TRUST - finding a specific unit
EastCoastway
6 Mar 2019
Hello,
Part of my job involves looking for lost property and knowing what a unit is working after it has terminated would be handy on the off chance that when the service has been terminated an item hasn't been found. Does anyone know the TRUST command for finding the diagram for a specific unit, please?
LA50041
20 Feb 2017
Hello,
Think you can only get a unit diagram from genius.
I’ve not found a way otherwise
janb
16 Jul 2008
If you have access to Gemini you can do it.
With TRUST I was only ever able to look at a location, look at the unit allocation (command UA) and work it out myself.
Aictos
28 Apr 2009
Indeed time consuming but sometimes quicker if you put in the TOC code too especially if it’s a location served by more then one TOC.
DarloRich
Fenny Stratford
Hello,
Surely asking your manager for the appropriate training would be the right answer
Aictos
28 Apr 2009
Depends on the manager, when I used it in a previous role like everything elsewhere I had to learn on the job and teach myself as it wasn’t something the manager knew anything about.
In the end, it depends on the training that’s available.
800002
19 Jun 2019
Would an 'E3' Locomotive Enquiry be of any use?
But it would only tell you where the unit is last reported as being at, and the previous service it ran.
43094
19 May 2010
It used to be possible to check a specific unit in TRUST (using the TSRO function).
However that was removed when Web Gemini was brought online in the late 2000s.
Your best bet is to ask officially for a Web Gemini sign-on, with the appropriate permissions to access units operated by whichever TOC you need.
hurri67
25 Sep 2015
could you pm me the input code so I can try it please?
