Trivia - WALES - the "most" least stops for a journey entirely within Wales?
crispy1978
4 Feb 2013
Scarborough
Pretty sure there was a thread in the UK as a whole re: this - but didn't find one re: Wales.
Basically, I am interested in the highest number of stops between two stations involving a journey wholly within Wales and its associated islands (i.e. including Anglesey, etc.) - but you need to keep changes to a minimum within Wales.
A look at the National Rail Map however seemed to show that you might need to utilise some English lines (Shrewsbury - Hereford, etc).
Will try and add some more detail if needed later.
PHILIPE
14 Nov 2011
Caerphilly
Cardiff Bay to Blaenau Ffestiniog - 4 trains, 3 changes.
Cardiff Bay to Cardiff Queen St
Cardiff Queens St to Cardiff Central
Cardiff Central to Llandudno Jn
Llandudno Jn to Blaenau Ffestiniog
SeanG
4 May 2013
Surely you'd have to go up the Marches, which is in England.
Unless I have interpreted the question incorrectly
PHILIPE
14 Nov 2011
Caerphilly
The OP has originally said Marches will have to be used but has disappeared and left another message which will publish when time available. Post #1 refers
gazthomas
5 Jun 2011
St. Albans
I would think this would be something like Fishguard to the most extreme point of the Heart of Wales - I'm guessing Knuckles, unless you started at say Abergavenny and went via Llanelli
Llanigraham
23 Mar 2013
Powys
1/ Fishguard to Carmarthen
2/ Carmarthen to Llanelli
3/ Llanelli to Shrewsbury
4/ Shrewsbury to Machynlleth
5/ Machynlleth to Pwllheli
Although through trains are possible on that route, at some times you would need to change as above.
30907
The connections NRE throws up are 2,2 and 3 changes.
Though the route must surely have the "most least" stops (counting requests, obviously) as opposed to changes.
