Trivia: Steepest Gradient?
matchmaker
8 Mar 2009
Central Scotland
aka the Middleton Incline :)
Yes. 1 in 8!!!! But rope worked.
http://en.wikipedia.org/wiki/Cromford_and_High_Peak_Railway
Wikipedia said:
Across the plateau, since the line had been built on the canal principle of following contours, there were many tight curves, which in later years were to hamper operations. Not only did the C&HPR have the steepest adhesion worked incline of any line in the country, the 1 in 14 of Hopton, it also had the sharpest curve, 55 yards (50 m) radius through eighty degrees at Gotham.
Taunton
1 Aug 2013
Liverpool James Street to Birkenhead Hamilton Square is 1 in 27 on both sides, which I believe is the steepest on the national network.
34D
9 Feb 2011
If we were talking modern EMU's what would be the theoretical maximum they could achieve?
I realise this will be different from a standing start and with a run-up
SWTH
12 Mar 2013
Shrewsbury/Porthmadog/Exeter
The Welshpool and Llanfair has that beat. Golfa bank is a mile of 1 in 29, still regularly worked by steam.
True, although I'd argue that the sheer length of the climb between the Aberglaslyn Pass and Pitts Head (over six miles averaging 1 in 40) makes it just as much of a challenge, if not more so.
73001
2 Jun 2010
There's an article somewhere that I read about the 507s being tested when they first came to Liverpool. They had half of the traction motors switched out and then performed a standing start on one of the steepest sections of line. They managed it although a fair bit of heat was generated. Presumably much steeper though and you start to get wheel slip etc.
Whistler40145
30 Apr 2010
Lancashire
Does Shap qualify whereby a train climbs from Tebay upto Shap Summit or Beattock, which is another long climb?
fowler9
29 Oct 2013
How steep is that climb heading from Bury Bolton Street on the East Lancs Railway to Heywood out of interest?
Shap is 1 in 75 from the south.
Beattock is similar (also from the south) but peaks at 1 in 69 over a short distance.
Slochd is 1 in 60 (several sections).
Copy Pit is 1 in 65, often overlooked.
The South Devon banks are 1 in 38 (Dainton), 1 in 45 (Rattery), and 1 in 42 (Hemerdon).
On the Mersey Railway, I think the 1 in 27 is on the Liverpool side which is slightly steeper than the climb to Birkenhead.
The climb out from Green Lane to the BJ main line is also very steep but I haven't found a figure for it.
oddiesjack
11 Jan 2012
High Peak
It's sort of a tramway now and other systems have steeper climbs Is the reason. It's a bit steep. Anyone know the ratio?
The Werneth Incline wasn't on the section taken over for Metrolink, but on the line from Middleton Junction to Oldham, which closed in 1963/4. Ir was 1 in 27 and used to be the steepest route in the UK for passenger trains.
The line that the tramway now follows up as far as the site of Werneth Station was the easier-graded route that left the Oldham-Rochdale main line at Newton Heath. Where Werneth station was, the trains now take a very sharp left turn as part of the diversion into Oldham town centre proper.
Surprised Oddiesjack hasn't yet mentioned Chinley to Peak Forest, that must be a rather steep incline?
Mostly 1 in 90, with a bit of 1 in 87 near New Mills.
Woodhead was mostly shallower than 1 in 100 but there was a bit of 1 in 70 near Guide Bridge (still in use).
In that neck of the woods there was the steeply graded Cromford and High Peak which was rope worked in places (1 in 7 max).
The later linked freight line from Buxton to Hindlow, still in use, is also pretty steep with sections of 1 in 60.
Bevan Price
22 Apr 2010
It's actually the 1:27 on the climb up from
River bed in the Mersey tunnel.
The profiles actually show short sections at 1 in 26, in addition to longer sections at 1 in 27.
On former BR freight lines, Hopton Incline (Cromford & High Peak Railway) was 1 in 14.
Whistler40145
30 Apr 2010
Lancashire
Raven's Rock Summit on the Kyle line has a gradient of 1:50.
I also wonder what the gradient on West Highland line is from Helensburgh Upper to Glen Douglas?
61653 HTAFC
18 Dec 2012
Another planet...
It's not as long as many already mentioned, but Greetland Junction to Salterhebble Junction (used by services from Brighouse to Halifax) always looked pretty steep...
civ-eng-jim
16 Jul 2011
Derby
I was having a discussion with a colleague regarding train performance on inclines. He mentioned back in the days of steam and diesel loco hauled passenger trains, a train may start the incline at, say 60mph and barely scrape 20mph nearer the top.
On the long climbs today, do trains still struggle to maintain their speed up an incline? Voyagers on Lickey or Pendolinos on Shap?
Deepgreen
12 Jun 2013
Betchworth, Surrey
Yes, that was regarded as Britain's steepest adhesion-worked gradient. I remember a visit when I was a child with my father and a five brake van special was double-headed by J94 0-6-0Ts and had to be split into two sections to breast the summit!
Philip C
21 Feb 2013
The gradient appears to be 1 in 36 eastbound and 1 in 41 westbound. With little scope for approaching the ramp at speed this must be quite a challenge.
Taunton
1 Aug 2013
The Great Western built a standard style of coal stage which had a ramp at one end. From what I remember the one at Taunton was said to have a gradient of about 1 in 12. There's one still extant at Didcot museum depot, but the gradient there looks less than the one at Taunton, which had to fit a very confined space.
It was shunted by a 57xx Pannier Tank which pushed up one coal wagon at a time, and only had a short run up before. Full gear and full regulator, but often with big slipping and especially in wet weather it wouldn't make it first time round. Huge noisy slipping which could be heard across half the town, especially given that the loco would tend to see-saw going over the crest. Some crews were better at it than others.
Tobbes
12 Aug 2012
I was on the train to work and the section of the ELL extension heading south from Surrey Quays past the Milwall FC ground is marked as 1 in 30m - as a passenger it certainly feels steep. If I understand the history correctly, this is an old alignment being reused, but is it the steepest built in recent years?
