Trivia: trains scheduled to call at the same station consecutively
Discussion in 'Allocations, Diagrams & Timetables' started by Malcolmffc, 7 Apr 2019.
  1. Malcolmffc
    Malcolmffc Member
    215
    19 Mar 2017
    Today, SWR was running trains from Waterloo to Reading via Wimbledon, reversing at Virginia Water. The PSA actually announced two consecutive stops at Virginia Water (at different platforms), as reflected by the timetable:
    http://www.realtimetrains.co.uk/train/W91570/2019/04/07
    Just wondering if such timetabling happens in normal use anywhere? To be clear, I’m well aware there are many trains that go through the same location more than once non-consecutively.
    Rail Forums
  3. yorkie
    yorkie Administrator Staff Member Administrator
    40,802
    The only one I can think of no longer seems to run, and was from Wick/Thurso or Kyle of Lochalsh through to Aberdeen, calling at Inverness twice.
  4. Bletchleyite
    Bletchleyite Veteran Member
    35,952
    Up and down the south WCML (mostly)
    All Far North services call at Georgemas twice. Or does the OP require different platforms?
  5. Kite159
    Kite159 Veteran Member
    12,377
    27 Jan 2014
    West of Andover
    Wouldn't that be like the Saturdays only Kyle - Elgin service which takes the station avoider to reverse at the junction to call at Inverness (P1-P4) before carrying on towards Aberdeen?
  6. Mag_seven
    Mag_seven Established Member
    4,187
    1 Sep 2014
    here to eternity
    But not consecutively - a call at Thurso is in between the two calls at Georgemas.
  7. yorkie
    40,802
    The OP has specifically excluded that scenario.
    It could be that one I am thinking of which used to call at Inverness twice; maybe it used to go to Aberdeen or maybe I just imagined that. Anyway I have found the one you mentioned: http://www.realtimetrains.co.uk/train/G88270/2019/05/18/advanced but it no longer calls at Inverness twice. I am sure it used to though!
  8. TEW
    TEW Established Member
    5,035
    16 May 2008
    In the past when Reading trains have been diverted via Wimbledon the first call has been set down only and the second pick up only which leads to a slightly less bizarre display on the CIS. On the other hand I have seen the CIS at Waterloo advertising not only both stops at Virginia Water, but also a call at Virginia Water Signal F491 before.
  9. HamworthyGoods
    HamworthyGoods Member
    82
    15 Jan 2019
    It’s anywhere that involves a shunt mostly during engineering work. Trains for example have often called at Stevenage twice during SLW caused by engineering work.
  10. 700007
    700007 Member
    718
    6 May 2017
    Near a bunch of sheds that aren't 66s.
    There was a case during engineering works a few weeks back at Lewes where trains were diverted to run London - Lewes - Brighton, I believe calling at Lewes twice.
  11. adrock1976
    adrock1976 Established Member
    2,396
    10 Dec 2013
    One that I can recall when on one of my rare ventures south of the mighty Thames is that there was engineering works between Kingston upon Thames and Raynes Park closing the line.
    The timetable was parts of local services cobbled together, meaning that the Shepperton trains from Waterloo were running via Hounslow to Kingston, then reversing direction to continue to Shepperton calling at Teddington a second time. That is the closest example I can come up with, although what I have described here is similar to Georgemas Junction between Thurso and Wick as mentioned above.
    Many years ago when there used to be track from the present day Fishergate Centre next door to Preston station running to Rostock Hall, this formed a balloon loop with the present day line that runs from Blackburn to Preston, which converges with the line from Ormskirk. I remember reading an article somewhere that in the days of steam locos, trains from points north of Preston heading to Blackpool would turn round via the balloon loop so as to switch platforms from one side of the station to another, and also saving the need for the loco to run round.
Share This Page
