Trivia: Tickets that are impossible to use
Panceltic
2 Nov 2012
Manchester
Just had a look at the Ardwick to Manchester Piccadilly Off-Peak Day Return (£3.50)
Ardwick to Piccadilly has one service daily (Mon-Sat) at 0716
Piccadilly to Ardwick has one service daily (Mon-Fri) at 1657
It is impossible to use the Off-Peak Day Return since it is only valid from 0930 to 1600 and after 1830 (Mon-Fri).
Are there any other situations like this floating in the system?
Thanks
miklcct
2 May 2021
Cricklewood
How about Drem - East Linton? Is this ticket valid by anything other than the direct route (which no services call at both station)?
Mcr Warrior
8 Jan 2009
The particular Off Peak Day Return that you mention, would, I think, be valid on a Bank Holiday, if the trains run.
Mcr Warrior
8 Jan 2009
Isn't Northern on of the operators which generally runs a Saturday timetable on bank holidays?
National Rail timetable planner currently showing the 0716 Ardwick->Manchester Piccadilly service as running on Wednesday 1st January 2025, as well as the return afternoon working. Whether it does, remains to be seen.
Panceltic
2 Nov 2012
Manchester
I can't see the return service on 1 January.
But you are correct about the restrictions, they seem to be lifted for bank holidays (according to brfares.com) - seemingly to no practical effect as there aren't any return services!
Come to think of it, a Manchester-Ardwick Day Return is totally unusable.
Kite159
27 Jan 2014
West of Andover
I wonder how many customers buy tickets to Ardwick solely to bypass the barriers at Manchester Piccadilly. Assuming that is the cheapest ticket.
Bit of a stupid idea seeing that at most times of day, it will be obvious what you are doing.
A ticket to Manchester Oxford Rd - or indeed an Advance ticket on a local Northern service - may well be cheaper anyway.
pokemonsuper9
20 Dec 2022
Greater Manchester
Day returns from Reddish South or Denton to Guide Bridge or Stalybridge.
(the only return possible from those two stations is to Stockport)
Probably a mountain more with those two stations.
infobleep
27 Feb 2011
If you bought the off peak return, which is the same price as the any time single, at £3.70, and got delayed, you wouldn't get a much delay repay.
You'd need to buy it on a ticket machine that doesn't use journey planners or allows you to bypass such a thing.
island
30 Dec 2010
I think it used to be the case that doing a day return between the furthest reaches of the Network Railcard zone (and starting after 1000 as one must) was not doable. Exeter St Davids to Walton on the Naze with a Network Railcard is (just) doable nowadays, but you have a mere 5 minutes before having to turn around and come back.
Haywain
3 Feb 2013
Except that from Exeter St David's you can start at 08:23 with a Network Railcard, which means you could have a whole 2 hours in Walton on the Naze.
A S Leib
9 Sep 2018
More pointless than unusable, but Heysham – Morecambe and vice-versa has off-peak and anytime day returns. The only weekday service at Heysham gets there at 13:08 and leaves at 13:21, making the anytime fare pointless.
Eccles Road – Norwich on weekdays requires an anytime ticket; the off-peak's valid from 08:45 and 06:56 and 07:57 are the only morning departures.
Mcr Warrior
8 Jan 2009
And why any Anytime (or Off Peak) Day Returns from Heysham Port to/from Morecambe? You're not going to be getting back to Heysham Port the same day by train!
ServerHoster
15 Jun 2019
North West
Denton/Reddish South to Brigg/Kirton Lindsey - Anytime Single
Denton and Reddish South only get trains on Saturdays. An Anytime Single is valid for 2 days (so on the Saturday and the Sunday)
But Brigg and Kirton Lindsey only get trains on Mondays to Fridays.
In the other direction, it is possible if you start from Brigg/Kirton Lindsey on a Friday, sleep overnight in Stockport then continue to Denton/Reddish South in the morning.
A S Leib
9 Sep 2018
There's an off-peak return from Polesworth to Coombe Junction Halt, which is unusable except on Saturdays (can't be used before 09:30, only train at Polesworth at 06:48). This probably applies to most off-peak CrossCountry fares from / to Polesworth.
I think the Polesworth – Tamworth fares are even stranger. There's
  • Anytime day return (how do you return?) for £22.40
  • Off-peak day return (not valid before 08:59) for £15.90
  • Anytime day return not via Birmingham (how do you return, and how would you go via Birmingham without going via Tamworth?) for £4.20
  • Anytime single any permitted (again, no way to go any route except directly) for £14.10
  • Anytime day single not via Birmingham for £3.40
Fermiboson
7 Jan 2024
Oxford/London/West Yorkshire
Same is true of day return routed not via Manchester for Guide Bridge to Stalybridge. Equally pointless is of course the seven day season ticket available for the same.
kieron
22 Mar 2012
Connah's Quay
It's valid on the shortest route served by a regular passenger service (Drem-Wallyford-East Linton), and on direct trains to and from the common routeing point (Drem-Edinburgh-East Linton).
There are no direct Drem-Newcastle trains, so it isn't valid in that direction.
The ticket is usable. It lets you break your journey, so you can use most of the validity the ticket gives you and just miss out the Polesworth-Tamworth and Atherstone-Polesworth bits if you can't travel at the weekend.
A Polesworth-London Euston super off peak single forbids break of journey, so can next be used on 23rd December.
JoeM1V
10 Sep 2019
Fort William to Glasgow, super off peak day return. The first valid outward train gets into Queen St after the last valid return train departs.
Still worth buying on occasion though as it’s cheaper than any of the non-Advance singles
Tutbury and Hatton to Rugeley Trent Valley has no permitted routes, since RDG messed up the shortest route data. Many TOC sites say there are no journeys available. Some sites sell a combination of tickets (Chiltern's site is particularly misleading for such journeys)
York to Stafford route Any Permitted is superfluous, as it is priced by XC to be valid via Tamworth (& Birmingham) however has no permitted routes that way.
Kite159
27 Jan 2014
West of Andover
I guess the RDG has included the (mostly) freight only line between Lichfield & Burton into their calculation for Tutbury - Rugeley
On the route via Burton, the data also deems there to be a link between Willington and Peartree - ignoring the fact that the XC services via Burton don't stop at Peartree, so you have no choice but to double back between Peartree and Derby.
On the route via Stoke, the data includes mileage from Stone to Rugeley via Hixon, but it isn't sufficiently granular for journey planners tombe able to work out that you can't actually get a train from Stoke via Hixon that calls at Rugeley.
So in essence the data is misleading and makes it appear like the only feasible routes (via Derby or Stafford) are more than 3 miles longer than the shortest route.
philthetube
5 Jan 2016
Possible, though unlikely, that people may want to meet friends/family off the ship.
