Up to 1976, there was Alston, on a branch from Haltwhistle.
I believe that throughout most of rail history there was only ONE mainland Great British station which required THREE changes to reach London. Anyone know which?
Presteigne it was! Give the man a cigar!
From 1875 to 1951 Presteigne had 3 trains a day, but they only went to Titley Junction or Kington. From there you joined the mighty express from New Radnor to Leominster, but even at Leominster there was never a through train to London.
Until the sixties, they ran trains like the Lakes Express and the Cambrian Coast Express, which divided en route to give a huge number of branch line stations a direct train from London.
Which makes me wonder .. Which departure from London went to MOST stations? I am sure somebody must have thought of this question before, but I've never seen it.
The OP's question was the minimum changes required from London, so no cheating by starting from a non-optimal terminus.Depends on where in London you go from, me thinks. Not many need two from Paddington down to the Westcountry, but from Waterloo you'll need two changes to get on the Cornish branches.
The Atlantic Coast Express from Waterloo must be a contender. BTW, do you mean the most destinations, or the most stations in total (i.e. en route as well)?
Cancel that - I think the Birmingham train actually splits at Machynlleth with part going north to Pwllheli and the other part south to Aberystwyth
At the time of closure in 2009, the Oldham stations on eastern side of the Oldham Loop would have needed two changes for London.
True enough, but prior to May 2000 the prospective London-bound Oldhamite (or whatever the term is!) would only have needed to change at Rochdale. Although I suspect that most preferred to make multiple changes rather than go all that way on a 158!
All stations on Merseyrail's Northern Line apart from Liverpool South Parkway, unless you count walking from Liverpool Central to Liverpool Lime Street (rather than changing at Moorfields and Liverpool Lime Street) as a single change.
