dennis63uk
I've downloaded it and it is a great route. Had a struggle with the class66 to get it up the hill as speed dropped to 5 mph
James 66526 said:66s are more powerful than 37s anyway. You can keep above 20 if you acclerate at the right moment.
Sturdjos said:When you approach Riverside on the local services ( Blackbrook - Riverside / Maybank - Riverside), you are held at the signal before the one before the station, which is at caution, and directs you into platform 1 ( I think!).
Is this a bug, or, are you meant to trip past it ( as I have done on both routes), or are you meant for the 5 mins plus at the signal for it to clear?
lankylancaster said:The signal always changes to yellow as I am apporaching it.... I've never had a red there before.
Chaz said:I think you just Isolate the AWS/TPWS Safety systems.
You must've been going damn slow to get caught there!Julian G said:I was struggling with the 66 on the Steep Climb from Radley Junction, the train kept going backwards , so I had to exceed the limits of the 66 and go to Notch 8 (from 5mph),
it was quite hard, but at the end i got there!
a) I was on an MSN conversation for 2mins , and I have forgotten about the trainCoxster said:You must've been going damn slow to get caught there!
Simon_G said:On services that terminate in the bay at Riverside, the signal just after Washpool station should be red when you first see it, then clear to yellow with a left feather as you approach. Have you found that it stays at red?
Wouldn't that one be more appropriate on X-City??Simon_G said:blokes on bridges (who's going to make that object, then?!)
