[Trivia] Unused Features in rolling stock?
klambert
11 Sep 2008
Aldershot, Hampshire
The prototype HST power cars had (have) a driving cab at the "blunt end" too. I seem to remember it was mooted they could be used on overnight parcels/newspaper trains.
Someone mentioned HST usage on freight trains?
I don't know if it's been photoshopped or real, if it's been shopped, they've done a good job. *edit: I definitely think it's shopped.
This is the rear cab on the Prototype, which I think was also incorperated on the production HSTs.
tsr
15 Nov 2011
Between the parallel lines
The conductor signal to the driver is unused on the Southern 455's.
It really, really isn't.
It's used every time a 455 works between Dorking and Horsham, and between Leatherhead and Guildford. Those routes are yet to be cleared for DOO, in the former case only for stock still without bodyside cameras.
Plus you'll find the odd Metro service elsewhere which still pops up on conductor diagrams. Lastly, Selhurst conductors still have to do route learning on them from time to time, again on whichever Metro services are required, which includes full dispatch competency.
I'll freely admit that the bells sometimes think they're not used and therefore don't work very well...
dubscottie
4 Apr 2010
100% photoshopped. That was in "The Railway Magazine" many moons ago as an example of not what to send them for publication.
I read somewhere that the 317's had a "fail soft" system when first introduced on the Bed-Pan route. In DOO, the train would continue to the next station if the driver passed out etc.
Was it ever used?
CyrusWuff
20 May 2013
Chiltern's 168/2s and 172s have Guards door control panels by some of the saloon doors (one per side in each vehicle), though I don't believe they're connected up.
Staying with the 168s, they also have an on-board wheelchair ramp in a cupboard by the accessible toilet, but these are rarely (if ever) used, with station ramps being preferred.
Was it ever used?
(Checks date, nope not April yet).
I hope not. Sounds dangerous to me.
Matt Taylor
31 Aug 2008
Portsmouth
The hand dryers on 700s are tripped out of use due to a revision of the safety precautions taken after the fire on 377442 at Eastbourne, which may have been caused by faulty/degraded hand drier wiring. Whether they will be replaced with another variant remains to be seen...
SWT have also isolated the hand dryers on Desiros for the same reason.
The destination blind above the gangway doors on the class 442s were only used for a very short time before it became clear they hopeless.
In the cab of every Class 444 and Class 450 on the secondmans side is a Nokia phone handset (akin to a Nokia 1610) none of which have ever been used I don't think.
J-2739
30 Jul 2016
Interesting, the Nokia handset feature. What was it supposed to be used for (I'm guessing not making a phone call to your mum as that will be quite distractin!;))
Class455
19 May 2016
I see, I've personally never heard them but I've only used them to Caterham/Tattenham Corner and on the Sutton line so that's probably why. Whilst the SWT ones are never DOO and the bells are always pressed.
18 Feb 2015
Haven't seen any class 380s doubled up since testing, 7 years ago (crikey, 7 years already!). I guess the gangways only purpose is to impede the driver as much as possible.
380s run in 6 and 7 car formation every single day of the week on Ayrshire and Inverclyde services. Also run as a 6 to North Berwick on a Saturday for some services.
satisnek
5 Sep 2014
Kidderminster/Mercia Marina
It was difficult to obtain low-voltage DC from higher-voltage DC until the advent of affordable power electronics, as transformers only work on AC. The traditional way of lighting trams was to connect light bulbs in series so their total voltage rating was the same as the line voltage. I expect the same was done for older third rail EMUs.
I think you'll find that the rotary convertor (or motor-generator set) came in long before power electronics :) I believe that the 1938 tube stock was the first to have these in the UK, the 1951 EPB stock was the first on the SR, don't know about other EMU stock.
satisnek
5 Sep 2014
An obscure one is the auto-announcement system originally fitted to the Mark 2d stock introduced on the ECML in the early 1970s. In those pre-digital, pre GPS days it used a tape cartridge with the announcements ("We will shortly be arriving at..." etc.) recorded sequentially (presumably separated by cue tones, perhaps on another track?) and an axle revolution counter to calculate the mileage and hence the point at which to play each announcement. From what I have read, it wasn't perfectly reliable and didn't last long in service. The rest of the PA system, including the guard's microphone, however, was obviously a highly successful innovation...
SpacePhoenix
18 Mar 2014
The guards/parcels area on 442s (before they got converted to seating areas for Gatwick Express). I can only remember ever seeing used for bike storage
ert47
28 Feb 2010
Speaking of the original trams, the Request Stop buttons are being removed as they're refurbished.
They're being removed on the original CR4000 trams, but the buttons are available on the newer Stadler trams and they wont be up for refurb for a while..
Ash Bridge
17 Mar 2014
Stockport Cheshire
That would be the Ripper Robots Ltd. Auto-Navigation System, it was also set to play music over the mk2d's PA speaker system when the train was standing in the station, l can remember once a Deltic hauled service at York that had arrived from Kings Cross, walking past the open doors music could clearly be heard playing over the vestibule area speakers.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Are you sure about the Hand dryers? The 444s I've had this week have both been working. Albeit to the usual low levels as usual.
Although clearly Bombardier stock hasn't been as affected, as the Chiltern 168 decided to throw full storm mode at me yesterday water air water air water water air water water air!
That sounds brilliant! A little naff, but I love the idea of being able to play music through the train.
JohnElliott
15 Sep 2014
The 1930s express stock on the SR (6PUL, 5BEL and so on) had motor generators and 70v control circuits. The 4SUBs, though later, did everything at line voltage for compatibility with the existing SUB fleet.
47271
28 Apr 2015
Going by my last few trips, Coach G is a pretty much unused feature of an 11 car Pendolino. [emoji38]
craigybagel
25 Oct 2012
I know on the units at my TOC on units that use the dryer we've isolated the heating element of the dryers because of the issue. They still blow air, its just at the ambient temperature. Perhaps SWT have done the same?
43096
23 Nov 2015
Then they should be fixed properly. Why does the railway struggle to provide decent toilet facilities that include a working bog and sensible soap, water and hot air facilities? It is an utter joke.
MikePJ
10 Dec 2015
When I was a teenager (early-mid 1990s), I travelled to and from Portsmouth Harbour station to go to school. In the springtime, polystyrene boxes containing freshly-dug wet garlic would arrive on the fast ferry from the Isle of Wight, and be loaded into the guards' compartment of the 1606 express to London, in order to be delivered to smart restaurants the same evening! Pretty sure this unusual traffic survived into the 442 era on the Portsmouth Line.
Ianigsy
12 May 2015
There's several instances of this, Class 313/317 blinds showing destinations such as Spalding and even (if I recall correctly) on a closed former Midland branch.
Headbolt Lane was the one on Merseyrail units- it also appeared on the Solari indicator at Moorfields, along with Ormskirk via Marsh Lane (or words to that effect).
Somewhere in a drawer I still have a pair of Virgin branded headphones from a trip from Leeds to Edinburgh on a First Class advance in 2004- as I recall, quite a pleasant way to spend the return journey listening to an evening's output on Radio 4.
Cowley
General Discussion
15 Apr 2016
Devon
What sort of music would it have been Mr B, are we talking Brahms or the Sex Pistols? :D
Strathclyder
12 Jun 2013
Clydebank, West Dunbartonshire
380 multiple working is a daily occurrence on both the Ayrshire Coast and Inverclyde Lines, as far as I'm aware. Due to restrictive platform lengths along both lines, a 7 car formation (1 380/0 & 380/1) is the maximum allowed. On those two lines at least, the benefits of the gangways outweigh the downsides.
