Two Together identical tickets?
Leisurefirst
23 Apr 2013
Hello there,
Regarding the Two Together railcard...
Do the two tickets issued have to be identical if the two people concerned are making the same journey but one aleady has a ticket for part of the journey?
I.e. London to Southend if one person has a Freedom Pass can one ticket be bought from London & one from Upminster or would both have to have the same origin station?
Thanks!
JB_B
27 Dec 2013
A large majority of Two Together Railcard holders will be buying two identical tickets but I dont think that the terms and conditions actually require you to do so (although the tickets must be purchased at the same time).
As far as I know, most (or all) public-facing retail systems are incapable of accomodating your requirement but I understand that at least some ticket issuing systems used by booking offices should be able to cope. That means you'll probably need to buy the tickets face to face and you may need to shop around.
If you use the forum search you can find quite a few threads on this issue.
The terms and conditions are here:-
Edit: I note that the T&Cs now have an extra 'information' text after point 4.5
"INFORMATION:
Discounted price tickets purchased by a Two Together Railcard holder should be issued for travel for the same origin and destination and should normally be of the same ticket type (example both Off-Peak Returns)."
Note that the text says "should" not "must." As with similar "Information" points in the National Rail Conditions of Transport ( NRCoT ) I think it's reasonable to assume that this text doesn't form part of the conditions and merely represent RDG's aspirations.
Starmill
Fares Advisor
18 May 2012
Bolton
If the tickets were issued, I would say that they would be valid to use in the way you describe. However in most cases I think a ticket office will either be technically incapable of issuing that or otherwise the staff will refuse to do it.
Leisurefirst
23 Apr 2013
Thank you all for your replies.
Conclusion - file under more trouble than it's worth!
(Normally I have a Gold Card as well, but I refunded it under the current circumstances.)
Presume the same thing applies to PlusBus as one of us (in England anyway) has free bus travel from 09.30.
P Binnersley
30 Dec 2018
You should be able to get the plus bus as a separate ticket. It is in BR fares as XXXX to XXXX+BUS. You will need to show a ticket to/from XXXX.
I'm sure I've done this in the past when a ticket machine didn't give the +Bus option.
robbeech
11 Nov 2015
I’ve bought plus bus tickets from ticket offices separately, most of the time I haven’t even been asked for a ticket that allows it.
I’ve also bought them on board. I did a number of plus bus addons with the Northern 10p tickets, some with two together cards etc.
You should have no issues with this.
Leisurefirst
23 Apr 2013
...ah, but if you want just ONE PlusBus ticket in conjunction with Two Together discounted rail tickets can you get
a) One discounted PlusBus ticket.
b) One non-discounted PlusBus ticket only.
c) Two discounted PlusBus tickets or nothing?
Leisurefirst
23 Apr 2013
One of the above most likely.
I suspect so and that c) is probably likelier, in which case it might be cheaper to buy the least expensive non-discounted single to the destination and a PlusBus maybe rather than two discounted PlusBus tickets one of which you don't need?!
