdays, Ambergate has one train per day that starts there.
  14. FelixtheCat
    2,829
    23 Jul 2015
    There wouldn't be enough turnaround time if it continued to Ardrossan Harbour. 7 minutes is quite tight as it is.
  15. Bletchleyite
    Bletchleyite Veteran Member
    42,253
    Up and down the south WCML (mostly)
    The other end of that (in the morning peak) used to terminate at Greenbank - does it still?
  16. Bletchleyite
    42,253
    Close to home... there are only a few LNR mainline services which start/terminate at Bletchley, though since the new timetable I couldn't tell you what they are.
    I guess the Marston Vale knackers it as far as this thread goes, though.
  17. wellhouse
    wellhouse Member
    303
    4 Oct 2009
    West Yorkshire
    Marsden has 3 terminators that run non-stop from Huddersfield in the evening peak. They wait for a while and then continue towards Manchester with new headcodes.
  18. snookertam
    snookertam Member
    295
    22 Sep 2018
    Does Markinch have the sole originating and terminating train to/from Glasgow Queen Street?
    Kilwinning has one weekday service that originates there to run to Glasgow Central, although no corresponding terminatiing service (not what the OP asked tbf). Prestonpans similar with Edinburgh.
    One service daily terminates/originates at Irvine to/from Glasgow Central, instead of running to Ayr.
    New Cumnock has one daily service that terminates from Glasgow Central, with Auchinleck having one originator back to Central.
    Dalmally has one train terminating and originating to/from Oban on school days.
  19. John C
    John C Member
    111
    3 Dec 2011
    Shipley has x3 terminating services each weekday evening starting with the 20:30 Bradford Forster Square to Shipley then hourly give or take the odd minute with the last being the 22:25 from Bradford. All use platform 5.
  20. Killingworth
    Killingworth Established Member
    1,491
    30 May 2018
    Sheffield
    OK, I feel sorry for Chathill which only has two services a day Monday - Saturday, both of which start and finish there, average number of passengers per train under 2.
    It's a nice walk to Seahouses and Bamburgh, but not much else nearby unless you farm there.
  21. hexagon789
    6,282
    2 Sep 2016
    Fair enough, presumably it runs in a non-standard slot.
  22. Idon'tKnow
    Idon'tKnow Member
    117
    20 Aug 2016
    Staffordshire
    Hednesford has only one timetabled train terminating there in the very early morning at 00:07 (23:18 from New Street), but with the unreliability of LNR's timetable you're likely to see more throughout the day terminating there instead of Rugeley.
  23. snookertam
    snookertam Member
    295
    22 Sep 2018
    Has to get out of the way of the 0833 from Central to Ardrossan Harbour, which is the connection for the 1000 Arran ferry.
  24. M28361M
    M28361M Member
    306
    15 May 2014
    Some examples from Merseyrail:
    Birkenhead North and Birkenhead Central each have exactly one terminating service:-
    • The 0807 Chester to Birkenhead North via Liverpool loop
    • and the 0752 Chester to Birkenhead Central via Liverpool loop (both Mon-Fri only)
    Sandhills has one service which terminates there:-
    • 2306 Hunts Cross to Sandhills (Sundays only)
    Hooton has two terminating services:-
    • 1603 Moorfields to Hooton (M-F only)
    • 2330 Chester-Hooton (daily)
    Hamilton Square is another one:-
    • 2319 Ellesmere Port to Hamilton Square via Liverpool loop (daily)
  25. mm333
    mm333 Member
    396
    28 Aug 2008
    Goole has only three terminators, the two from Leeds via Whitley Bridge and one late night arrival from Doncaster. Everything else passes through after calling.
    Since the Huddersfield-Wakefield Kirkgate services were extended to Castleford, there are now just two services that terminate at Kirkgate. The last train in from Huddersfield doesn’t go any further, neither does the 0003 arrival from Sheffield via Barnsley.
    Until the Canal Tunnels opened, there were one or two late night Kings Cross-Finsbury Park services, which I’m sure were the only services to terminate at FPK.
  26. GW43125
    GW43125 Established Member
    1,870
    8 Dec 2014
    Three starters in the morning, three terminators in the evening. There's an exit from Ramsgate depot facing Broadstairs which makes it easier (saves doing a double shunt at Ramsgate)
  27. GW43125
    1,870
    8 Dec 2014
    Winchester seems to have two starters (one in the morning and one in the evening) and two terminators Mon-Fri.
    Caerphilly also only has four terminators.
  28. methethpropbut
    methethpropbut Member
    172
    25 Apr 2017
    South Ruislip has the one starter every weekday at 10:55 to West Ealing :)
  29. gnolife
    gnolife Established Member
    1,635
    4 Nov 2010
    Johnstone
    Theres a (I think) 1604 train from Glasgow that terminates at Irvine. Theres also a service on Saturdays that terminates at New Cumnock, with the return working starting at Auchinleck
  30. plugwash
    plugwash Member
    45
    29 May 2015
    There is one train a week from Stalybridge to Stockport and back, does anything else terminate at stockport in regular service? (it's quite common to see trains late night trains from Manchester terminate at stockport during engineering works)
Share This Page
