Twin Pendolino Testing This Week
455driver
10 May 2010
I agree with the ideas of too long trains and few stations capable of holding the whole train, but also, there are other factors like:
-A really slow acceleration due to a heavier train
-Also a long stopping distance, unless maybe all brakes of both units are applied.
-Signal blocks are occupied by more of a train at one time, which is the case with freight anyway, but also some signal blocks will end up being short enough for an 18 car train to occupy two at once, one block being fully occupied, which is most likely in a built up station are like a terminus.
- But a bigger issue in my eyes is to do with seat reservations, especially at a terminus. People have to walk a very long distance to where they need to sit, and this is worse considering you can't walk through the whole train, only each unit, so in a rush for the front when you're at the back will cause problems.
So the seat reservation "problem" is worse than no brakes, I think you need to look at your priorities!
As for the rest of your post, um wrong.
I reckon substations will be going boom as it passes :roll:
Power problems when a single Eurostar set used to pass.
One would hope that ten billion pounds bought some new substations.
VTPreston_Tez
26 Jan 2012
Preston
Both are implausible though... Edinburgh/Glasgow - Liverpool would surely be more likely.
Glasgow Trains have most of that covered, nothing a change at Carlisle can't solve. I'm hoping for a new route after Warrington however, something like Chester and if we're very lucky, down to Cardiff and that may prove popular.
MidnightFlyer
16 May 2010
Glasgow Trains has failed to take off AFAICS. Change at Carlisle for Liverpool? No you don't.
David
9 Jul 2005
Scunthorpe
You can already get to Chester direct from Warrington though, and Cardiff can be reached with 1 change from Preston and Warrington. Either at Crewe onto the ATW service or at Birmingam New Street onto an XC service.
sonic2009
19 Jan 2010
Crewe
i saw the 18-car Pendo on Wednesday Evening/Thursday Morning at Crewe.
Can anyone explain why two floodlights light up the Pantographs?
Also 390956 was noted at Crewe Thursday Afternoon
Yew
12 Mar 2011
The floodlights where probably to see how the pantographs interact with eachother
Mike C
18 Nov 2011
Lights on pans would be to illuminate them for cameras mounted on the roof to see how the dynamics are with two of them raised. If I would hazard a guess I'd say they are looking at how the rear pantograph copes with a wire which has an oscillation set up in it by the leading pantograph. The leading pan would have a camera on it for a return journey and/or to compare the two - the leading one being the "benchmark". It is something I've done before on our trains.
